Author Topic: Snow + ?  (Read 2982 times)
Snow + ?
« on: Thu, 18 February 2021, 05:56:15 »
So when they say,  4-6 inches of snow for wednesday, and then 6-10 inches snow for thursday.
Are we just suppose to add them up and assume that by the end of thursday there will be ~10-16 inches of snow total ?
How does this work ?
They rest the timer when presenting those numbers ?
Offline yui
Re: Snow + ?
« Reply #1 on: Thu, 18 February 2021, 06:16:50 »
from what i always understood those numbers it is snowfall so if snow did not compact and melt it would add up, but it will unlikely in the real world add up that high. well at least it is how i understand the thing, i never saw actually thick snow that stayed days in and day out. and why does it bother you? you will not go out either way :)
Re: Snow + ?
« Reply #2 on: Thu, 18 February 2021, 07:13:36 »
That's how much will fall everywhere.  Where there's wind it will bank up against walls and it will fall off roofs so nowhere actually land up that depth even ignoring melting, compacting and other human intervention (plowing roads to make pavements impassable, at least that's what they do here)
Still not had any that stuck around this year even though it's snowed many more times than usual.
Re: Snow + ?
« Reply #3 on: Thu, 18 February 2021, 08:25:51 »
I look at clearly isolated and undisturbed objects for an accurate count. An outdoor table standing by itself on the patio, for example, unless a strong wind is blowing and then you will never know.
- D Trump 2026-09-28
Re: Snow + ?
« Reply #4 on: Fri, 19 February 2021, 09:57:36 »
There can be significant snow without wind?  In the ... four(?) times I've experienced proper snow there has always been lots of wind while the many times it hasn't been enough to stick there is no significant wind, as this year.  I have learnt something today :)
Re: Snow + ?
« Reply #5 on: Fri, 19 February 2021, 19:37:01 »
Snow is just rain at another temperature gradient. Sometimes rain falls straight down from a cloud, and sometimes there is a "storm" of some sort.
Have you never experienced the absolutely surreal peace, quiet, and beauty of snow falling straight down, and accumulating in silence?
Re: Snow + ?
« Reply #6 on: Fri, 19 February 2021, 20:44:36 »
Nope, snow usually falls at 45 degrees or in wild swirls as if it's falling between many slow tornadoes.
Probably has something to do with living on the skinny bit of an island rather than a huge land mass?
Re: Snow + ?
« Reply #7 on: Fri, 19 February 2021, 21:07:28 »
snow usually falls .... in wild swirls
A pity, it creates an almost magical landscape.
Offline funkmon
Re: Snow + ?
« Reply #8 on: Mon, 22 February 2021, 10:20:50 »
You know what I discovered recently? Snow falling has a sound, even without wind and when it's slow and fluffy. It sounds like static! Just quiet static.
Re: Snow + ?
« Reply #9 on: Mon, 22 February 2021, 10:55:19 »
Just quiet static.
True. But with practically everything else muffled, it is probably far below any other natural ambient sound profile. (Why do people say "crickets"? Those things can be deafening!)
I attribute it to the tiny impact of flakes hitting tree limbs and leaves, and the almost infinitesimal "crunch" of snowflakes landing on the ground.
Offline funkmon
Re: Snow + ?
« Reply #10 on: Tue, 23 February 2021, 12:35:03 »
You know I was thinking about it the other day. My sister's joint here is next to the ocean and every time you step outside you have this ever present roar of the ocean. It feels very loud. Then I farted last night while walking around and it felt like I just set off a grenade. Turns out is pervasive but quiet.
