Author Topic: Body Casting  (Read 1747 times)
Body Casting
« on: Sun, 28 September 2014, 20:14:39 »
Hey dudes..
anyone know or have info on making a Standing cast, of one's back..
Re: Body Casting
« Reply #1 on: Mon, 29 September 2014, 00:23:16 »
Maybe plaster bandages would be easiest. Vaseline up and apply. Be very careful though because plaster is exothermic when it cures. Don't apply too much at once - if you do, you could burn yourself.
Most times when body parts are cast, the material used is Alginate, with additional support of plaster bandages. Alginate does shrink a bit and it is quite brittle so it will not survive many casts.
Offline RED-404
Re: Body Casting
« Reply #2 on: Mon, 29 September 2014, 01:08:06 »
NSFW'ish so not embedding it
He also has some other really good videos and not all of them are on the playlists.
Re: Body Casting
« Reply #3 on: Mon, 29 September 2014, 13:29:54 »
Also, it should go without saying but... shave beforehand. ;)
Re: Body Casting
« Reply #4 on: Mon, 29 September 2014, 14:07:41 »
ok..  thx for the link.. This seems like a 2 people job.. hrrmm......
Warning guys,, there are a bunch of NSFW links to the right of this tube vid.. LOL... heads up..
