Author Topic: [IC] ePBT Timeless | Pre-orders Live  (Read 68772 times)
Offline imivanh
    • The Right PC
« on: Wed, 30 June 2021, 23:25:54 »
Hey Everyone! Welcome to the IC of my first set, ePBT Timeless.
Please check out/fill out the IC Form.
This set is meant to reflect a timeless design aesthetic/language, which primary features are off-white, grey, and beige/wood tone colors.
GB IS LIVE! The Right PC is doing a 5% off all ePBT Timeless group buy products (applied at checkout) until Oct. 11th, 2021
Kits
Base Kit
Numpad Kit
Dark Alphas Kit
Spacebars Kit
40s Kit
International Kit
Color Comparison
Hex was used approximate the color and may not be 100% accurate to their Pantone/Ral/etc
Renders
Fuji 65
Rama U80
Desk Mats
Continuum - This desk mat was inspired by a certain show, a scene from the place that exists outside of time.
designed by fireanddarkness
Eternity - Heavenly clouds, a place that exists forever
ePBT Timeless x The Deep Desk Mat (Light)
designed by Cat from Onomichi
ePBT Timeless x The Deep Desk Mat (Dark)
Artisans
Metal Artisan Collab w/ AseroFoundry
CNC Brass Artisan Collab w/ THOK
Vendors
US - The Right PC
CA - Shockport Keyboards
UK - Prototypist
EU - Eloquent Clicks
Asia - KBDFans
OCE - DailyClack
India - StacksKB
PH - Klikity Shop
GB Date
October 4th - November 1st, 2021
Pricing
KBDFans will not be offering the metal artisans, so you can purchase them from The Right PC, they ship Worldwide. Make sure to only have the metal artisans in your cart on check out for cheapest shipping.
Collabs
Cat From Onomichi - Desk Mat
fireandarkness - Desk Mat
Yu.Keys - Artisan
MOZICaps - Artisan
Cantoclicks - Artisan
THOK - Artisan
Aserofoundry - Artisan
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=113610.0][img width=263 height=120]https://i.imgur.com/AM9sH0a.png[/img]][/url]
ePBT Timeless IC Form
Discord
Instagram
Special Thanks
The Right PC Team - helped me with kitting + overall positive support
dandruff - for the advice and sharing his experience as a designer
MechGroupBuys
Update Log
6/30/2021 - IC Posted, base kit renders fixed for F13 key, removed scooped F, J, and 5 keys
7/12/2021 - Manufacturer changed to Milkyways for PBT keycap manufacturing. Slight kitting update for 1 SKU for ease of manufacturing and pricing. No longer running a dark base kit due to manufacturer not able to produce reverse dye-sub keycaps reliably at this time.
7/20/2021 - Another change in manufacturer due to Milkways unable to produce reverse dye-sub for the colors we want at the moment. Samples have been ordered with another manufacturer to check quality and to determine if we go with another manufacturer and being able to produce some reverse dye-sub keys.
7/25/2021 - Based on IC, base kit mods are now changed to dark mods. Still awaiting reverse dye sub samples to come in to make sure quality is acceptable.
7/29/2021 - Currently in talks with ePBT, most likely we will be running this as an ePBT set.
8/3/2021 - Confirmed with ePBT this set can be made
8/6/2021 - Spacebar kit added
8/9/2021 - Kits finalized, added 40s and international kit. Removed basic 40s from base kit. Color comparison render added. Rama U80 render added.
8/11/2021 - Quotes expected from ePBT in about a month. EU vendor confirmed
8/18/2021 - Vendors Finalized, Collab section updated.
8/30/2021 - First desk mat revealed, created by fireanddarkess
9/4/2021 - ePBT Timeless x The Deep Desk Mat collab reveal
9/7/2021 - Collab update
9/11/21 - GB date finalized!
9/12/21 - Slight change to the pantone color, the chip I received did not meet my expectations of the color, so I changed to a different pantone that better matches the set
9/15/21 - Final Desk Mat Design added
9/16/221 - Desk mat render overhaul, pricing announced, added OCE Vendor
9/21/21 - Metal Artisan Collab with AseroFoundry revealed!
9/26/21 - CNC Brass Artisan Collab with THOK revealed! Pricing updated for some vendors.
10/4/21 - GB is live until November 2nd, 2021!
To Do
- Move basic 40s to base kit
- Move accent bars to separate spacebar kit Accent bars remain in base kit
- novelties(?) Decided to not have novelties. Will be creating matching desk mats instead for the theme.
- Render updates
- Matching Desk Mats
- Collabs
- Vendors
- Waiting on Quotes and Pricing
- Finalize GB Date
« Last Edit: Sun, 30 January 2022, 05:59:24 by imivanh »
Offline MIGHTY CHICKEN
Re: [IC] GMK Timeless
« Reply #1 on: Wed, 30 June 2021, 23:28:37 »
The light base is just bow...
Consider removing it as two bases is not a really good idea for GMK
Offline JohnYYZ
  • KanataKeys.co
« Reply #2 on: Wed, 30 June 2021, 23:31:48 »
Looks pretty good, GLWIC
^^ Also same thoughts on having two base kits.
Offline pararch
« Reply #3 on: Wed, 30 June 2021, 23:34:51 »
I would take a second look at the 40's kit, as there seems to be a lot missing for optimal coverage for GMK kitting. You're missing quite a few R4 keys like 1.25u shift, and all the 1u text keys. I'd also consider breaking the spacebar kit out from 40's.
Also would not run 2 base kits for GMK. The dark kit gives me GMK Nines vibes.
GLWIC
Offline IOVERCALLHISTIOCYTES
« Reply #4 on: Wed, 30 June 2021, 23:57:11 »
I like CP white (hagoromo for oblivion, Olivia, ursa) more than WS1 (minimal) and always wanted CP white mods.
Do a color comparison w oblivion mod grey, N9, and the dark dark grey from GMK lux if you can.
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #5 on: Thu, 01 July 2021, 00:04:19 »
this feels ridiculously low effort
Offline imivanh
    • The Right PC
« Reply #6 on: Thu, 01 July 2021, 00:09:08 »
Gotcha, I will definitely put that into consideration.
Thank you! I will definitely consider removing one of the base kits.
Will get right on that, thank you for the input!
What about this makes it feel ridiculously low effort? Would love to show you more effort if you have any suggestions on how I can do so!
Offline doggo1dance
« Reply #7 on: Thu, 01 July 2021, 00:13:37 »
quite ironic coming from someone that doesn't provide suggestions to improve the set as a whole  :p
Offline stevenT
« Reply #8 on: Thu, 01 July 2021, 00:19:06 »
I would like to see yellow on black mod in same kit with white alphas, gonna be next big hit after Olivia
Offline Altephor
« Reply #9 on: Thu, 01 July 2021, 00:20:10 »
F13 in renders but no F13 in the kits?
Offline nvh2092
« Reply #10 on: Thu, 01 July 2021, 00:23:55 »
I'd to see novelties, consider making a kit which has gold (patone 911c) novelties about the design philosophy so it can be used for both bases.
« Last Edit: Thu, 01 July 2021, 02:22:51 by nvh2092 »
Offline imivanh
    • The Right PC
« Reply #11 on: Thu, 01 July 2021, 00:32:27 »
Good catch, I'll get the kit rendering fixed asap. There will be a F13 Key in base kit
Edit: base kit renders fixed for F13 key
« Last Edit: Thu, 01 July 2021, 00:51:22 by imivanh »
« Reply #12 on: Thu, 01 July 2021, 00:39:20 »
It's basically just bow/wob,
Kitting is a mess with no normal f and j
The extras kit forces accent bars and is missing other important stuff like 2.25u and 2u bars, everything mostly just looks like stock krk etc.
Offline hayasaka
  • No.
« Reply #13 on: Thu, 01 July 2021, 00:42:26 »
looks classy
Offline dandruff
« Reply #14 on: Thu, 01 July 2021, 01:11:59 »
I share some of your views such as no normal f and j while there is a normal 5 key in numpad (the inconsistency bothers me, and I'd rather just remove scooped completely.
but I'm going to have to disagree regarding bow/wob and low effort.
I think this has everything people are looking for in a starting IC. Colors/renders/theme and they build upon it. Especially for his first keycap post, imagine flaming someone's kitting issues as low effort.
As for colors, first off, you can't "own" a colorway, and the white in this case is CP rather than the usual WS1 and WS2. As for the dark kit, white is nowhere lol.
I think it's a fine start, and just needs to fix some kitting issues (like adding basic 40s to base kit if 40s kit is going to be kitted like that (and possibly add novelties (?))).
Edit: Also... to my knowledge and personal experience... when has 2 base kit been a bad idea with GMK...?
« Last Edit: Thu, 01 July 2021, 01:24:54 by dandruff »
Offline imivanh
    • The Right PC
« Reply #15 on: Thu, 01 July 2021, 02:30:23 »
Thanks for the feedback dandruff! I will change the scooped keys to regular keys first, and work on fixing the extras kit. It is so hard to make everyone happy with the kitting haha, since it's impossible to fit everything into the base kit. Looks like putting basic 40s into the base kit is the way to go, and move accent bars and arrow keys to a separate kit.
« Last Edit: Thu, 01 July 2021, 03:03:32 by imivanh »
Offline sup3r170va
« Reply #16 on: Thu, 01 July 2021, 08:51:11 »
I quite like the CP set. Suggest you move the basic 40s kit into the base. Consider white/dark grey bars instead of the cream ones.
A hangul or hiragana sublegends child kit would be nice.
Offline chamoy_MXC
« Reply #17 on: Thu, 01 July 2021, 09:22:20 »
I like this. For the basic 40s support on base you just have to add  1.75 R2 backspace, 1.5 enter and 1.25 tab both R3. That covers minivan and you will have a lot of forties happy with it.
Offline Neely_12
« Reply #18 on: Thu, 01 July 2021, 09:39:13 »
I feel like the white base could use extra character. I understand its supposed to be simple, but bow with gold accents isn't anything crazy. Also a r3 pg up and a r4 pg dn would be appreciated if added in the base.
Offline hali
  • OHHHH MY GODDDDDD
    • hali.studio
« Reply #19 on: Thu, 01 July 2021, 10:28:29 »
A lot of areas don't cut it for me. Light base is very similar to Stormtrooper, just with icon mods, slightly darker legends, and an accent colour. Dark base is similar to other yellow on black/grey options. Interior design is mentioned but nothing really reflects that. To me it seems like nothing is really done to set this set apart from others, or to even convey the theme of interior design as well as it could have. IMO novelties should have been released alongside IC, because from what I see, there's nothing very timeless here.
Offline iinko_mk
  • Status: broke
« Reply #20 on: Thu, 01 July 2021, 15:05:09 »
both base kits look like something that already exist. the light base is just bow with orange accents (i think geekark ran something like this only a few months ago).
The dark base looks like a slew of other sets. We have solaria, spirit, and inukuma just to name a few.
You might also want to revist the 40s kit, it has really minimal support that doesn't do much. Clumping it with spacebars just makes it more expensive, and people buying spacebars will have to spend an extra 20 USD at least to get alice support at all. (base kit doesn't have an extra 2.25u shift)
Offline Cylent
  • Formerly cylentshadows
« Reply #21 on: Thu, 01 July 2021, 17:14:35 »
imo kitting can be fixed pretty easily, although 40s is a bit more difficult, but can also be done, so not a massive deal
I agree with hali and iinko on there already being very similar sets, and that without novelties the theme really doesn't come through for me.
tl;dr - This IC has been put in the oven, but not for long enough. Please put it back in the oven so I can evaluate whether this set is something I want to purchase.
Offline Zetina
  • Big bird
    • Instagram
« Reply #22 on: Thu, 01 July 2021, 20:16:09 »
I personally think that you should offer some tipe of accent kit instead of the white base, but the set looks nice GLWIC
Instagram: @zetina.kb
Offline kiwoli
« Reply #23 on: Thu, 01 July 2021, 20:29:28 »
I feel this IC needed to launch with some banger novelties/deskmats, the timeless theme is not strong enough based on the accent colour alone.
Using an IC form to gauge interest in the separate base kits is fine, just need to know when to fold one of them.
The most recent case is GMK Cobalt when the alternate base kit had to be cancelled due to poor sales during GB window.
Offline phxrbn
  • tech. design. real estate.
« Reply #24 on: Thu, 01 July 2021, 22:13:07 »
Maybe add a darker 'neutral' tone for the dark kit, like a deeper brown. Think of it as white + birch/one and black + walnut. Maybe could work. Novelties like a rama with woodgrain/knot would be nice.
Offline HappyB0T
  • I'm a Piggie
« Reply #25 on: Fri, 02 July 2021, 01:24:28 »
GMK Sixes and GMK Art have more style for sets that are simple. Although those sets are simple there is a design aesthetic to compliment them. I really feel that this set is positioned between a BOW / WOB set and those sets referenced above. What make those sets successful is their attention to detail and setting a specific goal. Some people have commented that GMK Boho is well designed but at the same time conservative in its approach. I would use the word - safe in it's colorway. I feel that this set fall short of communicating a vision like Boho does.
If you have a vision - what would the novelties be?? Even if it was to support a design standard there should be at least something to convince people that this is worth a 1.5 year wait. I am not seeing it.
Even the most basic of BOW & WOB sets have something that differentiate them from others. Maybe it is a more modern or retro take on choices and kitting.
Offline HappyB0T
  • I'm a Piggie
« Reply #26 on: Fri, 02 July 2021, 01:28:36 »
Please consider changing the name of the "extras" kit - this is confusing in the context of a keyboard GB. Extension | 40s | Alt kit all are better at describing the kit.
GLWIC
« Last Edit: Sat, 03 July 2021, 20:30:01 by HappyB0T »
Offline bigdonnerz
« Reply #27 on: Fri, 02 July 2021, 09:01:42 »
I think the colours are nice and don't agree that it needs a vision or concept behind it to differentiate it from other kits. There's also ready so much duplication of colours and ideas, it's easy to reduce most sets to "it's just X but with an added Y".
My only feedback would be that the kitting looks like it might result in this being expensive. I think you might be better off picking one of the two for the first run of this. Personally, I prefer the BOW set but it's up to you.
GLWIC!
Offline imivanh
    • The Right PC
« Reply #28 on: Mon, 05 July 2021, 01:44:41 »
Thanks for the feedback! I am working on finalizing the changes for the kitting and hopefully it’ll make more people happy about it. I agree it is definitely easy to categorize sets into other existing sets. Something is always the shade of another thing, there are only so many basic colors.
Offline DeMechanica
« Reply #29 on: Mon, 05 July 2021, 07:44:25 »
This set is meant to reflect a timeless interior design aesthetic, featuring off-white, grey, and beige/wood tone color accents.
There will be two base kits:
A Light Base to represent the traditional timeless interior design, which features white "walls" with grey and beige/wood tones;
and a Dark Base, for those who like dark mode (my personal favorite).
How does an off yellow cream colour or a dark grey represent beige / wood? Why offer a dark mode? What sets this apart? What makes this set unique? What makes it worth the investment from vendors? How is it worth the money of those who buy it? I’m completely unconvinced by the answers to these questions. I encourage you to try to answer those types of questions with a more thoughtful design.
And finally, how is this set “timeless”? Even if we take away the set colours not matching your description, the description isn’t even a timeless style, if I understand what you were describing correctly. The naming honestly reminds me of the GOAT stabilisers.
If the colours are just colours you like, scrap the pretence and just call it GMK Imivanh, don’t take away a great name from a design that would perfectly fit the name. Just tell it like it is and be up front about it being a design you want and so you’re running a GB for it to make it affordable for you. I think people wouldn’t question it nearly as much. I know I’d appreciate it.
Genuinely, good luck with the IC, I hope you take this as it’s intended, which is very clear (perhaps too clear and therefore quite harsh) constructive criticism.
« Last Edit: Mon, 05 July 2021, 07:47:58 by DeMechanica »
Offline hrmmm
« Reply #30 on: Mon, 05 July 2021, 09:48:04 »
I dunno, I like it. I find it simple, clean, and overall pleasant.
Some people are trying to get you to answer all these deeper questions, but honestly, no one is forcing anyone to buy it. If a vendor doesn't think it's worth the investment, then they won't do it. If you don't like the design, don't buy it. That being said, if there are some things you can do that'll increase its appeal to a wider audience, sure, go ahead and do it. But ultimately it's your design, so stick to your guns.
Offline imivanh
    • The Right PC
« Reply #31 on: Mon, 05 July 2021, 23:04:25 »
I appreciate the criticism. Thank you for your comments
Offline scoopbb
« Reply #32 on: Tue, 06 July 2021, 00:52:54 »
i like the light set. the tone of the criticism is pretty insane. maybe thematically i can see their point but def not from, the low effort. even if it was just "white and yellow", id still like it and wouldn't consider it low effort.
Offline holer
« Reply #33 on: Tue, 06 July 2021, 04:20:01 »
Damn this thread has been harsh  :(
I like the dark base, and it scratches the same itch as the dark version of ePBT Antarctic Emperor for me. And even if they are similar, then they are different profiles and the switch from blue to black is quite significant.
I don't mind the lack of novelties - imo too many sets have token novelties included that does nothing for the theme. So maybe asking for suggestions for novelties is a commendable approach.
All in all, I don't think this is low effort at all, and best of luck  :)
Offline imivanh
    • The Right PC
« Reply #34 on: Tue, 06 July 2021, 17:00:06 »
Thank you, I appreciate that you can see this is not low effort. I feel I put I lot of work into creating what I thought was my vision. There are definitely valid criticisms that I have and will improve on the set, but it does hurt a bit for people to scream "low effort" at me.
Thank you for your kind words! I'm glad there are those who don't disvalue my work or think it is "low effort". I did put a good amount of thought and effort into this and it does suck that some do not understand my vision for the set. There are valid criticisms, which I will definitely improve on them where needed. I thought IC was a place to share the idea and make changes according to criticism, but some seem to want a fully fleshed out and completed project immediately.
Offline mymeepo
« Reply #35 on: Tue, 06 July 2021, 17:41:17 »
Don't get discouraged. The dark base set definitely has potential and it is clear that you put in effort into this IC.
Offline holer
« Reply #36 on: Wed, 07 July 2021, 05:07:50 »
Cheers :) Let me take this chance to give you some less useful feedback - you went for the "wrong" iso support (and here wrong means the one I don't use) with R4 "< >" instead of R4 "\ |".  ;D
Offline SwirlCables
  • Where Cables Meet End Game
    • SwirlCables - Custom Made Coiled Cables
« Reply #37 on: Sat, 10 July 2021, 00:58:14 »
very clean and nice!  :thumb:
Offline conternecticus
If there's no separate 40s kit then please add minimum support for 40% in the base kit.
Offline pondscum
Re: [IC] ePBT Timeless | Formerly GMK Timeless | Major Changes Made
« Reply #39 on: Wed, 04 August 2021, 08:36:21 »
Looks good - can go with Daily Clack for an OCE vendor
Offline Cylent
« Reply #40 on: Wed, 04 August 2021, 10:57:06 »
You switched to ePBT but kept GMK kitting with 3 key support for 40s? Please just kit for ePBT.
Offline salgiza
« Reply #41 on: Wed, 04 August 2021, 15:34:41 »
Now that you are going with ePBT, please consider adding kittings for Norde and South (or even FR/BE) layouts. There are not that many elegant layouts with South & FR layouts, so hopefully that should give you a boost to meet the MOQ.
Same thing with 40s, Mac modifiers, etc. Hopefully there is no rush to get the GB out, and the more kittings that you add, the more interest that you will gather. So, having a MOQ just for the base kit, you should probably take the chance to add as extra kittings as you feel comfortable doing/think that make sense.
In addition to that, I agree with others that the IC will have more chances of having a successful GB if you manage to add some novelties that match the spirit of the theme. Maybe timeless designs? (I’m thinking lamps, furniture, maybe buildings). Art Deco glyphs would also match the color theme, I think.
Anyway, it’s your set, and it already looks quite nice as it is!
« Last Edit: Thu, 05 August 2021, 04:40:30 by salgiza »
Offline solomonshv
« Reply #42 on: Wed, 04 August 2021, 18:37:19 »
would you be able to tell us why was the manu changed from GMK?
i was thinking about a color comparison with GMK Cafe.
it appears that the designer IS the vendor. i will surprised if this gets proxies.
Keebs::: Bok.CP - Antique Copper | Keycult No.2/65 Black/Brass | Keycult No.2 Rev 1 Grey/Brass | Jane V2 CE - Black/Multicolor | J-01 Rev1 - Blue | Haus - Silver | Kohaku - Red | OwLab Jelly Epoch - Ruby SE & Popcorn | KBD8X MKII WKL - Black PC | Ayleen WKL - Gin
Caps::: GMK Modo, GMK Jamon, GMK Olive, GMK Mizu, GMK Olivia++, GMK Bingsu, GMK Analog Dreams, GMK Botanical, GMK Moondust, GMK Taro R2, GMK Hennessey, GMK Serika R2, GMK Birch, GMK Tuzi, GMK Red Alert, GMK Zooted, GMK Hazakura, GMK Cyrillic Beige, GMK Lavender, GMK Daifuku, GMK November Fog, GMK Villanelle, GMK Blossom, DCS 9009 WYSE Alps
On order: GMK Tiramisu, GMK Maroon, GMK Bordeaux, GMK Taiga
Offline stevenT
« Reply #43 on: Wed, 04 August 2021, 20:44:24 »
very nice set, does Ebpt has same thickness as GMK?
Offline bball2
« Reply #44 on: Wed, 04 August 2021, 21:39:52 »
I really like it! Definitely in for a base set
Offline gloomycloud
  • me enjoy 60s
« Reply #45 on: Thu, 05 August 2021, 00:17:04 »
Please consider a spacebar kit with 2.25u, 2.75u, and 2x 3u spacebars
HHKB Pro Hybrid || Polaris || Kei || Meridian || Leviatán
Offline imivanh
    • The Right PC
« Reply #46 on: Sat, 07 August 2021, 21:59:38 »
Decided not to go with GMK due to the insane wait times. They really work on increasing production.
As for color comparison, I will work on rendering one with GMK Cafe as requested. In the meantime if you're interested, we are using Pantone 911 C, GMK N9, and GMK CP for our colors.
I am a vendor, but will definitely be having other regional proxies, not going to force people to only be able to purchase from us. Currently working on finalizing the regional proxies.
Thank You!
Done! Spacebar kit added.
Offline N3VERM0R3
« Reply #47 on: Mon, 09 August 2021, 14:06:50 »
Really liking this set. Good luck!
Offline denibhoxha
  • cock and balls technology
« Reply #48 on: Mon, 09 August 2021, 15:06:54 »
yet another epbt set with 5 side dye sub
Offline imivanh
    • The Right PC
Re: [IC] ePBT Timeless | Final Kitting Revealed
« Reply #49 on: Tue, 10 August 2021, 03:02:24 »
Update: Final Kitting revealed. 40s and International kits have been added due to request, and basic 40s were removed from base kit. Updated thread with color comparison to GMK Cafe and JTK Suited Assassin. Final things to do are:
1. Finalize the rest of the regional vendors
2. Finish Desk Mats
3. Finalize Collabs
4. Get Quotes
