Author Topic: Efficiency Noodle Initiative  (Read 4868 times)
« on: Tue, 11 April 2023, 08:49:59 »
It takes quite a while to boil pasta/noodles, even just al dente.
Tp4 times approximately:
_ 11 minutes under a roaring boil.
_ 15-18 minutes under simmer.
In order to minimize fuel use:
_ 10 minutes simmer + 5-8 minute rest in pot (zero flame), produces comparable results.
/Climate !
298189-0
Offline Darthbaggins
  • PC Cannibal
Re: Efficiency Noodle Initiative
« Reply #1 on: Tue, 11 April 2023, 10:23:08 »
Also ensure the burner (we use gas) is not flaming out from under the pot but more concentrated under the base - tends to create the best results in speedy boil and consistency in the cook time.
« Reply #2 on: Wed, 03 May 2023, 01:32:31 »
Boil noodles in a pan instead of a pot. Fastest boil.
« Reply #3 on: Wed, 03 May 2023, 07:23:02 »
how does that work?
Offline udller
« Reply #4 on: Wed, 03 May 2023, 07:39:34 »
less water to heat up so it would be a bit quicker probably,
but seriously it also depends on the pasta your cooking. also if its fresh pasta or instant pasta.
« Reply #5 on: Wed, 03 May 2023, 08:16:44 »
how does that work?
Greater surface area in contact with heat source vs volume of water.
- D Trump 2026-10-24
« Reply #6 on: Wed, 03 May 2023, 08:57:21 »
how does that work?
I see so the water boils faster.
Does it also speed up the noodles after it goes in the water ? or is it only boosting the startup phase.
« Reply #7 on: Wed, 03 May 2023, 14:38:54 »
how does that work?
Faster boiling water = faster noodle cook and less fuel consumption. You could always add salt to the water to increase the boil temp by a little bit as well.
