Steelseries Diablo3 (I have 2) it seems this roughened rubber coating seems to tricky to clean.
- Alcohol is said to make the roughened going away - not sure I want that.
- Water and mild glass and TFT cleaners, I think makes it clean, but very very sticky once dry - so that after 3 days you have more grease than before.
- moistering soap?
- when it comes out of the box do they put silicon on it so it is clean and non sticky but still roughened?
How do you clean your mouse without ruining the rubber?
