Author Topic: Quick! Talk me out of this keyboard and recommend something else!  (Read 3229 times)
Offline absyrd
  • CPT HYPE PADAWAN
Offline gipetto
Re: Quick! Talk me out of this keyboard and recommend something else!
« Reply #1 on: Wed, 12 February 2020, 20:13:23 »
no qmk support.
Offline Mr.Elli0t
« Reply #2 on: Wed, 12 February 2020, 20:20:28 »
https://drop.com/mechanical-keyboards/drops
If you want a tkl go with the CTRL if you are okay with a 65% go with the ALT, both have hotswap PCBs, which will let you experiment with different switches.
Sent from my Pixel 4 XL using Tapatalk
Offline rxc92
« Reply #3 on: Wed, 12 February 2020, 20:22:20 »
It's not using Cherry switches but still costs $100 with only basic RGB as its defining feature.
You can get a $50 keyboard generic Chinese board with the exact same quality and switches. If the money isn't a big deal then just buy something more expensive and better.
Offline Maledicted
« Reply #4 on: Thu, 13 February 2020, 21:07:19 »
^ and it isn't a hot-swap board, and the cable isn't removable, and the caps are lasered ABS. Pretty poor value for the price.
« Reply #5 on: Fri, 14 February 2020, 01:11:06 »
I think it looks ugly and thick. Get a Leopold!
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Just my thoughts
Offline Mr.Elli0t
« Reply #8 on: Fri, 14 February 2020, 09:02:06 »
https://www.amazon.com/dp/B07N4D7PMJ/?coliid=I3HWELEKHBM5RL&colid=CSJH9160G943&psc=1&ref_=lv_ov_lig_dp_it
context?
You could argue that there are better options like the glorious gmmk or gergo
Nice call on the GMMK, I completely forgot about that one as a good starting point, with RGB lighting and hotswap PCB.
Offline Maledicted
« Reply #9 on: Fri, 14 February 2020, 09:57:20 »
It's not an Ergodox =  No Buy
Tp4 recommends
ERGODOX.
I could have grabbed one of those for a song (comparatively) on an auction website not too long ago. The only ergo keyboard I have ever tried is the old beige M$ ones. I didn't mind it, but I didn't particularly like it either. I owned at least one for years. I might, still, maybe. I can't say I used it more than once, just to see what it was like.
