Author Topic: CE/1 CAD Macropad  (Read 2089 times)
Offline ChaoticEngineering
CE/1 CAD Macropad
« on: Mon, 06 May 2019, 19:29:08 »
Heyo, just wanted to get some criticism on a little project I am working on. This is a macro pad designed solely for CAD workflow, but I imagine anyone could use it for gaming or any other sort of workflow that would benefit from a programmable external device.
Offline nguyenhimself
Re: CE/1 CAD Macropad
« Reply #1 on: Mon, 06 May 2019, 22:38:57 »
I mean, it's half of an Ergodox. I doubt anyone can give you serious critics here as split keyboard is not that rare of a thing these days.
Sure, if you have a need for it, go for it.
« Reply #2 on: Tue, 07 May 2019, 00:05:16 »
IMHO, left side  column should be left alone , if more keys are needed TOP rows could be added.
The reason is tented, You want the left side to drop as low as possible.
There's no reason to make only 1 side.
The thumb cluster is fine as is,  But to address some of the newbies, a closer thumb button should exist between that current blank space.
