Author Topic: Furnace n0000oooo....  (Read 2503 times)
« on: Sun, 21 February 2021, 12:03:20 »
Woke up froz cold.
Be like whaaaa...gon'rong.
Chk furnace, it be blown' cold air.
4 blinking lights, " thermal limiter open "
ffffffffffffffffff................../ maximum h8 mode activate.
Checked thermal limiter switch, indeed, it won't reset.  Bridged the leads, blue flame fires.
Sigh...
Now must wait 2 days in suprcol  for switch.   IF Tp run the furnace without the limiter, assssuming it's just the switch that's broken,  Tp should probably no die. but welllll it is a gas appliance
THOUGHTS ?   Should Tp just run it w/ safety off ? Is that even legal ?
Re: Furnace n0000oooo....
« Reply #1 on: Sun, 21 February 2021, 12:53:56 »
Anyone else I'd suggest putting on a coat as it can't be colder in than out but do you even own one?
« Reply #2 on: Sun, 21 February 2021, 13:05:28 »
Offline pixelpusher
« Reply #3 on: Sun, 21 February 2021, 13:21:35 »
If you blow up from a gas explosion, your post count will be surpassed at some point.  This cannot happen.  Call to get on a list for repair.  Make a tent and keep warm.  Remember, no cotton for sleeping.  Don't wanna sweat and lose precious heat.
« Reply #4 on: Sun, 21 February 2021, 13:27:08 »
Here's the p00r person engineering thought..
Tp dun' think the sensor tripped.. it MAY just be corrosion..  perhaps Recent xcapadz into Humidifying has accelerated oxidation on an already old-sensor.. no ?  imagining it ?  it sounded reasonable when Tp thunk it....
Xplodz ?
The radon outside air inlet is right next to the furnace, so it's getting a mix of cold wintry air + the normal air of the house,   Can't really see that it'd overheat in the winter.   The intake filter was changed only in late Jan, flow rate should be gud.
« Reply #5 on: Sun, 21 February 2021, 14:55:32 »
Imagine if off-topic posts counted toward the total !
- D Trump 2026-09-28
