Author Topic: KBP mini V60, new brand from Taiwan  (Read 31929 times)
Offline sdiearly
« on: Tue, 22 April 2014, 04:16:52 »
I think I should post this in "review", but this product isn't published now.
This is more like brief introduction.
The new brand:
http://www.kbp.com.tw/
From this address, it shows it comes from Taiwan.
I am glad to have a chance to get one sample at this moment.
About mini V60:
This keyboard is ANSI-60% layout, like poker/poker2 with 61 keys.
I copy feature list from their manual:
1.  USB Interface
2.  HID Device
3.  Plug & Play
4.  Firmware upgradable over USB
5.  QWERTY Layout
6.  About 60% as wide as of the standard 104-Key keyboard
7.  Uses Cherry MX-Series switches
8.  N-key rollover
9.  6 Port dip switch for customer define
10. Multi-Lingual Layout
11. Laser-engraved Keycaps
12. Dual Led backlit function
Then I have some pictures to show details.
The boxing:
Top
bottom:
The Chinese words tell us it made in Taiwan.
The contents
1.  Keyboard
     *.  Dimension(W*L*H):100 mm*291 mm*42.5 mm
     *.  Weight:510 g
2.  Replacement keycap
3.  Cable
     *. 1.5 meters
4.  Keycap puller
The special feature:
Duel back-light LED
User can change the color via pressing "fn" + "enter"
My gift is two colors in RED/BLUE
Strong and good look case
Those corner design improve the structure and poise of keyboard
Actually, KBP V60 is assembled by Costar,
To be the 1st and the only one 60% keyboard product from Costar OEM.
I think the quality can be the same as CODE/Filco/IDF/Feenix, those famous products
« Last Edit: Tue, 22 April 2014, 04:19:55 by sdiearly »
My favorite 60%:  TEX-Beetle
                 80%:  KBtalKing Race
                100%: Cherry G80-3494, Zowie Celeritas
Offline sth
  • 2 girls 1 cuprubber
Re: KBP mini V60, new brand from Taiwan
« Reply #1 on: Tue, 22 April 2014, 04:18:24 »
is there anything that sets this apart from other 60%?
Offline sdiearly
« Reply #2 on: Tue, 22 April 2014, 04:35:22 »
I do not know if this is their finalized design in FN layout.
beside keyboard using, I think this case can make me type comfortably.
« Last Edit: Tue, 22 April 2014, 04:37:30 by sdiearly »
                 80%:  KBtalKing Race
Offline ajx
« Reply #3 on: Tue, 22 April 2014, 07:24:48 »
any chance to get white LED color among others colors or is it only blue/red as main LED color?
Offline Oobly
« Reply #4 on: Tue, 22 April 2014, 07:47:00 »
The default Fn layer is not very good, particularly the placement of Home and End.
They mention the firmware is upgradable, but is the layout programmable? What do the various DIP switches do?
I agree, white LEDs would be nice.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline p3lim
« Reply #5 on: Tue, 22 April 2014, 08:11:50 »
What controller is on it?
Offline sdiearly
« Reply #6 on: Tue, 22 April 2014, 09:36:09 »
Yes, I've complain the layout to them.
And this is sample production, probably not the final layout.
LED spec show on their website only two choices, blue/red and blue/green.
white light could not to have duel color since it's two pins controlled.
dip switches are used to do do key replacement.
MCU seems to be arm series.
                 80%:  KBtalKing Race
Offline Demetrium
« Reply #7 on: Tue, 22 April 2014, 09:38:18 »
Looks nice in red!
Offline Zeal
    • Zeal Generation Inc.
« Reply #8 on: Fri, 02 May 2014, 11:35:22 »
You said the keyboard is made by Costar, but a few months back, the developer said it uses Cherry stabilizers. Does it use Cherry stabilizers, or Costar style stabs?
« Reply #9 on: Fri, 02 May 2014, 11:38:17 »
And because it has different mounting holes than a Poker-style 60%, they just eliminated many buyers who would replace the stock case with an existing alu case.
Offline Oobly
« Reply #10 on: Fri, 02 May 2014, 11:55:55 »
Is it PCB or plate mount?
Offline Doesntknowwhattosay
« Reply #11 on: Fri, 02 May 2014, 16:49:48 »
I second this. Could you post some pics of the naked keyboard without keycaps?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #12 on: Fri, 02 May 2014, 18:06:46 »
^I would like to know this also^
Some of Ye ole  Keyboards -->
OTD Koala:  62g Old MX-Blacks   |   LZ-GH V2:  MX-?62g   |   KMAC2:   62g Tactile MX-Greys   |   LZ CLS s:   62g Vintage MX-Blacks   |   X60:   62g Vintage MX-Blacks   |   GON NerD 60:  62g Old MX-Clears   |   Filco MJ2 (Beige) TKL's:  62g MX-Clears  &   62g Vintage MX-Blacks   |   IBM '91 SSK
WTB/WTS/WTT ---->
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #13 on: Fri, 02 May 2014, 18:15:59 »
It uses Cherry stabs
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #14 on: Fri, 02 May 2014, 18:18:01 »
That's what I figured, but when I heard "made by Costar" it made me wonder.
WTB/WTS/WTT ---->
Offline pexon
    • Pexon PCs
« Reply #15 on: Fri, 02 May 2014, 18:40:27 »
Yea, its a bit strange
Offline johndavis33
« Reply #16 on: Fri, 02 May 2014, 20:06:28 »
Oh, sweet! I've been waiting for a 60% with greens or whites!
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #17 on: Fri, 02 May 2014, 20:11:44 »
I can't wait for the V60 MTS to come out.  That one I for sure plan on getting.
WTB/WTS/WTT ---->
Offline p3lim
« Reply #18 on: Fri, 02 May 2014, 21:17:07 »
You said its firmware is upgradable, I'd like to know if we can flash custom firmware to it or not, and if that is the case, what controller is on it?
Offline sdiearly
« Reply #19 on: Mon, 12 May 2014, 00:51:55 »
It is just likes ducky stabilizer(which is on my hand).
But I can't sure the final design will be filco style or ducky style.
                 80%:  KBtalKing Race
Offline sdiearly
« Reply #20 on: Mon, 12 May 2014, 00:58:04 »
Stabs can't help you to determine this keyboard comes from which manufacture.
Using what part to assemble is decided by brand, not OEM.
                 80%:  KBtalKing Race
Offline sdiearly
« Reply #21 on: Mon, 12 May 2014, 01:05:24 »
I don't think FW customized tool can be released by this vendor, due to many warranty issues.
Maybe we can only get the .exe file to update firmware(still following their design).
Again, I'm trying to complain this layout in FN layer.
                 80%:  KBtalKing Race
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #22 on: Mon, 12 May 2014, 01:06:57 »
I'm aware of that.  I actually prefer Costar stabs, and was hoping they would be used since it was made by them  :)
WTB/WTS/WTT ---->
Offline Maya_Natsume
« Reply #23 on: Fri, 06 June 2014, 11:26:32 »
For anyone interested in pre-ordering, Rabbit Web Factory seems to be taking order : http://rabbitwebfactory.com/pages/v60
Offline ideus
  • Björkö.
« Reply #24 on: Fri, 06 June 2014, 13:39:30 »
The reference here read plate-based.
Offline ideus
  • Björkö.
« Reply #25 on: Fri, 06 June 2014, 13:44:34 »
I like the case, and the triple access to arrows, left, right, and ala Poker X. Now I should reconsider the decision I had almost took to get a new Poker II, because I do not like the lack of a switchable fixed cluster of arrows of the Poker II that this one has. I use that cluster a lot in my Poker X. However, I may miss the option to upgrade the case due to the different positions of the screws in this one.
« Reply #26 on: Fri, 06 June 2014, 22:08:47 »
Yep, it seems that V60 is plate-based from the reference link.
For those who are looking at co-star stabilizer for V60, you would be disappointed.
I emailed Rabbit Web Factory and got to know that despite being manufactured by co-star, V60 is using cherry stabilizer instead of co-star stabilizer.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #27 on: Fri, 06 June 2014, 23:01:07 »
Yeah I saw somewhere that it uses Cherry stabs.  I still wouldn't mind getting one though.
The the arrow layers is one of the main things I like about it.  Also I think Pexon mentioned that he might be able to get some aftermarket V60 cases made at some point.
WTB/WTS/WTT ---->
Offline ideus
  • Björkö.
« Reply #28 on: Sat, 07 June 2014, 01:10:35 »
I am trying to make my mind about this or a Sprit kit. Any advice on it?
Offline bahamot
    • bistropolis - dine with style
« Reply #29 on: Sat, 07 June 2014, 03:39:12 »
Too bad it doesn't compatible with poker case, otherwise I might give a try.
« Reply #30 on: Sat, 07 June 2014, 03:55:40 »
Maybe you can consider V60. It seems that online reviews on this keyboard is pretty good. I think this is because V60 has the same contract manufacturer as Filco, which is co-star.
Price wise, it's quite decent.
Offline bahamot
« Reply #31 on: Sat, 07 June 2014, 04:15:59 »
As it isn't compatible with poker case, I am thinking to get ducky mini instead.
Offline RESPRiT
  • HHKB = ❤
« Reply #33 on: Sat, 07 June 2014, 08:00:27 »
This is actually pretty neat. I'm skeptical in how popular they may ever get without a Western supplier though.
Offline ideus
  • Björkö.
« Reply #34 on: Sat, 07 June 2014, 11:00:10 »
I am very tempted to pre-order one.
Offline sdiearly
« Reply #35 on: Sun, 08 June 2014, 05:04:10 »
Add pictures on plate and board view.
Said again, the parts "stabs" are not particular to be recognized this keyboard comes from which manufacturer.
In Taiwan, those stabs are used in plated PCB design, not purely called cherry stab.
                 80%:  KBtalKing Race
Offline ideus
  • Björkö.
« Reply #36 on: Sun, 08 June 2014, 13:27:13 »
It would be a hit, if it were programmable.
« Reply #37 on: Mon, 09 June 2014, 01:50:30 »
By the way, does anyone happen to know what's the weight of V60?
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #38 on: Mon, 09 June 2014, 02:26:17 »
Are all Costar PCB's blue?  I know that Filco's are.
I'm trying to hold off until the V60 MTS comes out, but I'll probably break down and buy one of these when MK.com gets them back in stock.
WTB/WTS/WTT ---->
Offline sdiearly
« Reply #39 on: Mon, 09 June 2014, 02:31:02 »
PCB color doesnot depends on OEM Costar.
That's decided by brand owner.
PCB is "A" part from another vendor and wait Costar to assemble a keyboard.
                 80%:  KBtalKing Race
Offline sdiearly
« Reply #40 on: Mon, 09 June 2014, 02:32:14 »
I have listed the spec in OP.
                 80%:  KBtalKing Race
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #41 on: Fri, 13 June 2014, 23:03:54 »
KBP posted this on their FB page.  It says that if a Poker case has a big enough hole for the V60's extra dip switches then it will fit.
https://www.facebook.com/media/set/?set=a.914047031954104.1073741838.316701428355337&type=1
WTB/WTS/WTT ---->
Offline coggys
  • Richard
« Reply #42 on: Thu, 19 June 2014, 19:01:16 »
Woah, what is the blue keyboard? And what did you do to it? Looks gorgeous.  :eek:
Offline sdiearly
« Reply #43 on: Fri, 20 June 2014, 01:47:38 »
that's TEX Beetle, my favorite 60%.
I replace 2 kinds of color key caps to separate them into alphabeta keys and modifier keys.
                 80%:  KBtalKing Race
Offline coggys
  • Richard
« Reply #44 on: Fri, 20 June 2014, 12:17:54 »
What kind of case is that and where did you get it? I've been planning on getting a mechanical keyboard for quite some time now and the Tex you have looks absolutely stunning.
Offline okwchin
« Reply #45 on: Fri, 20 June 2014, 13:27:55 »
You can see the holes for the poker layout. But as the other post linking to the FB page, its the larger DIP switch width that is the only binding component. Removal of material from your case to extend the dip switch opening and you will be able to install the VT60 into a poker and pure compatible case. It looks to me like they did everything they could to give you compatibility, and the only limitation being one that they did not want to be constrained by.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #46 on: Fri, 20 June 2014, 14:26:10 »
I like cherry stabs... :$
Also, you can pre-order these from Pexon. I've got one reserved :D
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #47 on: Fri, 20 June 2014, 16:51:15 »
Where's the order button?
Offline katushkin
  • Just the guy
« Reply #48 on: Fri, 20 June 2014, 16:56:13 »
http://pexonpcs.co.uk/V60Mini
You have an hour and 5 minutes to get pre-orders in
And now it's gone. I think.
« Last Edit: Fri, 20 June 2014, 18:12:01 by katushkin »
Offline sdiearly
« Reply #49 on: Sat, 21 June 2014, 02:18:44 »
That's TEX Beetle's original case. This company is near to my place.  :p
Here are my Beetles
http://imgur.com/a/pz7D9
                 80%:  KBtalKing Race
