Author Topic: Does this work ?  (Read 1885 times)
Online tp4tissue
Does this work ?
« on: Thu, 19 May 2022, 08:36:26 »
Felt harder to read the bolded one.
286404-0
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Does this work ?
« Reply #1 on: Thu, 19 May 2022, 08:48:11 »
Seems really gimmicky to me. The bolded one looks more cluttered & messy, also doesn't make any noticeable improvement to my speed or comprehension of the text. I see what they are going for, by bolding the first few letters of each word in theory someone could use that to speed up their reading. In practice though it doesn't pan out that way it seems. Well at least it doesn't seem to help me at all, in fact I feel like it's a hinderance.
« Reply #2 on: Thu, 19 May 2022, 08:51:29 »
That is kind of interesting.
It may be that being more "difficult" means that it forces you to focus harder. Their goal is that you walk away having absorbed more content.
They never said that it would be "easier" to read, the "shallow form of reading" they refer to might be similar to what we used to call "skimming" and that is not an optimal study style.
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
Online tp4tissue
« Reply #3 on: Thu, 19 May 2022, 08:52:37 »
suspect the bolds might not be in the right place for everyone, Tp4 does not read single words, Tp4 reads blocks of paragraphs and at the very least 3-5 words at a time.
« Reply #4 on: Fri, 20 May 2022, 10:29:33 »
Thought this was something to do with subpixel rendering of fonts but actually the bionic version was significantly quicker and easier to read (I read it first as it looked "interesting" so not helped by remembering the normal version)
« Last Edit: Fri, 20 May 2022, 10:36:41 by suicidal_orange »
Offline butre
« Reply #5 on: Fri, 20 May 2022, 10:33:24 »
the bolded bits slowed me down, which might improve reading comprehension.  using the same paragraph twice makes it harder to determine if it made a difference in that regard though, since I already had read the paragraph normally.
Offline Leslieann
« Reply #6 on: Fri, 20 May 2022, 17:52:47 »
I find that actually painful to read.
Keep in mind, I'm dyslexic, this style forces me to have to skip all my tricks that enable me to read at a normal or slightly accelerated pace (which takes a lot of effort as it is) and I kept having to go back and re-read things because it made me think I missed something I didn't. So now I'm not only 4 or 5 times slower reading it but I have lost all sense of what the heck I was reading.
Basically it comes off as brain aching word salad while the regular font made sense.
I have heard from an ADHD sufferer that it helped them keep on track while reading it so it may work for some but not others.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #7 on: Mon, 23 May 2022, 00:58:38 »
I've always found that if you need to retrain your brain as opposed to enhancing your current tactics, it is rarely worth the effort and often makes your cognitive fluidity worse for having tried.
I don't like it.
Offline pixelpusher
« Reply #8 on: Mon, 23 May 2022, 01:03:30 »
It actually made the text much easier for me to read.  I'm intrigued
Offline Coreda
« Reply #9 on: Mon, 23 May 2022, 04:26:31 »
I don't think it's a fair comparison. The right is in part easier to read since is has stronger color when contrasted with the surrounding whitespace, which even with the odd mix still helps legibility.
Raise the minimum typeface weight on the left and then one can judge whether it's the technique or just better color helping the reading speed (or even desire to read it in the first place).
Offline Sintpinty
  • Carbon Based Life Form
  • she/her/they/them/any except he him
    • My Roblox Profile
« Reply #10 on: Tue, 24 May 2022, 10:19:29 »
Seems glitched to me when i read
bio.link/bitbat
