Author Topic: [solved] How to fix my PCB?  (Read 3441 times)
Offline Jahakob
« on: Wed, 10 April 2019, 12:46:34 »
Today I desoldered my Vortex Race 3 to get rid of the MX blues it came with.
When I soldered in the new switches I noticed 2 key right next to each other stopped working. (LD26 & LD27)
While I was troubleshooting I noticed that the two left connectors to the pin might somehow be at fault. (marked green in the second image), since I can bridge the right ones to create a keystroke but not the left ones.
The Diodes seem ok to me. But I am out of ideas at this point, what the problem is. Please help me :)
« Last Edit: Wed, 10 April 2019, 17:36:23 by Jahakob »
Online tp4tissue
Re: How to fix my PCB?
« Reply #1 on: Wed, 10 April 2019, 13:07:17 »
measure between the 2 green circled,   if they're connected, then bridge either one to any ground with wire.
Then short the connection see if they work.
Offline Jahakob
« Reply #2 on: Wed, 10 April 2019, 13:26:39 »
Thanks for the quick answer! I am not sure tho, where a ground pin would be on this keyboard.
Offline Jahakob
« Reply #3 on: Wed, 10 April 2019, 13:51:30 »
I tried connecting it to a led ground pin. That didn't seem to do the trick. The two are definitley connected tho, according to my multimeter.
Online tp4tissue
« Reply #4 on: Wed, 10 April 2019, 16:16:44 »
/Head scratch
When you said you can bridge the -Right ones- to create a keystroke, what did you mean by that, where did you bridge to
Offline Jahakob
« Reply #5 on: Wed, 10 April 2019, 17:35:23 »
/Head scratch
I did it now. I desoldered everything to look at it from the front. From there I could check all the connections of the solder points. I used the multimeter to identify the faulty one, which i bridged as you said. Thank you for your help!
