Author Topic: Doors.  (Read 3526 times)
Doors.
« on: Sun, 27 June 2021, 07:26:37 »
If want hifi, open as many windows and doors as possible.
Chk this measurement difference, small room, 1 door, open (dark line) vs closed.
Offline Faceman76
Re: Doors.
« Reply #1 on: Sun, 27 June 2021, 08:20:24 »
There was no getting rid of that via DSP.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Doors.
« Reply #2 on: Sun, 27 June 2021, 09:31:57 »
Pretty wild difference there! I don't know a ton about WiFi, but when we had our newest router installed the technician told us that putting it up on the 2nd floor would help it work better. Since the signal supposedly goes up & falls back down like if you held a hose straight up in the air. Can't say for sure how much truth there is to that, but I will say since we did follow his advice & put it on the 2nd floor we get a pretty good signal all across the house. Although in the furthest rooms from the router I have noticed the signal being much weaker when the door to those rooms is closed.
Offline Faceman76
Re: Doors.
« Reply #3 on: Sun, 27 June 2021, 10:53:53 »
Hifi and WiFi are slightly different.
@tp4tissue, multiple subs throughout the room may resolve your issue without opening doors or windows.
Open Baffle woofer/subs will excite less room nodes as well.
Re: Doors.
« Reply #4 on: Sun, 27 June 2021, 10:56:42 »
No idea what this shows or which out of bright blue and slightly muted red is supposed to be 'dark' :confused:
Offline Faceman76
Re: Doors.
« Reply #5 on: Sun, 27 June 2021, 11:03:08 »
Red=Open
Blue=Closed
That would have been easier for all. Maybe OP is colorblind?
Small spaces will cause peaks and nulls in bass reproduction.  By opening doors or windows, there will be less of this, but bass will fall off earlier due to the lack or reinforcement.
Re: Doors.
« Reply #6 on: Sun, 27 June 2021, 11:12:57 »
Hahahahha.. Believe it or not wifi is also aided by open doors. Keep the windows closed though, unless you want your wifi to get out into the garden.
Re: Doors.
« Reply #7 on: Sun, 27 June 2021, 11:15:14 »
Closed small rooms eat your bass response in these slices. If you open the door, the waves get out, and won't cancel out.
Re: Doors.
« Reply #8 on: Sun, 27 June 2021, 14:48:12 »
 :confused: is this thread about hifi or wifi?
Re: Doors.
« Reply #9 on: Sun, 27 June 2021, 16:00:29 »
 wifi is one of the best ways to transmit hifi data. galvanic isolation
Offline jamster
Re: Doors.
« Reply #10 on: Sun, 27 June 2021, 23:14:25 »
You have your microphone located at a bass null for 65Hz. Wavelength is 5.3m, iirc you're looking at wave peaks and troughs every 1/4 wavelength (I can't remember basic physics) so every 1.3 metres.
Opening a door has changed the null locations slightly, but just moving your head or moving the speakers would result in similar shifts, and it would probably mean you get messed up bass in other locations.
If anyone has a decent set of speakers, finding bass nulls is pretty interesting- go to a site that generates pure sine waves, generate a low tone (40-80Hz) and then walk around the room. Your head will go in and out of bass nulls and peaks, it is incredibly easy to hear- sometimes the tone simply vanishes.
Edit- hard to tell what that graph means as it's missing the Y axis labels.
« Last Edit: Sun, 27 June 2021, 23:16:17 by jamster »
Re: Doors.
« Reply #11 on: Mon, 28 June 2021, 06:44:51 »
I'm looking at the subwoof,  there's no reason why it can't become a chair.
Offline yui
Re: Doors.
« Reply #12 on: Mon, 28 June 2021, 07:15:07 »
if it is built well enough, sure, although do you really want to be on it at full volume?
Offline Faceman76
Re: Doors.
« Reply #13 on: Mon, 28 June 2021, 17:12:59 »
Google tactile transducers. I have four from Aura on my couch.
Some may find this exciting...
