Author Topic: This year may be biblical  (Read 181179 times)
Re: This year may be biblical
« Reply #350 on: Fri, 16 August 2024, 07:59:06 »
released from permafrost
Permafrost is possibly the thing I worry about the most.
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
« Reply #351 on: Sat, 17 August 2024, 07:24:50 »
Doomsday fish sighted, Southern California.
/dooooooooooooom.
« Reply #352 on: Sun, 18 August 2024, 07:56:15 »
This was during the 2016 El Nino,  much the same this year possibly.
Air temperatures around Mamirauá topped 40C for days and the absence of rain and clouds cooked Amazon waters in the sun. In Lake Tefé, a tributary of, and gateway to, the western Amazon .... Fleischmann .... measured water temperatures above 40C between 3ft and 6ft underwater.
Fleischmann was distraught. “Nobody ever saw anything like this before. I saw 70 river dolphin carcasses along the lake and one animal still agonising. It was about 4pm and very hot. I watched a dolphin swimming in circles, struggling to survive. It was horrible. We didn’t know what to do or how to help it.” Not only was it hot and dry, but more than 7,000 fires raged across Amazonas state.
https://www.theguardian.com/environment/article/2024/aug/17/methane-climate-crisis-amazon-peat-permafrost-vegan-heat-pumps
« Reply #353 on: Sun, 18 August 2024, 08:10:46 »
Holy ****! Having been swimming in rivers and lakes, I know that the water generally gets cooler when you go down a few feet.
« Reply #354 on: Sun, 18 August 2024, 08:14:55 »
Everyone needs to m0ar-veggies fohat, there's no other option.
We essentially need everyone to 99.99% veggie to turn this climate change around.
90% of Amazon rainforest deforestation is due to the demand for grazing BEEF cattle. Brazil is a vassal state, they have no political or economic will of their own, this situation is almost entirely Our-fault ('murica).
« Reply #355 on: Sun, 18 August 2024, 08:37:36 »
Don't listen to Tp4 say it, fine
Here's a famous white guy saying it.
« Reply #356 on: Mon, 19 August 2024, 12:27:45 »
Tp4 can't afford beach front property.
« Reply #357 on: Mon, 19 August 2024, 15:39:40 »
Wait a few years, you may get some.
« Reply #358 on: Thu, 22 August 2024, 21:32:40 »
Had a conversation today, with an ignorant person, which is just about 99% of persons.
Tried to tell him about the ICE MELTING.
Putting it most simply, the Ice takes millions of years to make.  If we lose all of it, we would almost double the heating on the planet, as the blacker ocean increases the heat absorbed, while the missing ice no longer reflecting radiant energy back into space.
<This is a planetary boundary> What does that mean, it means if we cross a threshold, we can not go back. Nature just has to hit the reset button, kill everything, and start over.
His argument literally was, well we have refrigerators, the government can easily turn this around by investing in the technology to transport heat away from the arctic.
He's not a dumb person per se, but there are such MAJOR gaps in people's knowledge, that there is no point of DEMOCRACY, in fact, depending on timing, democracy could well be the most dangerous thing..
If you were trying to save the planet right now.  You'd really just have to kill your way to the top of this Idiotic Heap, then turn this around via Incredible violence.   This must be done, because there's no time, and no alternative.
Tp4 can only watch the world burn, because he's got neither power nor annex to power.  He's got some annex to money, but that's useless, because capitalism is good for nothing but burning. Every modern economic machinery is designed to burn or kill something, this includes ALL of clean energy.
For reference, the most efficient electric heat pump system we produce is only 3:1 , use 1 watt to Move 3 watt of heat.  It doesn't move it into SPACE,  only somewhere ON EARTH.   So even if we had a heat pump big enough, turning it on would instantly kill us.    It'd be like lighting another fire in the burning house we're already stuck in.
« Reply #359 on: Fri, 23 August 2024, 08:17:03 »
At least the arctic and antarctic regions are where the least direct sunlight reaches in.
« Reply #360 on: Fri, 23 August 2024, 13:15:20 »
People tour the ice sheet melting. And you see this guy go, yeaaaahh, when a big piece of ice breaks off.
Stupid stupid humans.
« Reply #361 on: Fri, 23 August 2024, 13:33:43 »
Clade 1-b  Mpox.  10% fatality.  Ongoing outbreak in Africa. WHO has declared global emergency, which is the HIGHEST level of alarm in international health law.
Sweden and Thailand has reported their 1st cases of Clade 1.   Current estimates show only 1% fatality rate, but that's pretty bad already.
Previous US infection was the less deadly Clade 2, 0.2% fatality.
Don't touch anything. Go to costco, GO HOME.
« Reply #362 on: Mon, 26 August 2024, 08:23:33 »
KP.3.1.1 Covid surging across America,  Don't get complacent people.
Stop going outside so much.  Everything fun is computer.
« Reply #363 on: Sun, 01 September 2024, 19:41:05 »
Eastern equine encephalitis,  or EEE.  Spread by mosquitoes. Some states recommending curfew.
« Reply #365 on: Fri, 13 September 2024, 21:23:08 »
Liquified natural gas (LNG) is At least as bad as coal, Likely worse.  Cornell study.
Reason:  Methane Leak across the entire process stack.
Yay Fracking... !! Woooooo !!
Offline phinix
« Reply #368 on: Wed, 18 September 2024, 17:01:39 »
Yep. Pagers yesterday, today walkie-talkies. Impressive!
Tomorrow... airpods?
I would do toilet sits.
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #369 on: Wed, 18 September 2024, 17:06:27 »
Sigh.. Israel wants to find out the hard way, how it only took ~30 people do a 9.11 against the United States, the most powerful country on the planet.
I just hope they don't drag us into this further.  Which harris and trump both seem intent on doing.
« Reply #370 on: Wed, 18 September 2024, 17:19:46 »
Currently don't have a jacket for this Winter due to slipping on ice last year and ripping it. Either need to repair my old one, or steal one off a bum, cause I have a feeling this is gonna be a frigid Winter.
Anyone know where to take a ripped leather jacket to be fixed? I tried a dry cleaners, but they said they don't work with leather.
« Reply #371 on: Wed, 18 September 2024, 17:36:33 »
Tp4 recommends Duct-Tape.
« Reply #372 on: Wed, 18 September 2024, 17:56:11 »
Maybe a shoe repair place?
Offline phinix
« Reply #373 on: Thu, 19 September 2024, 08:34:33 »
Shoe repair places do leather in any form, I used to take purses and jackets for fix there.
« Reply #374 on: Fri, 27 September 2024, 15:22:54 »
Hurricane Helene,  climate change? Nahhhhh..
« Reply #375 on: Fri, 27 September 2024, 16:58:43 »
East Tennessee took quite a hit.
Storms like to drop their rain on the mountains, and it builds up a lot of force racing downhill ....
edit - Newfound Gap, a favorite hiking area at the crest of the Smoky Mountains on the state line (the ridge crest forms the Tenneessee - North Carolina state line) got 9 inches (23 cm) ! and that was in a matter of hours, far inland
« Last Edit: Fri, 27 September 2024, 17:32:35 by fohat.digs »
« Reply #376 on: Fri, 27 September 2024, 18:41:07 »
Where can we go Fohat, if we lose globalization, country wide, the costs will soon make rebuilding untenable. Forget about insurance, you couldn't buy enough materials with infinite $$.
« Reply #377 on: Mon, 30 September 2024, 13:41:29 »
It's about time. Anybody who wasn't already doing it was a fool.
https://www.axios.com/2024/09/26/climate-risk-zillow-insurance-home-listings
« Reply #378 on: Mon, 30 September 2024, 19:46:21 »
« Reply #379 on: Thu, 03 October 2024, 09:47:27 »
Iran missiles.
Sigh...........
Israel's Iron Dome (America), designed (mostly), produced by Raytheon/General Dynamics, interceptor missiles cost between 1 Million - 3.5 Million a piece.
Iran's latest missile attack, ~$100,000 a piece.
Statistically,  KNOWING exactly where a missile is going to be BEFORE HAND, as in TESTING, Not live combat, we only have 70% chance of successful interception.  This is the best math that current technology can achieve.
If you don't know where the missile is going to be, the %% is basically ffff'all.
Isreel's genocide is not going to end well. Unless we send our troops to finish it for them.
« Reply #380 on: Fri, 04 October 2024, 10:57:31 »
Hurricane Helene damage estimates, $250 Billion.
Animal Agriculture, Keep it up !!
« Reply #381 on: Fri, 04 October 2024, 11:23:47 »
Do we really need more explanation on how quickly nature can put us back in the stone ages.
North Carolina relying on Mules to deliver emergency supply.
Where's your fancy electric car now, yo f'n Donkey?
310290-0
« Reply #382 on: Fri, 04 October 2024, 12:12:54 »
Mules have been the engines of choice in the mountains for a long time ....
« Reply #383 on: Fri, 04 October 2024, 12:24:08 »
Mules rescue party, these owners will probably vote for trump.
Not that harris will be any better for climate change.
« Reply #384 on: Fri, 04 October 2024, 17:23:12 »
« Reply #385 on: Fri, 04 October 2024, 17:52:04 »
I think some religious teaching WITH historical context is probably a good thing.
The problem is, that isn't how religion is taught.
« Reply #386 on: Fri, 04 October 2024, 18:49:01 »
"must be the King James Version; must contain the Old and New Testaments; must include copies of the Pledge of Allegiance, Declaration of Independence, U.S. Constitution and the Bill of Rights; and must be bound in leather or leather-like material."
And check out this guy:
« Reply #387 on: Mon, 07 October 2024, 10:08:52 »
Weather Control, Milton, round 2, get ready.
« Reply #388 on: Mon, 07 October 2024, 11:38:16 »
This is Asheville NC, 200 miles inland from all directions.
No where is safe. Where can you run to.  Veggies is our only hope.
« Reply #389 on: Mon, 07 October 2024, 16:35:14 »
Milton, Category 5,  oh it's ON.
Ran through the same ultra-warm water patch that caused Helene to drive so much water.
It's almost like, this is happening exactly like Woke-Experts said they would. Nah, they is hoaxspurts.
Please keep moving to florida, where you can enter the construction trade, to rebuild towns twice no 5 times a year.
« Reply #390 on: Mon, 07 October 2024, 17:54:43 »
Asheville NC
Many of the MAGAs really wanted DiSantis as the sane alternative to Drumpf.
« Reply #391 on: Mon, 07 October 2024, 20:44:28 »
Asheville NC
On the one hand Tp4 empathizes with the severely disenfranchised, which is actually most people, democrap or repooblican.
On the other hand, and this is of course the wrong perspective, one might think, well, they're not people, you don't negotiate with monkeys, they'll always want banana, how many bananas even exist is irrelevant to them, whether it's an inedible plantain is irrelevant to them, they don't know any better.
More correctly, bad choices have strong momentum, and it isn't until humanity crashes into the wall, which we have, that Mass-Famine changes our mind.  Animal agriculture has destroyed this planet.
« Reply #392 on: Tue, 08 October 2024, 20:03:47 »
Milton nearing mathematical limit of hurricanes on the Planet Earth.
They don't care...
While Meteorologists pooping bricks and literally crying on tv.
« Reply #394 on: Thu, 10 October 2024, 07:46:00 »
3 Million people in Florida without power. NICE.  Twice in 1 month.
Oddly more people are MOVING TO FLORIDA...   Do we let them? Let the forces of nature handle it?
« Reply #395 on: Thu, 10 October 2024, 09:45:19 »
I am very curious about how MacDill AFB fared last night, but there seems to be nothing coming out yet.
« Reply #396 on: Thu, 10 October 2024, 10:11:11 »
« Reply #397 on: Thu, 10 October 2024, 15:41:28 »
Any feel the G4 ?
Think it started during Tp4's nap.  Heard a loud tssssss, in the dream? not sure.
« Reply #398 on: Thu, 10 October 2024, 20:39:15 »
Fema budgets, ok seriously, this is just another BAIL OUT structure.  They say "investing" in resiliance. And yet they rebuild in the same place, adhere to the identical codes that failed the first time, OR WORSE, built a cost reduced version that isn't even as good as the original (New Orleans).
That's Bail-Out. It's wasteful and STUPID.
There is going to be rapid weather intensification sooner, and more numerous.  This disaster structure is unsustainable.
If we don't end animal agriculture immediately, No amount of money will bail these people out, you will just run out of construction resources.
Large community damage, takes 10-20 years to recover, many do not recover.
