Author Topic: 2021 printers  (Read 5107 times)
2021 printers
« on: Thu, 13 May 2021, 13:58:49 »
Why is installing printers still like pulling teeth in the year 2021..
click click, install, ufr2, ufr2 v4, wth is that, google, nothing. even canon doesn't know what v4 is.
Clikc click, install, can't find printer,  GDI, 2.4ghz only ? crap,  Turns on 2.4ghz, ok can't find printer.. GDI, go to printer, enter ssid manually, pass, Printer found.    Where is scan, Tp4 want scan,  google,  download separate scan utility, OMG,  ok,  clik clik , install,  scanner utility Can't find printer.. IWEFHWEtgh9p8q34p ygq24h93g4hpq3g4h8pg54h8pg54h8p9g5h89pp3g5h89g5h89pg5h8p[05h8p[0
Offline Darthbaggins
  • PC Cannibal
Re: 2021 printers
« Reply #1 on: Thu, 13 May 2021, 14:02:46 »
didn't have issues doing this with my HP printer, Win10 found and installed all that was needed for print and scan capabilities.
Re: 2021 printers
« Reply #2 on: Thu, 13 May 2021, 14:06:43 »
Are these printers safe ? do people hax them to churn crypto ?
Offline Sniping
Re: 2021 printers
« Reply #3 on: Thu, 13 May 2021, 14:18:41 »
still use the same black and white laser printer. last time i checked last year they still make quality laser printers without the gimmicks, they're just a couple hundred bucks like they always were. i always just hook up my laptop to the printer when i need to print something.
Offline Olumin
  • "Guy walks into a doctor's office..."
Re: 2021 printers
« Reply #4 on: Thu, 13 May 2021, 15:38:53 »
Guess a decent typewriter doasnt seems like such a bad investment now does it.
And no installing or updates required. Guaranteed.
Offline Leslieann
Re: 2021 printers
« Reply #5 on: Thu, 13 May 2021, 22:42:06 »
HP?
Probably HP.
How do you fix an HP printer or scanner? Throw it away and buy a Brother.
Unless they really need color often, I tell people buy a Brother B&W laser fax, super cheap to own and operate and last forever, if you need color it's actually cheaper to drive to a printing store or Walmart for the rare times you probably need it.
Your keyboard probably has more computing power than your printer.
They're hacking RGB software to mine crypto.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: 2021 printers
« Reply #6 on: Fri, 14 May 2021, 04:33:42 »
And with the risk of being accused of blasphemy around here: They can be more satisfying to type on than on a computer keyboard.
Offline Olumin
Re: 2021 printers
« Reply #7 on: Fri, 14 May 2021, 06:45:10 »
My Olympia Report Deluxe is more satisfying to type on then any beamspring board.
Offline MIGHTY CHICKEN
Re: 2021 printers
« Reply #8 on: Fri, 14 May 2021, 16:02:38 »
Big daddy capitalism wants you to feel pain
  • PC Cannibal
Re: 2021 printers
« Reply #9 on: Fri, 14 May 2021, 18:49:46 »
HP?
Probably HP.
Only reason why I have my HP is due to a HP rep giving it to me along w/ 2 years of free ink - I'll use it until it dies and then I'll get a real Epson Photo printer or do more research into what else would be good to print photos larger than 8"x10" on the stock I prefer to use.
Offline Leslieann
Re: 2021 printers
« Reply #10 on: Fri, 14 May 2021, 22:13:59 »
While not quite as bad, they're working on doing similar things with ink, like locking out remanufactured and clone cartridges.
Check the model before buying and never update firmware. The days of constant ink systems on Epson printers is quickly coming to an end, which was part of the draw to them.
What needs to happen is the open source 3d printer devs need to work backwards and design a 2d open source printer.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Re: 2021 printers
« Reply #11 on: Sat, 15 May 2021, 08:28:05 »
Paper craft needs to get a whole lot more popular, otherwise it's just the work printers.
Offline Kavik
Re: 2021 printers
« Reply #12 on: Fri, 21 May 2021, 14:31:27 »
I'll second Leslieann. Brother printers seem to be no (or at least less) BS than others. I've had the same HP printer for a long time, but it is always so much trouble that I finally stuck it in a corner and stole my mom's Brother printer. I don't understand why these devices need special software or complicated drivers just to function; it should be like plugging in a keyboard or mouse and just work. The only improvement over the printer I had 25 years ago is the new ones are quieter (and maybe resolution or something, idk).
Offline Leslieann
Re: 2021 printers
« Reply #13 on: Fri, 21 May 2021, 20:54:29 »
They don't.
There are universal standards and drivers for printers and scanners, Windows used to use them and (shhhh) they still do.
The software is just vendor lock-in, you wouldn't want to have to learn a new program would you? You already have the software and spare ink, just buy another when this one breaks... I can't tell you how many times I've hacked Windows drivers from older printers/scanners to work on newer ones, they aren't significantly different.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: 2021 printers
« Reply #14 on: Sat, 22 May 2021, 21:45:54 »
Using printers is like using a gramophone in 2021
Just my thoughts
Re: 2021 printers
« Reply #15 on: Tue, 25 May 2021, 19:10:40 »
Also, why scanner still make sounds like it's busted.
269154-0
Offline Kavik
Re: 2021 printers
« Reply #16 on: Fri, 28 May 2021, 09:47:50 »
Is TP4 scanning and printing money so that he can send us stimulus checks?
Re: 2021 printers
« Reply #17 on: Fri, 28 May 2021, 09:59:47 »
Normally, what they do is, they counterfeit $20s and $100s,  but they wash the $1 bills for the dye.
Tp4 would have to be the world's worst counterfeiter doing $1s, cuz it'd cost more to make..
Offline sefixmm
Re: 2021 printers
« Reply #18 on: Sat, 29 May 2021, 04:58:59 »
Only use laser+professional+network+printers and i never had issues :)
« Last Edit: Sat, 29 May 2021, 05:00:55 by sefixmm »
