Author Topic: Wall warts.  (Read 2412 times)
Wall warts.
« on: Wed, 03 February 2021, 19:43:53 »
Is there a trust worthy brand other than samsung/ apple ?  They're stupid xpensivo.
Re: Wall warts.
« Reply #1 on: Wed, 03 February 2021, 19:59:03 »
They all use the same internal parts. It's like paying $30 for a USB you can get for less than $5. Even if it breaks you can buy 5x more for the same price.
Re: Wall warts.
« Reply #2 on: Wed, 03 February 2021, 20:25:53 »
More clearly Tp4 wants to skimp , but not SO much so, that it blows up the fone.
Offline dgneo
  • Supervillain
Re: Wall warts.
« Reply #3 on: Wed, 03 February 2021, 20:33:27 »
anker
Offline retoid
Re: Wall warts.
« Reply #4 on: Wed, 03 February 2021, 20:46:18 »
Mean Well is usually pretty good for a decent price.
Re: Wall warts.
« Reply #5 on: Wed, 03 February 2021, 21:23:25 »
I suspect that this is generally true.
Remember that the voltage is what matters. If you get one with a higher amperage rating, the device will only draw what it needs/wants and/or can use at the moment.
semi-off-topic - apparently they draw a very small current continuously whenever plugged into the wall, even if no appliance is actively draining them
"if you can feel warmth then they are actively feeding"
- D Trump 2026-09-28
Offline jamster
Re: Wall warts.
« Reply #6 on: Wed, 03 February 2021, 23:59:09 »
Wall warts, or USB chargers?
Wall warts are almost invariably Chinese branded, and most seem totally fine.
USB chargers... I guess Anker, or again, anything 'branded'. I'd only really be concerned with quality once it got into USB-C/PD/40-100W territory.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: Wall warts.
« Reply #7 on: Sat, 06 February 2021, 15:44:12 »
Anker
Just my thoughts
Offline Darthbaggins
  • PC Cannibal
Re: Wall warts.
« Reply #8 on: Sun, 07 February 2021, 14:37:07 »
I too recommend Anker, I use their Qi pads and charging bricks.
