Author Topic: Gakk, the Oil  (Read 3377 times)
Gakk, the Oil
« on: Thu, 25 June 2020, 16:28:41 »
Buddy called Tp4 w/ new recipe.
You take pillsbury crescent roll dough.  Make 4 quarter rolls. DEEP FRY.
That's it, that's the whole recipe. Lightly dip in soysauce. UNREAL taste..  Extremely greasy..  Probably gonna have a heart attack or a stroke later tonight..
Tp4 8 all four rolls. irresistible.   Can always blame the pandemic..
Re: Gakk, the Oil
« Reply #1 on: Thu, 25 June 2020, 17:06:22 »
Have all this left over oil.
Did up some homemade Chive/Spinach-Dumplings..
De'Key 2 depfry dumplings is to get it just slightly before golden brown, it will turn golden brown once you take um out.
Then, ya don't eat them right away, you wait a little bit ~5 minutes for the crust to soften slightly, and the internal Chive-Juices to re-infuse with the inner skin..
245772-0
Offline absyrd
  • CPT HYPE PADAWAN
Re: Gakk, the Oil
« Reply #2 on: Fri, 26 June 2020, 06:11:28 »
The spinach makes them healthy. GJ
Re: Gakk, the Oil
« Reply #3 on: Fri, 26 June 2020, 09:36:03 »
Totes cancels out the depfryn'  < what we tell ourselves >
Offline yui
Re: Gakk, the Oil
« Reply #4 on: Mon, 29 June 2020, 02:49:24 »
chive spinach dumplings, now you are speaking my language :)
would you post the recipe? looks and sounds very tasty.
Re: Gakk, the Oil
« Reply #5 on: Mon, 29 June 2020, 03:59:20 »
Needs some cheese. Everything is improved through the power of cheese.
Offline yui
Re: Gakk, the Oil
« Reply #6 on: Mon, 29 June 2020, 04:38:54 »
shhh, do not say that here :) you put the cheese after we get the recipe :)
