Author Topic: How often can you desolder and resolder a board/pcb?  (Read 5582 times)
Offline DuckNorris
« on: Thu, 29 August 2019, 13:15:20 »
Hey guys I know a lot of custom build kits are not really hot swap so you ofc need to desolder switches if you want to change them. I am not too familiar with this but say if done right, is there really a risk if one desolder and solders a board more than once?
Just like worried of something happening if I buy a used custom board and fry something and got no replacement parts  :eek:
Offline wholypantalones
  • text and icon mods plz.
Re: How often can you desolder and resolder a board/pcb?
« Reply #1 on: Thu, 29 August 2019, 13:22:32 »
I'm up to three times desoldering a TX87KIN L3 pcb, then I stuck mil max sockets in it and use it in a CLS.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Thu, 29 August 2019, 13:49:52 »
All depending on your soldering skills, after 2 desolder and resolder I've ruined 2 sockets, and then I had to ghetto fix it.  So it works perfectly fine for now but it will not allow future desolder anymore.
So if you think you'll be installing/removing all switches a few times it's best to buy a keyboard that support quick swap.
That being said, usually there's always a fix it's just I'm not skilled enough to fix the broken socket properly.  If you're only going to do it 1 more time it should be ok.  But then it also depends on how many times the previous owner swapped his switches.
Offline shansoft
« Reply #3 on: Thu, 29 August 2019, 17:23:03 »
If you are using desoldering gun, then it can pretty much last as long as you want.
If not, then 1-2 desoldering probably will screw up the plate.
Hence why I usually buy multiple PCB just to be cautious.
Now I much prefer hotswap PCB due to this very reason.  ;D
Offline _rubik
« Reply #4 on: Thu, 29 August 2019, 17:34:15 »
Never if I can help it.
That said, I'm perfectly comfortable the first time round. I'll hesitate the second time, but have never run into a problem. Going three or beyond is asking for trouble unless you have the proper tools.
Offline Sup
« Reply #5 on: Thu, 29 August 2019, 19:18:02 »
So long you use flux paste i don't think there can go much wrong i think i desolderd my AEK64 like 3 times once. No difference after the first desoldering.
« Last Edit: Thu, 29 August 2019, 19:26:33 by Sup »
current
Coming soon
Offline DuckNorris
« Reply #6 on: Fri, 30 August 2019, 10:33:20 »
Thank you guys and in this post you also gave me recommendations for soldering tools  :)
I will keep this in mind but also sadly many times for old keyboard kits there is only one PCB so will give me more confidence in purchasing a used keyboard
« Reply #7 on: Fri, 30 August 2019, 11:07:46 »
Even with good technique,  It comes down to what the lacquer is designed for..
Very budget boards are more/less solder once.  On these boards, even if you're good/fast, the lacquer will just melt, and the traces become unreliable.
Offline tedfs3
    • No Mercy Given
« Reply #8 on: Mon, 02 September 2019, 03:41:35 »
I was wondering this myself as I'd really like to desolder a board and use my own switches and have the benefit of keeping the case.
