I feel like a family member asking about why you need to spend so much on all that computer stuff, but what exactly makes that thing worth $213?
I would also want to know this, as far as I understand its just boils water? would a simple kettle not be good enough :x
If you're not a hot water user, this thing would be pretty useless
It comes down to time savings and convenience (laziness really)
Ok.. so when you need hot water..
Go downstairs,
Fill Kettle
Put on burner
Wait
Use water,
Dry kettle, put away
This is at fastest, a 10-15minute gig.
So... my day usually has 1 hot water time, 4 tea times (1 fresh hot 3 warmed from microwave ), , 2 ramen times.
I was going through the hot water routine at least 3-4 times per day. which amounts to about an hour of boiling water...
This electric boiler takes care of that for me..
It's essentially a Hot Water Server. It's a vacuum bottle + boiler + reheater..
I guess what made it $200, vs the $100 cheaper alternatives is merely the weeaboo factor, higher wages of jpn workers mostly..
The conflict in my mind now, is how much power I'm using for this convenience.. which is quite substantial vs the alternative of gas kettle, and regular electric kettles.
