Author Topic: Geekhack Handwriting Thread and Fountain Pen Thread  (Read 427222 times)
Offline Zeal
    • Zeal Generation Inc.
Re: Geekhack Handwriting Thread and Fountain Pen Thread
« Reply #50 on: Thu, 12 June 2014, 12:14:07 »
Seeing as we apparently type way too much here...
<transcript below since my handwriting can be pretty indecipherable>
hello Geekhack!
Fountain pens has [sic] been a hobby of mine for quite a while now... about 6 years or so. Collecting and using, then and now, both pens and inks, as well as other stuff like paper/notebooks too.
Thanks to them, I've bettered my penmanship; but I also have other styles of handwriting, based on the situation, as some people may find my regular writing tough to read.
Sometimes I also vary it based on the pen and paper I'm using, as some pens write very wide and therefore need to be handled in a different way.
However I also just like to vary it based on what I feel like; playing with fountain pens is fun.
Pens used in this post, from the top:
Omas Milord w/ Diamine Sapphire Blue;
Mont Blanc Herbert von Karajan with Sailor Tokiwa Matsu;
Lamy 2000 with a green ink I mixed;
Kaweco Elite 587 with Rohrer & Klingner Alt-goldgrun;
Sailor ProGear Realo and Sailor Shigure;
and a TWSBI Vac 700 I just turned to a cursive italic.
Nice pens! I really like the Diamine Sapphire Blue.
Is that Kaweco Elite 587 the same as a Dialog 2? It looks very similar at least. And you ground the nib in the Vac 700 yourself?
The Elite 587 looks like this (though mine is missing two of the gold cap rings and the picture there has one missing). It's an old pen from the 1950s I got for a steal from eBay. Was worried that the piston seal, which is made of cork, was already dried up and deteriorated, but it was working perfectly - what a miracle. The best part is definitely the flexible OBB nib, which is stubby. Amazing line variation, and writes very wet!
The Vac 700, indeed I ground myself, just last night. I do a bit of work on the side, doing nib grinds and pen adjustments for the local fountain pen group, and this was just another of the requests I got.
hmm... i would also really like to file down an italic to maybe 30deg..
any tips on this...
Hmm, do you mean grinding a pen nib to an oblique nib? The general process is that I use rough micromesh or even sandpaper to remove material and shape the nib, then I use an ultra-fine Arkansas stone to re-shape, smoothen, and polish the nib. The rest of the equation is just practice and building technique.
Wow, the "hello Geekhack" in the first picture almost looks like it was typed out! Fountain pens have such cool line variation.
Very neat handwriting, too!
I think as a kid, I tried to play with my dad's fountain pen, but it just ended up scratching the paper without any ink coming out/ then started leaking. :(
Never touched a fountain pen since.
« Reply #51 on: Thu, 12 June 2014, 19:34:33 »
Today I tried my first Pelikan!!! It's a blue marbled, pre-'97, Pelikan M200. The weird part is that it's got this super fun vintage nib. It's a 14K music nib. :D
Terrpn where you at? I need to thank you!!
« Reply #52 on: Thu, 12 June 2014, 19:53:27 »
Anyone ever use a nib holder pen and India ink? I remember doing that "back in the day."
« Reply #53 on: Thu, 12 June 2014, 20:04:37 »
I haven't personally but I've seen some incredible handwriting from that. Check it out in this post on FPN.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #54 on: Thu, 12 June 2014, 20:34:40 »
not india ink, but dip pens............yebber-- all the time ;)
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #55 on: Thu, 12 June 2014, 20:36:17 »
nice handwriting there :thumb:
« Reply #56 on: Thu, 12 June 2014, 20:40:07 »
The Pelikan and it's nib makes my handwriting look way nicer than I think it is :3
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #57 on: Fri, 13 June 2014, 12:14:20 »
Thought you guys might like this one.
« Reply #58 on: Fri, 13 June 2014, 12:40:16 »
I'm tried a glass dip pen a few times..
I don't see a point to it really..   there's no real advantage to it in my opinion. the tip might be more durable, but what's the point..  it's pretty damn hard to wear tips out given proper use of fountain pens.
« Reply #59 on: Fri, 13 June 2014, 12:42:16 »
If you're trying to test a lot of inks at once, it's really easy to do so with a dip glass pen. Don't need to flush the pen every time.
« Reply #60 on: Fri, 13 June 2014, 19:21:41 »
test lots of inks.. hmm I must admit, I don't do comparisons, i just write with black and blue, so they're all pretty much the same....
most blacks are grey-ish, and most blues have black bits in them, some are genuine blue, but i find them too light..
Offline IonutZ
  • Stay awhile and listen
    • SC
« Reply #61 on: Sat, 14 June 2014, 12:11:03 »
Holy smokes Zeroblade... that super flex nib is super flexible :o
I collect fountain pens too... this is my favorite: )
Pelikan M640 Polar Lights edition with a 18ct white gold oblique bold nib.
Offline SL89
« Reply #62 on: Sat, 14 June 2014, 12:26:50 »
Has anyone taken a stab at making a demonstrator eyedropper from the body of a Lamy Vista Rollerball and the section / nib from a Lamy Vista?
I want to make the plunge, but i am hesitant because all the instructions and outcomes seem a little too good to be true!
I use a ton of red ink for work and refilling just seems tedious as does setting up an Ahab to write properly.
« Reply #63 on: Sat, 14 June 2014, 13:53:37 »
what type of work is this..  I've always found ball point and marker more convenient vs the restricted writing angle on fountain pens when it comes to "work".
« Reply #64 on: Sat, 14 June 2014, 13:56:52 »
I've seen a video of this, it seems pretty easy and failsafe. Actually, all the pen mods I've seen seem easy compared to keyboards.
Damn that is a fine looking pen. Could you do a writing sample of that OB Bold nib against something like a medium or broad?
Some of today's writing practice. Only because riot asked so nicely.
« Last Edit: Sat, 14 June 2014, 15:00:19 by CPTBadAss »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #65 on: Sat, 14 June 2014, 14:54:02 »
should work...........just on the safe side make sure there is some sort of o ring to screw down on or use silicone grease to make a seal. some people do this without grease or an o ring, crank down the barrel tightening down on the section and crack it :(
i do not own a lamy demonstrator roller and am not sure if there is a vent hole in the barrel?
if so once again just plug with some silicone and you should be fine
do you have an eye dropper or syringe to use to fill with with?
eye droppers are great and hold a TON of ink.
be careful filling demonstrators with exotic colors, even reds.............they will stain the plastic depending on the manufacturer
« Reply #66 on: Sat, 14 June 2014, 15:04:08 »
For the Lamy Safari eye dropper, you can do it two ways.
1) Swap in the rollerball barrel which doesn't have the ink window
2) Put epoxy on the ink window of the original fountain pen barrel
Offline longweight
  • philanthropist
« Reply #67 on: Sat, 14 June 2014, 15:27:14 »
I love writing with my fountain pen, I mix up the ink every refill and I rotate around 12 Mont Blanc inks.
« Reply #68 on: Sat, 14 June 2014, 15:30:12 »
Offline longweight
  • philanthropist
« Reply #70 on: Sat, 14 June 2014, 17:27:12 »
I really wish that I had 1/10th that skill, I write like a child.
« Reply #71 on: Sat, 14 June 2014, 18:34:49 »
this part i do not understand.. you buy all the gear.. do you not use them?  like those kids with expensive guitars who just shows it off, but never practice?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #72 on: Sat, 14 June 2014, 19:20:53 »
........but you do write ;D
Offline longweight
  • philanthropist
« Reply #73 on: Sun, 15 June 2014, 02:00:33 »
I use them all the time!
Offline Zeroblade
    • Twitter
« Reply #74 on: Sun, 15 June 2014, 06:53:41 »
Hahaha, I've got another which can flex up to about 3mm wide or so! I don't use it much though since it's an eyedropper-fill pen from around 1910, and it sometimes leaks a bit. I have some friends whose pens are just as flexible for so.
Before I seriously got into fountain pens, I also tried them as a kid - just ended up flicking the ink around like the kid I was LOL
The Polar Lights is really pretty! Though my favorite of Pelikan's Nature series is still the Niagra Falls.
68085-0
Speaking of Pelikan, I've had the good fortune to be able to play around with the special edition M800 in Tortoiseshell, with a rare triple-broad (BBB) nib, ground to a cursive italic. A friend of mine wanted me to tune it up and smoothen the nib even more. So in the meantime, I'll be enjoying it 'til he gets it back! (I wish he never does)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #75 on: Sun, 15 June 2014, 15:19:36 »
howz this cpt[badass]?
just a sampling of what i got.........
most of my better stuff is boxed and put away :cool:
« Reply #76 on: Sun, 15 June 2014, 15:24:35 »
That pen display...wow. I really like that Esterbrook display. And the M800 is lovely.
Offline IonutZ
    • SC
« Reply #77 on: Sun, 15 June 2014, 19:14:07 »
CPTBadAss here's a sample of my Fine nibs, I don't have any broad nibs :\
« Reply #78 on: Sun, 15 June 2014, 19:21:34 »
That's a lovely collection IonutZ. I tried a Meisterstuck 149 a couple weeks ago and I enjoyed it. Not sure if I'd be wiling to pay that price but I liked writing with it :). And I actually didn't like that Noodler's rollerball pen. I had two bad experiences with them and I think I'm over them.
Offline IonutZ
    • SC
« Reply #79 on: Mon, 16 June 2014, 10:10:39 »
Thank you sir! The Montblanc is definitely a nice piece, that was my graduation present from my parents. And since I'm a classical pianist, I thought the Chopin special edition was a nice touch haha. Yea I stopped using that rollerball... those things are really finicky on the type of ink you put in them.
Haha that was gonna be my next purchase I really like the M800 Tortoise shell... although... have you seen the Kyokko & Gekko limited edition?!!??!?!?
These things are to die for. $2k
« Reply #80 on: Mon, 16 June 2014, 10:12:08 »
I've been drooling over those Pelikan Raden pens since I discovered what Raden was....WHY WOULD YOU LINK IT AGAIN :( :P
That rollerball's wick feed keeps clogging on me....even when I use Noodler's inks. And that's a cool story about your MB :D.
Offline Altis
« Reply #81 on: Tue, 17 June 2014, 22:54:45 »
I don't even know why I hang out here with the money you all tempt me to spend. I mean, the keyboards are bad enough, but now this?
Well, I look forward to my first fountain pen (Pilot Metropolitan) and some sample inks. Thanks a lot!  :rolleyes: ;)
PS The Pilot Iroshizuku Yama-Guri (chestnut brown) looks like it will be very nice on off-white paper.
WhiteFox (Gateron Brown) -- Realforce 87U 45g -- Realforce 104UG (Hi Pro 45g) -- Realforce 108US 30g JIS -- HHKB Pro 2 -- IBM Model M ('90) -- IBM Model M SSK ('87) -- NMB RT-101 & RT-8255C+ (Hi-Tek Space Invaders) -- Chicony KB-5181 (Monterey Blue Alps) -- KPT-102 (KPT Alps) -- KUL ES-87 (62/65g Purple Zealios) -- CM QFR (MX Red) -- Apple Aluminum BT -- Realforce 23u Numpad -- Logitech K740 -- QSENN DT-35 -- Zenith Z-150 (Green Alps)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #82 on: Wed, 18 June 2014, 23:20:11 »
tryin to ruin you of course and make ya like the rest of us :eek:
« Reply #83 on: Fri, 20 June 2014, 05:56:12 »
You messed up your order. Where's the nice paper?! :P
And GH has led me to fountain pens and audiophile gear as well as keyboards :(.
Offline Altis
« Reply #84 on: Sun, 22 June 2014, 11:25:20 »
Fortunately, I already have ample audio stuff (home recording studio).
The thing is, with fountain pens, 8 keyboards, etc... people are going to start expecting me to produce some content soon :rolleyes:
Same with the recording stuff... 4 guitars, production studio, etc, and nothing gets made because I'm tied down with work these days.
« Reply #85 on: Sun, 22 June 2014, 13:08:16 »
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline osi
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #87 on: Sun, 22 June 2014, 15:01:16 »
yes.................. you win the prize :rolleyes:
« Reply #88 on: Sun, 22 June 2014, 15:19:13 »
I made some progress in learning how to write with my music nib! The F's look so good :D.
Offline BlueBär
« Reply #89 on: Sun, 22 June 2014, 15:26:11 »
There is an f in vabbects?
« Reply #90 on: Sun, 22 June 2014, 15:28:05 »
This isn't my Sütterlinschrift practice ok?? Palmer cursive. :(
Affects.
Offline BlueBär
« Reply #91 on: Sun, 22 June 2014, 15:39:54 »
Affects.
I'm just joking, looking good! :thumb:
That ink is quite nice! I'm such a boring person, I use black ink :-X
Offline IonutZ
    • SC
« Reply #92 on: Sun, 22 June 2014, 16:23:14 »
^hahaha what he said.
Vabbects
Offline Frenir
  • HHKB Viking
« Reply #93 on: Sun, 22 June 2014, 16:33:57 »
Needs more hidden Illuminati symbols.
Offline BlueBär
« Reply #94 on: Sun, 22 June 2014, 16:56:42 »
You must be joking:
68744-0
« Reply #95 on: Sun, 22 June 2014, 17:38:21 »
Offline Frenir
  • HHKB Viking
« Reply #96 on: Sun, 22 June 2014, 17:41:30 »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #97 on: Sun, 22 June 2014, 18:04:36 »
nice...........
« Reply #98 on: Sun, 22 June 2014, 19:06:18 »
head of the illuminati should know how to triangle, c'mon guys...
Offline Melvang
« Reply #99 on: Mon, 23 June 2014, 04:26:34 »
Or at least ambigram
