Author Topic: Ergo RH mouse upgrade!  (Read 1923 times)
Offline jabar
« on: Sun, 21 September 2014, 07:58:14 »
Howdy all,
So recently my G500's LMB switch is starting to spaz, registering very rapid double clicks, so it's pasture time. I've been doing a bit of research into mice now and there is quite a wealth of information here (thanks guys!). Back in 2011 when I bought the G500 I just literally selected the most reviewed mouse on Newegg and rolled with it.
There are some things I like about it. I really like its ergo grip but for me it's not conducive to palming. I still tip grip it; I never found its back high enough? I actually had to learn to use a normal mouse pad because the POS wrist rest gel pad I used forever + tip grip on the G500 = extreme carpal, only took a year to figure that out. But I digress.
After reading the guide here, I'm not entirely sold on the optical > laser debate but I have been looking at two opticals that seem nice: Steelseries Rival and the Roccat Kone *. Anyone have tips for someone moving away from the G500? Unlike keyboards I'd like this to be a one-and-done! As for its use, I do steadily game but am not crazy about sensitivity settings. In fact, I just turned off native acceleration on the G500 and my pointer seizes across the screen! I guess I should get use to it.
I also use an Artisan Hien L in wine red. Absolutely love that pad!
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Re: Ergo RH mouse upgrade!
« Reply #1 on: Sun, 21 September 2014, 10:56:01 »
you can replace all the buttons in that mouse with genuine Japan Omrons for $17
Offline jabar
« Reply #2 on: Sun, 21 September 2014, 14:10:24 »
Yeah, I'm not going to ditch it, but I think after 3 years I'd like to try something else. That and my DIY projects are slow to complete; my Phantom is still patiently waiting, what, 18 months in?
Phantom 7bit
Offline munch
« Reply #3 on: Sun, 21 September 2014, 20:44:03 »
the Mionix Naos 7000 is pretty hard to do anything but palm with IME. not sure if you have larger or smaller hands though, but I also gripped the G500/G400 etc fingertip grip. couldn't palm it either... not that I use palm grip though.
Offline jabar
« Reply #4 on: Mon, 22 September 2014, 14:09:41 »
That miniox naos looks awesome! too bad I wasn't mouse shopping when it was on Massdrop.
Phantom 7bit
