Author Topic: GEEKHACK MOVIE NIGHT  (Read 95364 times)
Offline YoungMichael88
  • HHKB Wannabe
« on: Sat, 28 September 2013, 14:15:28 »
Welcome to Geekhack Movie Night!
Show time:
- Saturdays at 10pm EST (9pm Central, 8pm Mountain, 7pm Pacific)
Join in on the fun via Stream/Chat
To be included in the weekly movie drawing, please send your movie pick Via PM to YoungMichael88.
(ONE movie pick per member. Include "Movie Night" in the Subject and your user name and movie pick in the body)
NOTE: You can change your movie pick at any time.
« Last Edit: Sat, 19 April 2014, 21:00:02 by YoungMichael88 »
  • HHKB Wannabe
« Reply #1 on: Sat, 28 September 2013, 14:15:46 »
This Weeks Movie:
3) Krogenar - The Manitou
Here's where it all happens: Stream/Chat
Countdown timer HERE
« Last Edit: Mon, 18 August 2014, 20:43:58 by YoungMichael88 »
  • HHKB Wannabe
« Reply #2 on: Sat, 28 September 2013, 14:16:26 »
Movie List:
1) IvanIvanovich - Maniac (2012)
2) Greystoke - Delicatessen
4) YoungMichael88 - Shaun of the Dead
5) HoffmanMyster - The Blues Brothers
6) Badwrench - Akira
7) dragonxx21 - WALL-E
8 ) UniClown - In Bruges
9) Wildcard - The Royal Tenenbaums
10) Trent - The Host (2006)
11) hwood34 - 2001: A Space Odyssey
12) Air Tree - The Big Lebowski
13) inteli722 - The Matrix
14) Coreda - Buried
15) katushkin - The Room
« Last Edit: Mon, 26 May 2014, 15:51:03 by YoungMichael88 »
Re: GEEKHACK MOVIE NIGHT
« Reply #3 on: Sat, 28 September 2013, 14:18:32 »
reserved
  • HHKB Wannabe
« Reply #4 on: Sat, 28 September 2013, 14:21:13 »
« Reply #5 on: Sat, 28 September 2013, 22:29:17 »
Can you explain how the streamchat is going to work? I've only ever used the TwitchTV one.
« Reply #6 on: Sat, 28 September 2013, 22:32:59 »
what is stream chat btw.... I've never heard of it.
« Reply #7 on: Sat, 28 September 2013, 22:36:08 »
It's basically the same.  You have to "register" an identity (similar to IRC where you don't actually register) and you then chat in a chatbox to the right of the movie.  I think it's more or less the same as Twitch.
« Reply #8 on: Sat, 28 September 2013, 22:37:20 »
what's the streamchat website?
« Reply #9 on: Sat, 28 September 2013, 22:38:45 »
The stream (at least when I stream) will be located at http://www.livestream.com/movie_streamer (YoungMichael88 will add this to the OP) and if you go there now you can see the stream chat and you can even chat at the moment to test it out if you'd like.
« Reply #10 on: Sat, 28 September 2013, 22:41:22 »
can u reply multiple times? i was just in moose's twitchtv stream/chat and anything after 3 consecutive replies and it said it didnt go through due to "spam". not my fault i type fast.
« Reply #11 on: Sat, 28 September 2013, 22:42:38 »
Do you have the premium account to stream movies at 720p?
« Reply #12 on: Sat, 28 September 2013, 22:44:36 »
I've never had problems with that.  I've had groups of 5 or so of us just spamming during stupid movies with zero issues.  It's possible they've changed it recently though.
« Reply #13 on: Sat, 28 September 2013, 22:46:01 »
No.  You will have to acquire the movie yourself to get high-def.  The point of the stream is to allow many people to view an acceptable stream which makes it really easy to do a group-view.  It is not to start a high-def service.
« Reply #14 on: Sat, 28 September 2013, 22:50:03 »
ok, so are you using a cam software like cam-twist, which captures a section of your screen as a device, and then that goes through to the livestream.com
« Reply #15 on: Sat, 28 September 2013, 22:53:49 »
Livestream has that functionality built in to their streaming software, so I just use that.  But yes it does exactly as you described, it simply crops a portion of the screen to stream.
« Reply #16 on: Sat, 28 September 2013, 23:02:14 »
hmmm
Ok so the live stream thing has a very small chatbox,  to make it bigger, you can detach it, and put it on a secondary monitor with lower resolution so it looks bigger.   I guess this will probably be the best stream service then since the box is detachable.
Also, should we pick a movie that "comes out" on dvd/bray  this week.. instead of one that most of us has already seen, perhaps multiple times?
I think there's a good chance we'll get pacific rim before next friday.
  • HHKB Wannabe
« Reply #17 on: Sun, 29 September 2013, 11:40:40 »
Well my whole idea for this is to share a movie you love with others. I don't want to be the guy who chooses the movie everyone watches. I want everyone involved to be a part of it. BUT as I said, you can change your movie pick at any time so if you can convince others to change to a current movie like pacific rim then the numbers in the draw will be in your favor.
  • HHKB Wannabe
« Reply #18 on: Sun, 29 September 2013, 12:08:16 »
I've added the stream link in Reply #2
Offline Badwrench
  • ummmm.....I forgot
« Reply #19 on: Sun, 29 September 2013, 12:38:25 »
What kind of data flow is this going to use?  I want to try it at work, but have very limited bandwidth.
Also, my vote for the first movie should be the one that the OP wants to share:  The Life Aquatic.  my 2c.
  • HHKB Wannabe
« Reply #20 on: Sun, 29 September 2013, 12:40:04 »
I have added links to Wikipedia for each movie in the movie list in Reply #1
  • HHKB Wannabe
« Reply #21 on: Sun, 29 September 2013, 12:40:29 »
Shall I add you to the list?
Offline Badwrench
« Reply #22 on: Sun, 29 September 2013, 13:23:23 »
Might as well.  Gonna give it a run regardless of whether I get an email from IT saying I am using too much data.
« Reply #23 on: Sun, 29 September 2013, 16:47:58 »
As long as your allocation is > 500MByte, You'd be fine for the whole movie.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #24 on: Mon, 30 September 2013, 07:05:13 »
All good movie choices -- GH members have pretty good taste in movies!  :thumb:
Quote from: Samuel Adams
« Reply #25 on: Mon, 30 September 2013, 18:45:16 »
I think we're all playing it safe...
I kinda wanted to suggest Real Steel, the robot movie, since I haven't seen it, and it supposedly had good effects... bu..... I'm pretty sure it's to kiddie for all the adult GHers who actually became full adults.
  • HHKB Wannabe
« Reply #26 on: Mon, 30 September 2013, 18:51:50 »
Finding Nemo is in the list.... I think you're good. And I like Finding Nemo.
  • HHKB Wannabe
« Reply #27 on: Mon, 30 September 2013, 18:54:47 »
So I picked up an overtime shift this Friday night. You're all gonna need to tell me how it goes! Figures, I miss the first movie night that I created! Haha actually I'm going to miss the first three!
Offline Badwrench
« Reply #28 on: Mon, 30 September 2013, 19:00:17 »
I have never been told what the cutoff is for a flag to be thrown.  I was warned before for watching a 30min Funday Monday in 720p.  Anyone know if I can drop the resolution in the stream to lower my usage?
  • HHKB Wannabe
« Reply #29 on: Mon, 30 September 2013, 23:05:52 »
This weeks movie has been drawn and is up on the marquee. 9) HoffmanMyster - Brick
« Reply #30 on: Mon, 30 September 2013, 23:30:05 »
Cool!  I already have that one so I won't need to download it.  :D
It's a good movie, guys, I promise.
  • HHKB Wannabe
« Reply #31 on: Tue, 01 October 2013, 00:01:47 »
Im going to download beforehand and watch it at work but it's going to be earlier than you guys. I'm busy at the proper time. What was I thinking when I took that overtime shift! I know! I wasn't thinking!
« Reply #32 on: Tue, 01 October 2013, 00:38:33 »
go up to boss, put foot down, demand raise, not get one, look cool quitting, get called in a day later, meet boss's daughter, she's fat, date her anyway, she becomes skinny and super hawt, becomes attached to you, you lose interest, and on that same friday, you decide to stub her on the date and wtach movies with us instead...
In hollywood movie time, this shouldn't take more than 2 days, but you got 3 days from now to do it.
  • HHKB Wannabe
« Reply #33 on: Tue, 01 October 2013, 00:47:05 »
hmmm. Boss has two daughters...
Offline dragonxx21
« Reply #34 on: Tue, 01 October 2013, 01:06:00 »
You live in Canada. Just say you hit a moose. Trust me, it works all the time.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
« Reply #35 on: Tue, 01 October 2013, 03:58:24 »
Oh man..... how will you ever ch00se...  dual-wielding is the only solution..
« Reply #36 on: Tue, 01 October 2013, 03:59:03 »
Also... PACIFIC rim is OUT... told ya..... I called it...
  • HHKB Wannabe
« Reply #37 on: Fri, 04 October 2013, 18:36:54 »
So the first movie night starts in just under 4 and a half hours from now. I'm at work and can't participate because I'm a fool who doesn't think before accepting overtime. Hopefully everything goes smoothly and people participate and have a good time!
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #38 on: Fri, 04 October 2013, 20:29:34 »
Looking forward to it.
Offline Badwrench
« Reply #39 on: Fri, 04 October 2013, 21:34:20 »
Dang!  I am out for tonight.  Boss picked tonight to be here.  The guy never stays past 3pm, and now he is here waiting till 11pm to go out.    :mad:
  • HHKB Wannabe
« Reply #40 on: Fri, 04 October 2013, 22:07:46 »
ugh...work....bummer
Offline dragonxx21
« Reply #41 on: Fri, 04 October 2013, 22:18:22 »
watch while working C:
Keyboards Owned:
  • HHKB Wannabe
« Reply #42 on: Fri, 04 October 2013, 22:25:03 »
Oh if only this was possible... My own fault tho.
Offline Lastpilot
  • Power stance
« Reply #43 on: Fri, 04 October 2013, 22:27:30 »
I think you should fix the OP links. You are missing the ":" in http://
  • HHKB Wannabe
« Reply #44 on: Fri, 04 October 2013, 22:32:18 »
It doesn't work?
  • HHKB Wannabe
« Reply #45 on: Fri, 04 October 2013, 22:36:01 »
That's really weird. When I go to edit the links the ":" is indeed there. Yet I click on it and low and behold it doesn't work!
  • HHKB Wannabe
« Reply #46 on: Fri, 04 October 2013, 22:41:37 »
It should work now. Sorry about that guys
Offline Badwrench
« Reply #47 on: Fri, 04 October 2013, 22:54:08 »
I wish.  As stated before, I got a warning just for watching a small youtube vid in the corner of my second screen.  This would be a bit more than that.
Offline Rayne
  • For Science!
« Reply #48 on: Fri, 04 October 2013, 22:57:27 »
i am here and ready to watch a movie
« Reply #49 on: Fri, 04 October 2013, 22:57:59 »
Okay everyone!  Just wanted to stop by with a little over 2 minutes remaining until go time: I've got everything cued up and ready to go.  I'll be starting the stream exactly as the countdown timer in the OP runs out, and I'll start the movie immediately following.
Please relay any sound or video issues to me in a calm and collected manner.  This is our first movie night here, and there might be unforeseen issues.  We can work through them in a sensible manner.  :)
Anyway, hope everyone enjoys the movie!  It's one of my favourites.
