Author Topic: Gekha Bloodpressure thread.  (Read 4779 times)
« on: Sat, 08 February 2020, 13:48:10 »
Tp4 Getn' OL'
Costco had the arm-Cuff type blood pressure monitor on sale today.
Took some readn's aff getting hom
Avg over 30 runs , 119/ 75
<yes,  sat there for an hour and a half 15 readings on each arm, very numb arms>
A Dog barked outside on 1 run,  got 153/98
Offline absyrd
  • CPT HYPE PADAWAN
Re: Gekha Bloodpressure thread.
« Reply #1 on: Sat, 08 February 2020, 14:22:37 »
110/85 at the doc the other day. Usually I get white-coat bp and can spike up to 140/105. I ****ing hate PCP offices.
« Reply #2 on: Sat, 08 February 2020, 18:35:57 »
I run about 140/95
Sent from my SM-G970U1 using Tapatalk
« Reply #3 on: Sat, 08 February 2020, 19:19:58 »
Haven't been to a doc in like... 7 years?
« Reply #4 on: Sat, 08 February 2020, 19:22:02 »
This explains that bile problem. kekekeke
« Reply #5 on: Sat, 08 February 2020, 19:46:57 »
or this growing hole on me leaking foul black liquid, rotting all the flesh around it as it grows slightly larger each couple of months
Offline Kavik
« Reply #6 on: Sun, 09 February 2020, 01:04:34 »
Four readings on my home BP machine were as follows:
121/72
129/71
125/71
131/72
Pulse was 50-51 bpm each time (although my Fitbit showed 55-57).
My systolic is usually a bit above "normal", and my diastolic is usually below "normal". The problem I have is that, when my blood pressure is at or below "normal" (120/80), I tend to experience lightheadedness upon standing. When I've been fat with higher blood pressure, this didn't happen. I suppose smooth, flexible arteries are worth the possibility of fainting.
An interesting phenomenon after coming to from lightheadedness is a sense of hyper-reality (no idea what to call it) and visual clarity. It's as if things seem more real and edges of objects seem more defined. Odd feeling.
« Reply #7 on: Sun, 09 February 2020, 09:54:52 »
Had my BP taken often late last year, must have been normal as no comment was made.  I've have had similar experiences to Kavik, the light-headedness lead to me falling over unconscious a handful of times but lately it's not been that extreme.  The 'sharpened' vision is indeed strange.
Offline JP
« Reply #8 on: Mon, 10 February 2020, 10:48:31 »
Damnit, why am I seeing this thread after having my blood pressure checked...not good. 148/88. Never ever seen it this high and have it checked once a year. Maybe didn't help having that stiff cup of coffee before the test and a horrible diet recently coupled with work stress and a lack of sleep...
Alright gonna eat veggies, cut back on sodium and caffeine for a few days and have it checked again.
« Last Edit: Mon, 10 February 2020, 11:17:17 by JP »
About Me | The Collection
« Reply #9 on: Mon, 10 February 2020, 13:08:20 »
Coffee before a doc visit always renders off results. You should be fine... hopefully.
« Reply #10 on: Mon, 10 February 2020, 14:09:05 »
But are we SURE that it's Not Loopus.
Offline Kavik
« Reply #11 on: Mon, 10 February 2020, 16:00:32 »
I'm glad I'm not the only one. I've never heard anyone else describe this before.
The light-headedness lead to me falling over unconscious a handful of times but lately it's not been that extreme.
I've only "fully" passed out once many years ago, but I frequently have to brace myself against a wall or take a knee while my legs (and sometimes whole body) do a jello twitch thing and my vision is occluded by dark ink blots.
Offline Kavik
« Reply #12 on: Sat, 28 March 2020, 14:32:28 »
After having been transported to another dimension when standing up two or three times today, I took my blood pressure. My systolic has dropped a bit since last month.
Three readings taken about 1-2 minutes apart were: 114/83, 117/72, and 107/61 (focused on breathing to slow my heart rate a bit on the last one). I guess these are healthier numbers than last time, but worse in terms of staying conscious. Pulse was 83, 72, and 63 respectively. That's a bit high for me, probably because I had to get up to get the machine. My normal resting heart rate is between 40-60, so maybe my real resting BP is even lower.
« Last Edit: Sat, 28 March 2020, 14:34:26 by Kavik »
« Reply #13 on: Sat, 28 March 2020, 18:19:46 »
Sounds gud', you shall live many years.
Offline phinix
« Reply #14 on: Mon, 30 March 2020, 14:30:34 »
Sounds like you have good bp tp.
Mine is in average 175/119.
So yeah, I'm a f**ing ticking bomb... :(
After few weeks my doc decided in her infinite wisdom, that I need meds for this.. so she gave me the weakest ones you can get...
I'll see how better it gets in next few weeks.
« Reply #15 on: Mon, 30 March 2020, 16:31:00 »
The PlantBased community has near 100% success rate in this area.
LOW-Fats is key.  around 10-15% of daily calories max, ~22g of fats. <counting everything you eat,  avocados/cooking oil/ tofu/ etc>
The way keto-fad papers have gamed their studies is by using people who are consuming nearly 30% calories from fat. so 30% vs 40% vs 50% calories from fat, makes zero difference in blood pressure. Their conclusion, fats make no difference in BP. They cheat gud'
