Author Topic: How to Fix Keyboard Not Working Issue on Laptop?  (Read 1743 times)
Offline aadesh24
« on: Fri, 08 January 2021, 04:31:14 »
Hi all,
I am facing some issues with my keyboard. My keyboard is not working properly. Please help me.
Offline yui
Re: How to Fix Keyboard Not Working Issue on Laptop?
« Reply #1 on: Fri, 08 January 2021, 04:43:10 »
Hi all,
hello, we will need a lot more information to help you, the bare minimum would be:
1- what the problem is
2- what model keyboard
3- if the problem is physical and you need help fixing it, photos of the problem
and any extra information related to the problem can only help give better advice at the moment no one can help you with the only information being "i have a keyboard problem"
in the hope of being able to help you eventually
