Author Topic: You can tell right away  (Read 5060 times)
« on: Sun, 21 June 2020, 16:34:43 »
That this is the villain in the story.
Cuz he touches the CD's optical surface with his bare hands, only a despicable person would do such a thing..
245468-0
Offline phinix
Re: You can tell right away
« Reply #1 on: Sun, 21 June 2020, 17:57:43 »
Outrageous...
Offline chale_moore
« Reply #2 on: Mon, 22 June 2020, 07:31:59 »
Villain always does wrong things, I think this is a powerful villain and deliberately touching the cd player with bare hands.
Offline yui
« Reply #3 on: Mon, 22 June 2020, 07:47:32 »
to be fair with him, the chances of damaging the cd doing that is very low, but still, you do not do that.
Offline funkmon
« Reply #4 on: Tue, 23 June 2020, 02:22:15 »
Guys. I store CD and DVDs loose on top of the Xbox.
Hate me. They all still work.
« Reply #5 on: Tue, 23 June 2020, 04:48:35 »
It's not as if his appearance isn't villanesque. Only villains and their lawyers (which are also villains) wear that kind of hair style. And the eyes should also be a tell.
Offline Leslieann
« Reply #6 on: Tue, 23 June 2020, 05:28:52 »
This...
I used to throw them across rooms and bounce them off brick walls like frisbees just to freak out people who were scared to touch them.
How you damage it matters, not how much.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #7 on: Tue, 23 June 2020, 05:40:11 »
The eyes.
« Reply #8 on: Tue, 23 June 2020, 07:57:51 »
This...
Tp4 Hyperventilates..  //Criminals..
Offline yui
« Reply #9 on: Wed, 24 June 2020, 00:57:31 »
This...
well to be fair i did play Frisbee with failed burns but not with working ones, but not with working one because even though they may still work it may look much uglier and be harder to read to some players
Offline funkmon
« Reply #10 on: Wed, 24 June 2020, 02:14:47 »
I tried to Frisbee many times with CDs, but I don't think they fly well enough. They're not stable.
Offline Leslieann
« Reply #11 on: Wed, 24 June 2020, 04:20:02 »
It helps when it's a rage throw.
In the early days of burners the disks were expensive and failed often, you got lots of practice using lots of anger.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline phinix
« Reply #12 on: Wed, 24 June 2020, 04:54:43 »
good old times:)
I remember 100s of CDs ending in a bin. Til they came up with buffer!
Offline yui
« Reply #13 on: Wed, 24 June 2020, 05:35:55 »
good old times:)
i remember failing quite a lot of dvd and CD when burning at full speed but i had no idea that the buffer was made to help with that, i was too late into that game to ever see a buffer less burner, interesting.
Offline funkmon
« Reply #14 on: Wed, 24 June 2020, 07:24:29 »
Oh yeah dude. We always had to burn em at 2x or lower to make sure it went okay. As in less than 20% failure rate.
Man that first CD I burned and played in a discman though. Amazing. Blew my mind. It had Metallica AND Ted Nugent on it.
« Reply #15 on: Wed, 24 June 2020, 08:03:17 »
Tp4 first burn were Br00dwars.
Offline yui
« Reply #16 on: Wed, 24 June 2020, 08:38:48 »
on my 1st burner i had to run it at 4x max else it was a guaranteed fail and i already found that slow, 2x must have been a pain, that is a part of that era i do not miss for sure :)
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #17 on: Wed, 01 July 2020, 09:32:27 »
He also puts smash brawl the wrong way
Just my thoughts
