Author Topic: DIY Laptop Keyboard LED's  (Read 6003 times)
Offline jy334769
« on: Tue, 02 April 2019, 13:20:06 »
Hi'all
I need some advice to create backlit LED's for my laptop keyboard. Bit hard to type in the dark. It's for a Lenovo E530. I was thinking trying to install LED strips and make small little holes on the keys.
Have any of you done this before and how did you link it to the power?
Offline Sup
Re: DIY Laptop Keyboard LED's
« Reply #1 on: Tue, 02 April 2019, 13:25:23 »
Nah that mod is not gonna work and not worth the hassle. Isn't there a backlight replacement keyboard you can't buy and replace it with that?
current
Coming soon
Offline Leslieann
« Reply #2 on: Tue, 02 April 2019, 20:47:22 »
Unless you have the right equipment and by equipment I mean a cnc mill and and injection molding system and the experience to use it, this will not work. More importantly, there's no reason to, what you want already exists... Almost.
My advice,start with a backlit X230 or T530 keyboard, and adapt the backlight wiring.
The keyboard is pretty much the same, probably a direct swap (probably!) however I'm not sure if the motherboard has the proper connections for the backlight. Keep in mind, keyboard backlighting is going to match cpu and display power draw, if not exceed those. You're system at idle is probably 12 watts, the keyboard will suck down around 5 more. This was something people never gave the Thinklight enough credit for, since it only used one LED as opposed to 100. The Thinklight, also may be possible to adapt.
A better option, though more expensive, if you want to keep what you have, is buy a used T540 with backlight lower half. Your cpu, ram, screen, drives, etc... will all bolt right on. You will get backlighting, a better case, more ports... It's a small upgrade that gets you what you want in a bolt on fashion. Better yet, get a T540 base and cpu and install your parts, you can get a damaged T540 for $60, which is about what you will spend on the backlit keyboard alone.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline ErgoMacros
« Reply #3 on: Tue, 02 April 2019, 22:08:56 »
Cheaper and easier yet... a usb powered light. Here's 3 from Amazon for $8:
  https://www.amazon.com/Flexible-USB-Light-Keyboard-Portable/dp/B0191S9I4K/
adjust the brightness with electrical tape. ;-)
Today's quote: '...“but then the customer successfully broke that.”
« Reply #4 on: Wed, 03 April 2019, 08:05:33 »
For the labor involved, you can take that time, wurk @ mcdonald ,  and buy a newer laptop WITH backlit keybard.
