Author Topic: Youtube ads  (Read 4674 times)
Youtube ads
« on: Mon, 12 February 2024, 20:10:52 »
So, what happens now is they Load before the adblocker has a chance to block it. The way you can still defeat them is by hitting F5, on any youtube links, and the adblocker will block it, this way, you only have to watch <1 second of the ad.
Anyone find any other blocking solution that works ?
Re: Youtube ads
« Reply #1 on: Mon, 12 February 2024, 20:26:31 »
On FF I've used a combo of uBlock Origin and AdGuard for many years, and no measure of changes have subjected me to any ads. I have noticed lately YT takes longer to load up pages, i.e. it will spool up the page then hang there for a few seconds not loading anything else. I assume that is where the ad would go, but it only lasts about 4 seconds.
On my phone I use Free Adblock Browser for the sole purpose of listening to music w/o ad interruptions.
Offline Leslieann
Re: Youtube ads
« Reply #2 on: Mon, 12 February 2024, 20:46:13 »
I'm not having any trouble (yet).
Just Ublocker, and I guess my Pi-hole is helping too maybe.
I also use an adblocking dns... But odds are it's ublock doing the lifting.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: Youtube ads
« Reply #3 on: Tue, 13 February 2024, 08:07:23 »
I do have ublock, but the ads are getting through on links to youtube. Hrrm.. Maybe my other pluggin dark-reader is delaying the ublock too long and it's not blocking ?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Youtube ads
« Reply #4 on: Tue, 13 February 2024, 17:28:35 »
Adblock Plus is still working, but the ads do show for a split second.
They must not get through, **** youtube ads.
Offline Leslieann
Re: Youtube ads
« Reply #5 on: Tue, 13 February 2024, 18:02:03 »
Adblock Plus is garbage, has been for a long time.
I do have ublock, but the ads are getting through on links to youtube. Hrrm.. Maybe my other pluggin dark-reader is delaying the ublock too long and it's not blocking ?[/size][/color]
I have Dark Reader, though I leave it turned off, no issues there.
It could be embedded in the links, I use a plugin called Skip Redirect by Sebastian Blask that bypasses referrals and such.
Add this to the custom filters, it blocks most Youtube anti-block. Maybe it will help.
Code: [Select]
youtube.com##+js(set, yt.config_.openPopupConfig.supportedPopups.adBlockMessageViewModel, false)
youtube.com##+js(set, Object.prototype.adBlocksFound, 0)
youtube.com##+js(set, ytplayer.config.args.raw_player_response.adPlacements, [])
youtube.com##+js(set, Object.prototype.hasAllowedInstreamAd, true)
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
