Author Topic: Been playn' all week.  (Read 2688 times)
« on: Fri, 04 December 2020, 09:48:16 »
Personal Best.. Finally broke 1 Milpuntos..
The trick is to ignore tetris.
- Turn music in game setting to off
- Make sure battery voltage is High, otherwise there's input lag at high levels.
- Lubricate d-pad for improved input precision.
- Don't count on T-spin @ highs levels
Tetris DX iz bes tetris on gameboy.
- Faster movement
- Softlock
- Color coded blocks
257031-0
Offline Shapey Fiend
Re: Been playn' all week.
« Reply #1 on: Fri, 04 December 2020, 10:41:25 »
I could do 154 lines on Original Gameboy Tetris. This probably doesn't mean much anymore but I was competing with a friend for weeks and I felt it was so significant I can still remember 30 years later.
« Reply #3 on: Fri, 04 December 2020, 10:50:28 »
I was just reading up on the world record holder there (400+ lines) he says the game it's one of the few Tetris games where the pieces are totally randomised so it's a very luck based thing to try get records on.
« Reply #4 on: Fri, 04 December 2020, 10:58:21 »
My son doesn't like Tetris but he's completely hooked on Mega Drive Columns for some reason.
« Reply #5 on: Fri, 04 December 2020, 11:01:54 »
Were there other rules? start at lvl 0 or lvl 9
/respect Shapey, your record remains unbroken.
You should try playing now with Adult-Level Processing power.
257039-0
« Reply #6 on: Fri, 04 December 2020, 15:37:13 »
Tetris DMG Gameboy is definitely harder to control, you have to start pressing before the piece even draws to get it to the corners later on.
« Reply #7 on: Fri, 04 December 2020, 16:44:39 »
Damn that was quick.
Uhh the world record peeps start at lvl9 cos you can get a higher score that way but I don't think there's any rule that you have to.
« Reply #8 on: Fri, 04 December 2020, 17:36:45 »
You'd be surprised how much guder' you are as an adult, time to go dig out your ol' DMG,  pre-Covid Nostalgia.
« Reply #9 on: Fri, 04 December 2020, 19:09:00 »
used to beat Tetris DX all the time and get the rocket shop at the end that drops Tetris bits onto Earth with a bunch of fireworks for every subsequent score tier.
I suck now but I used to be a monster in my super autistic teens when I had all the time in the world to perfect my games.
