Author Topic: Balatro, the oled ruiner  (Read 7718 times)
« on: Mon, 01 April 2024, 09:17:32 »
NE1 else addicted ?
This makes no sense, it's basically cookie clicker with cards.
307112-0
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: Balatro, the oled ruiner
« Reply #1 on: Mon, 01 April 2024, 09:29:54 »
I mean I feel like it would be addicting it's a game based on poker hands.
Also cookie clicker is like tailor made to send consistent dopamine to your brain for a while with all those increasing numbers.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
« Reply #2 on: Mon, 01 April 2024, 10:24:31 »
Ghhahahahahh Tp4 messed up, didn't know what increase rank of card meant.
Changed 2 Aces into 2x 2s.  That's what it meant.... wth gon' do with 6x 2s in the deck.
__foams @ mouth.
307114-0
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Mon, 01 April 2024, 10:28:59 »
It's not at all a cookie clicker, that's a type of AFK game, which Balatro absolutely isn't.
That said I really enjoyed it though! Even as a former poker player I thought it was really well done.
« Reply #4 on: Mon, 01 April 2024, 11:16:26 »
Sum'o deez cards yo, why do they even exist?
Red card is performing excellently, skip booster = +3x multi, it's @ 30x multi already for Tp4. Seems good early game, since early boosters don't help much, just skip.
The only legendary joker Tp4 saw so far is only 21 multi, so this seems almost as good, and you can unlock / use right away.
307116-0
307118-1
« Reply #5 on: Mon, 01 April 2024, 12:01:29 »
OK, for future reference,  ANKH, spectral card,  perfect copies, including the charged multiplier, so if you have a +45 multi, it will guarantee you a +45 copy.
It copies a random joker, destroys all other jokers, but if you only got a big card, then you can sell the other 4, and guarantee the copy.
Tp4 just copied his RED card with that much charge, now guaranteed 90x multi, this is awesome.
307120-0
« Reply #6 on: Mon, 01 April 2024, 12:53:44 »
Wth? Tp4 already won? Guess the base mode is just really easy.
307122-0
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Mon, 01 April 2024, 17:29:24 »
Yeah, it's not so difficult, I beat it on the third attempt iirc.
« Reply #9 on: Mon, 01 April 2024, 22:15:37 »
Oh, yea, this looks good.
307135-0
« Reply #10 on: Tue, 02 April 2024, 08:19:12 »
Turn off CRT Bloom, this setting alone consumes Double the GPU power.
« Reply #11 on: Tue, 02 April 2024, 09:23:44 »
//Addicted, can't stop.
This card is so good.
307141-0
« Reply #12 on: Tue, 02 April 2024, 09:51:01 »
This is absolutely ridiculous now. Royal flush with 4 cards.
307143-0
« Reply #13 on: Tue, 02 April 2024, 12:16:54 »
Okokokok. Doin' pretty gud' so far.
Egg,___________+3 sell value per turn (neg)
Four Fingers, ____all flush and straight played with 4 card
Raised Fist, _____add double lowest rank card in hand to multi, (neg)
Supernova, _____add number of hand type played (flush) to multi
Swashbuckler,____add sell value of cards to the left to multi (neg)
Smeared Joker, __diamond = heart, spade = club suit (poly)
Ancient Joker, ___played suit = 1.5x multi, suit req change each round. (neg)
Blueprint, ______copies right joker abilities.
Cardsharp, ______x3 Multi if card hand (flush) has been played
All flush build, the problem is, down to 5 card hands, it feels dicey.
Save temperance-tarot for fool-tarot, for extra +$50 when it shows up.
What's the hardest hitting hands you guys have gotten? This build is around ~300K. Don't think it has durability, it feels like it'd get outpaced by the Levels-creep soon. Can't use any complement jokers because Negative spectrals won't help, can't afford to reduce hand size anymore, it's already too dangerous for flushes.
307145-0
« Reply #14 on: Tue, 02 April 2024, 13:04:39 »
Welp, give up. There's just no way.
307147-0
YUP, DIED
307149-1
Offline _rubik
« Reply #15 on: Tue, 02 April 2024, 22:27:44 »
Oh boy I can see this game getting addicting. I just played a few hours after seeing this post.
I had to pull myself away after a few hours. It really is a fun and sticky game, especially on 4x game speed. I completely lost myself for a bit there
« Reply #16 on: Wed, 03 April 2024, 04:30:25 »
It is too late.
« Reply #17 on: Wed, 03 April 2024, 07:30:52 »
OMG, it's wensday? Wha happened to Tuesday..
« Reply #18 on: Wed, 03 April 2024, 09:29:16 »
Vangelis Blade Runner tracks are excellent background for Balatro.
« Reply #19 on: Thu, 04 April 2024, 18:13:06 »
Once you get used to playing, the whole game is just flipflipflipflipflipflipflip.  The sound is so satisfying.
Even with the music off, you can just calmly be enveloped in, and absorb The Balatro.
« Reply #20 on: Fri, 05 April 2024, 12:33:12 »
What are the odds.   Got a +3 lvl Straight flush on a blind skip, never thought it would amount to any use. Then here it is, Spade Royal Flush.
Sumtin's up, the game is messing with you.
307207-0
307209-1
« Reply #22 on: Thu, 11 April 2024, 10:45:32 »
It's stifling how early you have to commit to a build.
Offline chyros
  • a.k.a. Thomas
« Reply #23 on: Thu, 21 November 2024, 10:09:45 »
Picked this game up again after not playing all this time, started a fresh profile. Think this was my second run, this build worked pretty well.
I had to use my camera, couldn't make a screenshot. The mult was somewhere along the lines of 5000x I think. The mobile version is very nice as well.
« Reply #24 on: Thu, 21 November 2024, 12:14:34 »
2Mil is pretty high without hacks or seeding.
Offline chyros
  • a.k.a. Thomas
« Reply #25 on: Thu, 21 November 2024, 15:22:22 »
Yup, just a completely vanilla run. But it was easy, virtually impossible to score less than 1M per hand. Only 19 cards, almost all of which spades, good flush level, 132 multiplier for the Erosion joker, and many subsequent multiplier multipliers. I eventually died because I didn't realise that you could run out of cards to play, i.e. it doesn't shuffle your deck if you've played through everything xD .
