Author Topic: This has to be a disorder.  (Read 2297 times)
« on: Thu, 11 February 2021, 17:05:49 »
Noticed the piano and throw rug were not parallel with the wood floor.
Lined up the rug, moved the piano in and out 5mm a few times.
Finally realizing that the RUG itself is not cut completely square.
Now Tp4 is genuinely upset.  Don't want to be, and realize it's not a big deal, but GDI want to killz the rug guy who did this.
Y'all get this sometimes ?
Offline dingusxmcgee
Re: This has to be a disorder.
« Reply #1 on: Thu, 11 February 2021, 20:54:19 »
Once you see it, you can’t unsee it. No matter how slight.
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
« Reply #2 on: Thu, 11 February 2021, 21:27:47 »
Sounds like it's time for TP4 to take up machining :)
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
« Reply #3 on: Thu, 11 February 2021, 21:29:51 »
The number of imperfections in the world is staggering, especially if you yourself are perfect.
My recommendation is to just let it go. "Don't let the perfect be the enemy of the good."
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline hvontres
« Reply #4 on: Thu, 11 February 2021, 22:48:02 »
TP4, better not check any of the corners in your house. I don't think I have found any "square" corners in my place yet. :)
Henry von Tresckow
Offline jamster
« Reply #5 on: Fri, 12 February 2021, 01:05:46 »
Sounds like it's time for TP4 to take up machining rug weaving :)
« Reply #6 on: Fri, 12 February 2021, 03:00:04 »
Sounds OCDish?
I suggest putting it at 30* to the wood and try to forget about it, not that you will.
