Author Topic: When the p0wr goes out.  (Read 3661 times)
« on: Thu, 03 September 2020, 15:57:05 »
First thing ya do is Check the status of your Local n00qular reactors Within 600 Miles radius, on you fones.
For example,  Turkey Point (florida),  Earlier this year, maintenance workers were fired for Falsifying records.
THEN, most recently 3 seperate unplanned reactor shutdowns over 3 days in 1 month..  What's happening,  Corona ? Workers on furlough ? Skeleton Krew ?   WHO KNOWS..  The people in charge lied about every single n00qular disaster EVER, regardless of country.
Anyone living near this stuff, surprise, it's pretty much everyone, Vigilant mode activo.
Re: When the p0wr goes out.
« Reply #1 on: Thu, 03 September 2020, 16:08:51 »
Live near a hospital your power will never go out. At least until the hospital grid goes down, in which case start worrying.
« Reply #2 on: Thu, 03 September 2020, 16:10:16 »
Well, wouldn't wanna be near hospitals when dem' zombie/plague waves start.
Gotta be @ high elevation, natural barrier, low humidity.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #3 on: Thu, 03 September 2020, 20:45:00 »
Power outages suck
Just my thoughts
Offline jamster
« Reply #4 on: Thu, 03 September 2020, 20:53:08 »
How often do you guys in the US see power problems? Computer forums are full of UPS and surge protector advice.
I've personally experienced zero home outages in 15 years out here. I've seen the lights flicker less than five times. My parents' place in Australia has had one in the same period (which lasted a couple of days because of record storm damage).
I encounter power problems via work all the time, but these are almost always localised to single sites and not grid problems.
« Last Edit: Thu, 03 September 2020, 20:54:48 by jamster »
« Reply #5 on: Thu, 03 September 2020, 21:05:35 »
Power outages suck
This is why every home needs a piano. It's like a video game. but analog.
Offline yui
« Reply #6 on: Fri, 04 September 2020, 03:25:19 »
tbh i would rather be near a nuclear reactor than a coal power plant if something goes wrong, modern nuclear has so many more security feature and it too a high magnitude earthquake and a tsunami to make the last one fail. there is far more death and damage done by coal plants than nuclear ones, and well nuclear still is not clean but far cleaner than coal. (and no do not bring solar or water, if we replace nuclear now the only mature tech we have is coal, not saying that renewable will not happen, just not now)
and really if something were to go really wrong in either case you would not need to phone them to know
« Reply #7 on: Fri, 04 September 2020, 06:00:47 »
None of that is true.  N00q plants output tritium. unseen, almost impossible to filter cost effectively.
Germany decided to shut down all their reactors upon studying its effects by drawing concentric Rings around power plants, and noticing that Childhood leukemia correlated perfectly with living distance to plant.
In terms of Environmental impact,  Nooq Reactors are cleaner than coal while IN the power plant. However the mining / Transport of the nooq fuel ultimately makes n00q power only ~6% cleaner than Coal-Fire. Yet the opportunity cost is huge vs Wind and solar, because we can build capacity much faster. N00qs are notoriously cost over run,  and they are Economically NET NEGATIVE.
Then there's the Nooqular waste,  NO TECHNOLOGY exists to Deal with this.
Nooq plants are also Economically net negative.  They produce the most-expensive electricity of all known power sources, Ontop of a waste product which COSTS money indefinitely to oversight and store.   Contrary to popular belief, burying nooq waste is NOT a good solution If there is ever a leak/ earth quake etc, you immediately end up with massive unusable land that is nearly permanently contaminated ~300,000 years.
Renewables IS happening now. Fastest driver is WIND p0wr, truly clean, low maintenance, Fast to build, Thoroughly mature technology.  We can build 10x the megawatt wind capacity in the same time it takes to construct 1 n00q plant.
Each plant is also a ~600Billion to 2Trillion Dollar liability.   Jpn is facing that right now. NON STOP COSTS  in case of disaster.  Nature is relentless, and you can never be safe. Jpn is also now incurring the human cost of ~3,000 years of radiation assault @ the genetic lvl. Massive rise in cancer/ depression.
It's virtually impossible to truly decontaminate.
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #8 on: Fri, 04 September 2020, 13:55:48 »
We could always fund a private waste disposal space program that launches the tons of spend nuclear fuel into Jupiter.
So, don’t say there is no way to deal with it, the way is just too expensive. Like most great things in life.
« Reply #9 on: Fri, 04 September 2020, 15:33:36 »
When you get a power outage, it is almost never because of a deficiency in total energy production.
It is almost always because someone between the producer and you has been cutting corners and not provided enough infrastructure or operator training.
Offline Darthbaggins
  • PC Cannibal
« Reply #10 on: Sat, 05 September 2020, 07:42:25 »
only "blips" in power we've had are do to mother nature playing target practice with her natural electricity.  Also since my gear is on a 2300w UPS, I tend to not notice when the power goes out or blips on and off.
Offline yui
« Reply #11 on: Mon, 07 September 2020, 01:19:56 »
while technically true it is in very low quantity, i dunno if you know of a gas called radon that is produced in some very populated part of the world naturally and unlike tritium it can decompose into radioactive metal in the lungs and is overall far more radioactive and is produced in much larger quantities
given the timing i have doubt about that but officials will need a reason to look better.
well true that 1kg of uranium will pollute more to extract and to refine than 1kg of coal, overall your kg of uranium will last 20 to 30 years. while your kg of coal will last all of about 1 minute, and well maybe in the US a company can live of making negative profit but that is not the case everywhere, and either way we need them for their inertia, it is why i said renewable are out of the question at the moment renewable do not have inertia or are very location dependent.
well we do have technologies just cost more than making big holes to bury it
Nuclear power is not net negative outside of the US i dunno about the US seems pretty stupid to keep buying them is they only ever cost money but hey you got trump, repeating the same point does not make it more true, and yes nuclear waste are a cost, and yes i agree that burying it is not the solution but we can predict where there is chances of having earthquakes so that is not a huge problem and if buried deep enough the leakage radiation would be lower than ambient.
truly clean, false, the very large amount of steel needed is a large pollution, and they need to be replaced every 5 years or so, and your storage infrastructure will be a large pollution too, as wind does not produce at night and does have 0 inertia for when something goes wrong.
well it was known that building them in japan of all places was a bad idea, no other country built reactors in seismically active zones for a reason, we all knew it would happen but then maybe japan thought that after 2 nukes nuclear could not affect them anymore.
that part is true. it is why it took 2 major natural disasters to make one out of 4 reactor fail, because there are tons of fail-safes in place for that not to happen, there are from ourworldindata there is about 300 times more death per year from coal than nuclear, because coal feel safer so not fail-safes in places.
