Author Topic: I ruined an entire keyboard... | Alps SKCM White OVERLUBED Sound Test  (Read 6569 times)
Offline c.a.t.
  • All about Keyboards sound...
    • Click and Thock
I recently ruined an entire keyboard while lubing the switches with Krytox... The result, the Alps SKCM White on my Omnikey 102 are completely over lubed... Here a sound test video SKCM White Stock VS Overlubed. Next time, I will listen Chyros and make a soft clean... If you do lube your alps switches, do it lightly!
JS - aka Click and Thock
Offline CaesarAZealad
  • Racc
Re: I ruined an entire keyboard... | Alps SKCM White OVERLUBED Sound Test
« Reply #1 on: Thu, 11 August 2022, 18:24:16 »
Amazing presentation! Sadly it doesn't forgive your crimes. I'm sorry, but we're going to have to execute you : (
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline c.a.t.
    • Click and Thock
« Reply #2 on: Sat, 13 August 2022, 08:06:11 »
Ahaha yeah I know... But it's the third time I disassembly the switches to wipe the residue of lube, and it's still not perfect... I think that a great penalty already :P
Offline Sup
« Reply #3 on: Mon, 15 August 2022, 08:44:05 »
With clickies you never lube the leaf. This will result in a muted sound and less tactility.
current
Coming soon
Offline c.a.t.
    • Click and Thock
« Reply #4 on: Mon, 15 August 2022, 09:22:58 »
Yeah, my mistake. I did not lube the leaf, but to much on the stem... result, some of the lube go on the leaf...
Offline SoSaKing
    • Strumace
« Reply #5 on: Mon, 15 August 2022, 09:29:50 »
What's the best way to lube switches?
[ img ]https://cdn.shopify.com/s/files/1/0611/8060/8749/files/Geek_Hack_Banner.png?v=1666443171[/img]
Offline c.a.t.
    • Click and Thock
« Reply #6 on: Mon, 15 August 2022, 10:14:48 »
Some will say wax mod for the Alps switches but it does not work great for me either... Personally would stand by Thomas Ran opinion and from now, I only soft clean Alps switches... But I'm sure someone will find a miracle product in the future!
Offline Sup
« Reply #7 on: Sat, 27 August 2022, 15:10:27 »
Dry lube is recommended for Alps. I don't remember the exact reason but, something with not being a dust magnet.
current
Coming soon
  • Racc
« Reply #8 on: Sat, 27 August 2022, 18:59:27 »
Unlike the switches themselves, that catch more dust than artisan fans catch Ls
« Reply #9 on: Mon, 29 August 2022, 16:08:13 »
Ultrasonic tubs are really cheap now, $50 on amazon.  distilled water @ walmart.
Or 100% alcohol bath in a zip lock bag.
Offline c.a.t.
    • Click and Thock
« Reply #10 on: Thu, 01 September 2022, 10:53:58 »
Nice great tips! Thanks!
