So, the 1/16" thick o-rings reduce travel rather noticeably, so that by itself is a change of feel. Metric o-rings (5mm x 1.5mm) will have a smaller reduction of travel. I would suggest getting a couple of o-rings from a hardware store to get the idea and see if it's for you. If it is, it's really worth the investment getting the best o-rings like those from WASDkeyboards since they are made of better material (EPDM) than buna-n or nitrile rubber and won't harden up over time. BTW the wasd 40A-L are metric 1.5mm thick, the -R models are a bit thicker at 1/16". The way I see it, even spending $20 is worth it, because they will last for many years and you can transfer them from keyboard to keyboard. Also, 50A and 40A o-rings are much quieter than the regular (and cheaper) 70A. I've tried them all!
