Author Topic: Do you use your little fingers to type often?  (Read 72330 times)
Offline EpomakerKeyboard
    • Epomaker
« on: Mon, 06 June 2022, 21:20:23 »
When learning to type, I had a proper lesson to train myself rest the certain fingers to certain keys. In this way, I can type without watching the keyboard. But when at work, I met some people who cannot leave their eyes on the keyboard to type, especiall when it comes to the keys that the little fingers can reach. And then I saw some youtubers who do typing tests without using their little fingers, which is unbelievable for me!
So I wonder, how many people use their little fingers when typing?
Re: Do you use your little fingers to type often?
« Reply #1 on: Mon, 06 June 2022, 22:31:27 »
went from 130wpm to 90wpm on 10fastfingers, no pinky.
I could imagine doing 130 without pinky because on the right it only controls p, on the left q and z isn't used much, "A" is the biggest impact, but it's only a slight change up of 1.5 key, very doable.
Offline sefixmm
« Reply #2 on: Tue, 07 June 2022, 02:32:33 »
I rarely use my little finger... For typing.
Offline Flatiron520
« Reply #3 on: Tue, 07 June 2022, 05:11:18 »
wow you're my idol!
Offline kajahtaa
« Reply #4 on: Wed, 06 July 2022, 11:20:50 »
I use pinky on Ortho and split ergo
With big boards hands are always moving so 3 finger typing seems faster
Offline controller-works
    • Controller.works
« Reply #5 on: Wed, 20 July 2022, 20:51:26 »
I am trying to be more disciplined in my typing technique since switching to a split ortho keyboard (Corne variant). I used to use a full keyboard, and while my typing speed was good, my technique was bad and I moved my hands around a lot.  Now I essentially keep them in place.
Offline butre
« Reply #6 on: Thu, 21 July 2022, 01:28:37 »
left pinky yes, right pinky not so much.  I'll use it for right shift, but not much else.
if I had to lose a finger, it'd be my right pinky.  I can get used to left shift
Offline Tha_Pig
    • Futurepig
« Reply #7 on: Wed, 17 August 2022, 21:08:53 »
I type mostly with my middle fingers and use the pinkies for the SHIFT keys.
I can type pretty fast like that, only looking down at the keys from time to time.
Offline phinix
« Reply #8 on: Thu, 18 August 2022, 03:04:34 »
I think I don't use it at all. Just realised.
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline fortissim2
« Reply #9 on: Fri, 19 August 2022, 14:42:48 »
Alt layout fanboy here, I use my pinkies when typing.
Offline Darthbaggins
  • PC Cannibal
« Reply #10 on: Sun, 21 August 2022, 18:02:36 »
I know I use my left pinky the most for L-shift, Ctrl, CPSL (I use CPSL for a hot key for fast weapon swap in games - CSGO & Destiny 2), but other than those few reasons/scenarios left pinky is my primary little finger to use (my strong finger).
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #11 on: Thu, 06 October 2022, 08:33:45 »
I actually only use my left pinky to hit A sometimes. I don't think I ever use my right.
« Last Edit: Thu, 06 October 2022, 08:36:53 by mohawk1367 »
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline ArchDill
« Reply #12 on: Thu, 06 October 2022, 08:43:55 »
I have been working on training my left pinky and it has been rough.
Still not at the point where I can do it without thinking. Mainly just use it for the "a"
Offline vonk
« Reply #13 on: Thu, 06 October 2022, 08:46:58 »
UK ISO.
I've realised that they don't do much.  In this sentence they did: Both Shifts, Enter, ', and A
I also use my left pinky for z
Q, P and ; are handled by my ring fingers, which I'd never really thought about until now.  ? needs to be my ring finger because I use my right pinky on the Rshift instead of Lshift.
Offline TheWonderBubble
« Reply #14 on: Wed, 12 October 2022, 21:43:28 »
My pinkies actually end up floating usually, but I still use them quite a bit. Shift, QAZ, Tab, P":?[]\, Backspace, and Enter are all relegated to my pinkies...if they haven't been remapped elsewhere. Most my boards put shift/enter/backspace under the thumbs now, for example. Most my fingers actually end up floating, but I still touch type, and usually just have one or two fingers keying off homerow that the rest somehow manage to line up off of. I don't even know how my hands do it, but it works so  :cool:
Shhhhh...my wallet doesn't know I'm here.
Offline RitzyKraken
    • Ritzy Kraken
« Reply #15 on: Wed, 11 January 2023, 12:22:25 »
I never thought about it before, but I don’t think I ever use my pinky. Weird
Artisan wrist rest maker in the USA
https://www.instagram.com/ritzykraken/
Offline jamster
« Reply #16 on: Wed, 11 January 2023, 21:46:21 »
A, control (remapped caps lock), shifts, enter.
Offline Mandan
« Reply #17 on: Thu, 12 January 2023, 11:21:12 »
Left little finger:
Control, Left Shift, Left Alt
Right little finger:
Enter (sometimes), Right Shift, Right Control, all cursor pad keys
IBM F/AT, remapped with xmodmap
Offline Retirba
« Reply #18 on: Thu, 19 January 2023, 23:11:34 »
I use left one for q, a, z, and other keys to the left of those alphas.
Right one for p, ;, / and any keys to the right of those.
I can't imagine ever being faster without the little fingers. Less movement = more speed and accuracy imo.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #19 on: Wed, 25 January 2023, 11:43:36 »
all my fingers are "little fingers" so yes
Just my thoughts
« Reply #20 on: Wed, 25 January 2023, 15:30:01 »
I'm cowboy-typing. Left pinky for left Shift. Right pinky on right Shift key for some symbols on the far right of the alphanumeric keyboard.
I've trained myself to use the right pinky for P, [ ; and '   (actually P, Å, Ä and Ö in Swedish layout), but in practice I do that only sometimes.
« Last Edit: Wed, 25 January 2023, 15:31:41 by Findecanor »
« Reply #21 on: Thu, 26 January 2023, 10:33:07 »
tp4 never uses right shift on flat qwerty board,  ergodox yes, but on flatq, the whole hand kind of has to move.
Offline Sintpinty
    • My Roblox Profile
« Reply #22 on: Tue, 31 January 2023, 20:03:38 »
My little fingers should ideally be replaced with cybernetic ones , i do not use them for typing it feels weird
Just my thoughts
Offline CyCo
« Reply #23 on: Wed, 15 February 2023, 04:13:38 »
Very handy to hit that enter / Rshift button while gaming!
Offline Pretendo
« Reply #24 on: Sun, 09 April 2023, 10:20:21 »
If I'm "typing typing", as in not just pecking out a word or two but actually sitting at my computer keyboard and writing, then yes I tend to use my pinkies. In cases where I'm only entering a few words I'll tend to not properly position over the keyboard, and not use them as much.
The exception is when I'm using a fully manual typewriter, which I sometimes do for journaling. In that case I won't use my pinkies very much except for the shift keys; with the extra force and long travel of a typewriter key it gets to be a bit uncomfortable over time. Once in awhile I'll use them, maybe for the occasional 'Q' or 'P' that's perfectly positioned and leveraged.
« Last Edit: Sun, 09 April 2023, 10:22:01 by Pretendo »
IBM Model F-122 6110347 -- September 13th, 1984
IBM Model M 1391404 -- April 14th, 1988
Rosewill RK-9000
Offline djones
« Reply #25 on: Mon, 17 April 2023, 00:42:02 »
One thing while I learned while recovering from RSI was that using the pinky for one-handed-key-combos (including simple capitalized letters) is a sure fire way to aggravate whatever condition you have. Not only are you contorting your hand but also they are the weakest finger on your hands. For around a decade I didn't use my pinkies at all for typing and even now never use them for the modifier keys.
Offline madrone
« Reply #26 on: Sun, 14 May 2023, 01:07:32 »
Always used all my fingers but now I'll never be able to stop thinking about my pinkies when I type, so... thanks for that :p
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
« Reply #27 on: Wed, 17 May 2023, 16:30:13 »
I don't know what I'd do without my littlest piggies!  :))
I learned to touch type with all my fingers, and when I play Fortnite I use my left pinky for no less than 4 actions. I've been touch typing for 37 years, and so far, no problems.
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
Offline LavenderB
  • I believe in unix control supremacy
« Reply #28 on: Fri, 09 June 2023, 12:54:37 »
I'm not a proper touch typist but I do usually use my pinkies while typing.
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
Offline mathisart
« Reply #29 on: Thu, 13 July 2023, 22:28:28 »
I use my pinky fingers for the left-most and right-most keys, which includes the last column of character keys and some modifiers keys.
