Author Topic: Tough question  (Read 2413 times)
Tough question
« on: Thu, 18 September 2014, 19:05:39 »
Which one is better
4x X7460 cpu with 50gb ram
or
4x E7540 cpu  with 16gb ram
Hrrrm........  the 7460 has more ghz..   but the 7540 has hyperthreading..
Offline paicrai
  • mindblank
Re: Tough question
« Reply #1 on: Thu, 18 September 2014, 19:08:06 »
hypetroodles
THE FEMINIST ILLUMINATI
Re: Tough question
« Reply #2 on: Thu, 18 September 2014, 19:09:58 »
hypetroodles
Indeed, it's almost like 30-45% increase in performance in server oriented stuff..
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Tough question
« Reply #3 on: Thu, 18 September 2014, 19:16:20 »
What are you going to use it for?
Re: Tough question
« Reply #5 on: Thu, 18 September 2014, 19:20:52 »
Well clearly evil needs more memory.
Re: Tough question
« Reply #6 on: Thu, 18 September 2014, 19:28:07 »
I mean.. there's 24 cores in either machines,  so I could do like, lots of stuff at the same time
I could do vpn, maybe a dedi CSgo server, once I get the game for $5,   maybe a nice cruncher for stata , sas.
Re: Tough question
« Reply #7 on: Thu, 18 September 2014, 19:46:49 »
CPU wise they are pretty close really in performance in most scenarios. Hyperthreading won't do you a ton of good in most of your proposed use cases especially with that many cores already... but E7540 runs on qpi link which is faster and has a lower tdp and is newer so the motherboard may have better features? On the other hand the X7460 has more cache and is clocked higher, and comes with way more memory, so much more so you could run things on a ramdisk with little effort which could be nice.
Assuming they cost about the same, it comes down to the motherboard I suppose.
Re: Tough question
« Reply #8 on: Thu, 18 September 2014, 19:50:41 »
Yea man.. that's why this is so tough.. LOLOL
Offline The Mad Professor
  • Ex Scientia, Rabies
Re: Tough question
« Reply #9 on: Thu, 18 September 2014, 19:58:45 »
Honestly? At this level of performance, any differences will be so negligible as to be completely irrelevant. It's like asking which is better: a car that goes 450mph with 72mpg or one that goes 451mph with 71mpg.
Mad Science means never stopping to ask "What's the worst that could happen?" - Schlock Mercenary
Re: Tough question
« Reply #10 on: Thu, 18 September 2014, 20:03:50 »
it's not irrelevant if I could only get 1 though..   gaaaahhhhh
Re: Tough question
« Reply #11 on: Thu, 18 September 2014, 21:39:09 »
is the ram specs the same (other than capacity of course) ?
Re: Tough question
« Reply #12 on: Thu, 18 September 2014, 21:49:51 »
Then the question becomes "which is cheaper?"
Re: Tough question
« Reply #13 on: Fri, 19 September 2014, 04:10:39 »
same specs other than capacity.
cost same.
Re: Tough question
« Reply #14 on: Fri, 19 September 2014, 12:10:39 »
ok...
Which one.. would be better,  if I want to support say 5-20 people on VPN
but i don't want to use the whole machine.. there will be other stuff..
Re: Tough question
« Reply #15 on: Fri, 19 September 2014, 13:03:11 »
I would get the one with more memory. Unless the motherboard is total **** all that memory is better value. With more memory you could run dozen virtual machines and have everything separated out no problem.
Offline paicrai
  • mindblank
Re: Tough question
« Reply #16 on: Fri, 19 September 2014, 14:15:45 »
flux capacitor
Re: Tough question
« Reply #17 on: Fri, 19 September 2014, 14:31:14 »
hmmm... good point...
