Author Topic: [IC] SA Crimson Wither Base + Artisanal + Deskmat by Captus Keycaps  (Read 13930 times)
Offline CaptusKeys
    • Captus Keycaps
Mimicking the symbiosis of flesh and bone, the base set is sure to give you shivers.
We set out a goal to manufacture each keycap with a unique gradient accomplished via thermal sublimation of PBT plastic.
Inspired by various aesthetics, the set was designed to be something that hasn't been done before.
The release features two sets: A base set with ANSI, ISO, numpad, extra spacebars, and a corresponding aluminum novelty keycap
with a special electroplated gradient hue, which will also be available separately. We decided to go with the SA profile, as it's a smooth,
robust, rounded profile, perfect for the vision of meshing gradients we set out for this release.
Kit Renders
Rama U80-A
KeliumWorks Pillow65
Artisanal (anodized aluminum)
Desk mat
Colors:
cmyk(0,92,73,11)
cmyk(0,2,11,3)
Note: Pantone colors are not provided, because manufacturing will be done with dye-sublimation printing (otherwise known as thermal sublimation).
About us:
We are a small company composed of keyboard enthusiasts and folks who work in industrial design.
Our goal is to experiment with various manufacturing techniques on different types of Aluminium, PBT/ABS plastic sublimation and dyeing procedures in order to bring unique,
one-of-a-kind keycap ideas to life. The brand aesthetic we are looking to build is of functionality, minimalism and designs narrated by a strong foundation of thought and story.
Collaborations:
If you're interested in collaborating with us, feel free to get in contact via our discord or company email.
Vendors:
TBA, but most likely your usual ones
Pricing:
TBA
Interest Check Form:
https://forms.gle/5VXxwtvY9LqdeC4Q8
Socials for updates and announcements:
Instagram: https://www.instagram.com/captuskeycaps
LinkTree: https://linktr.ee/captuskeycaps
Discord Server:
FAQ:
TBA
Timeline/Change Log
Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=110920.0][img width=640 height=254]https://static1.squarespace.com/static/5fc53c24a879396864249228/t/601440ae22b516037d868a06/1611940019034/geekhackbannerwither-01+copy.png[/img][/url]
If you're interested in our projects and would like to support our products, please consider displaying our signature on your profile! Cheers
« Last Edit: Fri, 29 January 2021, 12:05:13 by CaptusKeys »
Offline of_sam
Re: [IC] SA Crimson Wither Base + Artisanal + Deskmat by Captus Keycaps
« Reply #1 on: Fri, 29 January 2021, 11:20:31 »
Are you going to keep spamming bad sets?
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline CaptusKeys
    • Captus Keycaps
« Reply #2 on: Fri, 29 January 2021, 11:24:10 »
We are sorry that you don't like it, we are actively working to create new designs, that I am sure you will love!
Offline iinko_mk
  • Status: broke
« Reply #3 on: Fri, 29 January 2021, 11:27:56 »
please don't rush out set's like this, there wasn't much thought put into this one right? cus those gradients on each of those caps will be next to impossible
Offline CaptusKeys
    • Captus Keycaps
« Reply #4 on: Fri, 29 January 2021, 11:36:19 »
We use 5-side sublimation, we have talked with our specialist partner and they said it is possible to make!
Offline S61
« Reply #5 on: Fri, 29 January 2021, 11:45:32 »
cooool ramp red color~~~~
Offline powwu
    • Discord
« Reply #6 on: Fri, 29 January 2021, 12:24:42 »
This is a shame. These colors would be pretty nice if the gradient wasn't next to impossible to create.
What's with the font? I would much rather prefer ye olde SA font over this.
The base kit is too small. Look at any other base kit for the keys you should have at the very least. Good luck though, adding more keys would bring the price from 6 figures to 6 figures and 20 dollars.
Offline Vegas_
« Reply #7 on: Fri, 29 January 2021, 12:38:37 »
this is an extremely novel concept & I'm super intrigued to see how it works out! individual gradients on each key is unheard of, but with in-house manufacturing it may just be possible! QC is something a little concerning to me though..
would be interested to see some prototypes as a proof of concept! i think this is a very unique idea and i wish you the best of luck with it :thumb:
Offline CaptusKeys
    • Captus Keycaps
« Reply #8 on: Fri, 29 January 2021, 12:41:04 »
Thank you! We are working on prototypes to prove that it can be done, it will be posted as soon as we get it!
Offline CaptusKeys
    • Captus Keycaps
« Reply #9 on: Fri, 29 January 2021, 12:41:46 »
Thank you for the feedback! We are going to make some renders and post them as a new IC if they come out good!
Offline Vala
  • :smork:
    • Vala Supply
« Reply #10 on: Fri, 29 January 2021, 12:45:15 »
Seriously? This is a "bad set"? They come with a new innovative style and for some reason people can only think of negative things to say...
I personally think this looks ****in' awesome. Good job Captus team, and thanks for bringing something new to the table. Looking forward to seeing how the prototypes turn out.
How do you know it is impossible? This seems completely reasonable with the known capabilities of dye sub.
Offline Xonuss
« Reply #11 on: Fri, 29 January 2021, 13:32:39 »
This set looks amazing. If the gradient is achievable and QC is good, I'd definitely be in.
Offline kajahtaa
« Reply #12 on: Fri, 29 January 2021, 13:36:39 »
Maybe KAM would make more sense?
I like the look.
Offline fireworm
« Reply #13 on: Fri, 29 January 2021, 13:38:43 »
I think I'd love to buy a dyesub artisan with that fade.
I don't quite like the whole set...
Offline Havattack
« Reply #14 on: Fri, 29 January 2021, 14:04:16 »
Might just be me, but i think "pink wither" might of been a more accurate name.
« Last Edit: Sat, 30 January 2021, 15:14:24 by Havattack »
Offline kw88
« Reply #15 on: Fri, 29 January 2021, 15:30:47 »
very nice  :thumb:
no
Offline Shironome
« Reply #16 on: Fri, 29 January 2021, 15:40:35 »
I think the gradient is pretty cool... but who is going to manu these?
edit: I'm stupid realized that you're manu. I'm now curious about the qc on this.
« Last Edit: Fri, 29 January 2021, 15:44:54 by Shironome »
Offline Anthixious
« Reply #17 on: Fri, 29 January 2021, 22:55:08 »
Maybe it's just me but all the key capo renders look pink on every screen I see it on, it's not really crimson red at all. Also would love the mods to be all colored, or have the base all white as it is along with a separate mods kit colored the pinkish hue.
Offline atlanticise
« Reply #18 on: Sat, 30 January 2021, 02:05:28 »
This is an interesting idea, but the colour combi kinda hurts my eyes. Maybe this would be better if you tried to do the gradient in like a sunset kind of colour instead of neon on white.
Offline Ustinj
« Reply #19 on: Tue, 02 February 2021, 13:09:04 »
what is bad about it? curious
Offline Livid
« Reply #20 on: Tue, 02 February 2021, 20:18:08 »
would also like to know.. it's unique, has a relatively high-effort IC, and looks good IMO. guess he thinks it's "bad" because of his opinion?
« Last Edit: Tue, 02 February 2021, 20:19:47 by Livid »
Offline Ustinj
« Reply #21 on: Wed, 03 February 2021, 00:23:02 »
anyway - would like to see some prototypes of these caps. people are doubting it, but if you pull it off I see nothing wrong with it. I don't have any comment on kitting, but visually it's a step up from many things that *dont* get bashed. The colors right now do feel kind of 'gross' and body-horror like, kind of reminds me of strained and bloodshot eyeballs (uncomfortable).
I guess a lot of people are bothered because you didn't pick color codes for color matching. I guess it's understandable, but if you're manufacturing it in-house I guess it might make the color-matching process doable even without references.
« Last Edit: Wed, 03 February 2021, 00:31:31 by Ustinj »
Offline Bax
« Reply #22 on: Sun, 04 April 2021, 18:23:12 »
Really like the theme! Also, you guys could really hit a home run with these gradient caps :)
Offline Nhils
    • IG
« Reply #23 on: Tue, 18 May 2021, 09:26:25 »
I can't wait to see the prototypes! I'm hyped for new colorway explorations with this technique
Offline Rumblethumps
« Reply #24 on: Tue, 18 May 2021, 10:10:48 »
Definitely unique! Never seen gradient keycaps before. It makes them look like they're glowing on their own with no backlight.
That being said, I'm not a huge fan of the colors. The gradient into the white makes the red look way too light to be called crimson; it almost looks pink. It sort of gives it an irritated skin type of feel. (Which would be cool if that was what you were going for, lol.)
Still looking forward to seeing the prototypes though, imagine all the possibilities if the gradient turns out to be feasible.
Offline Havattack
« Reply #25 on: Tue, 18 May 2021, 16:22:36 »
"almost".... pshhh cracka, that's pink.
Offline KVLT
« Reply #26 on: Wed, 19 May 2021, 09:42:27 »
i think it may be prejudice against non gmks
the bad guy wins in this one
Offline aleeex
« Reply #27 on: Wed, 19 May 2021, 10:00:48 »
The idea is very cool - but why didn’t you wait till you had a proto? It’s a big ask for people to just “trust” that’s it’s doable
Offline Havattack
« Reply #28 on: Wed, 19 May 2021, 17:11:37 »
money, money, moneyyyyyyyyyyy! Money!
Offline Indigu
  • Yea sure
« Reply #29 on: Wed, 19 May 2021, 17:39:04 »
Like the look, it's similar to that keyboard in taeha's intro. They font looks a bit weird for me but that's just my opinion.
Offline ダbruh
« Reply #30 on: Sat, 29 May 2021, 03:24:41 »
looks interesting, but is this even possible tho?
Offline KVLT
« Reply #31 on: Sat, 29 May 2021, 13:53:50 »
i'm interested to see this work... even if it's got issues... i'm still interested
