Author Topic: Gaming PC Parts discussion thread.  (Read 303583 times)
Re: Gaming PC Parts discussion thread.
« Reply #900 on: Tue, 30 September 2025, 10:12:00 »
Well, where dat power goin' ??
314697-0
« Reply #901 on: Wed, 01 October 2025, 11:49:31 »
Wonder if setting dac sound buffers actually do anything to reduce latency.
« Reply #902 on: Fri, 03 October 2025, 14:35:25 »
Tp4's thinking if the 77 s95f comes down from $3500 to $2500 for BF ?
Thoghts??
Online Computer-Lab in Basement
  • Live long and prosper
« Reply #903 on: Fri, 03 October 2025, 14:41:04 »
Stop talking to yourself
tp thread is tp thread
« Reply #904 on: Fri, 03 October 2025, 17:20:07 »
There is no assurance that the world outside of Tp4 actually exists.
The Beginning, The Tp4, The End...
The same cycle every "possible" construct goes through.
« Reply #905 on: Fri, 03 October 2025, 18:11:31 »
if tp4 posts a comment and no one reads it, was it ever really posted at all?
« Reply #906 on: Sat, 04 October 2025, 13:55:59 »
Compare to masturbation vs actual intercourse.
“So I decided to go to Iraq. I flew to Iraq. I was extremely brave. In fact, so brave I wanted to give myself the Congressional Medal of Honor. I said to my people, am I allowed to give myself the Congressional Medal of Honor?”
- Donald Trump 2026-02-19 Rome, Georgia
Offline Leslieann
« Reply #907 on: Sat, 04 October 2025, 21:39:27 »
Cache, memory timing/control, core balance, etc..
I was thinking it was high but remove the cores and it's mid 20watts, which isn't really that bad for what it's doing.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Sniping
« Reply #908 on: Sun, 05 October 2025, 17:29:12 »
Thoghts??
you're switching from one 77 oled to another right? I'd say its not worth it to buy retail to make this upgrade unless you can sell your current TV for close to the price of the new one.
« Reply #909 on: Sun, 05 October 2025, 20:59:40 »
The s95f has higher peak highlight limit that's why.
For HDR, it's about the same, but for SDR, the limiter makes a big difference.
« Reply #910 on: Mon, 06 October 2025, 12:11:57 »
Finger over buy for AW3225QF 32” 4K 240Hz
$765
/Must resisssst.
It's 4K, it's 240hz, it's qd-oled
The 1 thing,
holding Tp4 back, is Display Stream Compression.
-but realistically, are we really going to get that sweet 80gbps display port soonish?
« Reply #911 on: Mon, 06 October 2025, 17:06:18 »
According to the Steam hardware survey, close to 60% of people are still using 16gb of RAM
Offline phinix
« Reply #912 on: Mon, 06 October 2025, 17:40:55 »
I only upgraded to 32GB this year.
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #913 on: Tue, 07 October 2025, 08:08:24 »
Tp4 barely uses the 32gb.
That said, Tp4 believes 32 is prudent because it allows you to run at least 2-3 vms without much trouble.
Offline Leslieann
« Reply #914 on: Tue, 07 October 2025, 22:22:06 »
I won't say 16 is bad, it's not, but it's pretty much the bare minimum on Windows 11.
Honestly, 24 would probably a perfect number for most people if it was practical, but it's not, so 32 it is. Keep in mind I'm also not saying you need 64, that's pretty much where 32 was a few years ago. It's overkill.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #915 on: Wed, 08 October 2025, 10:08:48 »
24gb is happening because of lpddr5 soldered ram for AMD APUs.
There are no other packages that makes sense.
32gb on a laptop, in most cases, IS a bit much/ wasted.
Offline Sniping
« Reply #916 on: Thu, 09 October 2025, 11:44:06 »
been playing cloverpit for the past few days, pretty fun one if anyone needs a game rec. I think my gaming PC itch has mostly been scratched for now. small chance I swap to 5080 fe and itx down the line while they're still cheap and available but I don't think it'll happen honestly.
« Reply #917 on: Thu, 09 October 2025, 22:51:13 »
I feel like if 24GB RAM had been normalized when DDR3 was around it would have become the standard over 32GB
« Reply #918 on: Tue, 14 October 2025, 10:21:06 »
5070ti having only 12gb on mobile, and 5070 and below with 8gb.
Upsetting. Completely non-viable gpus.
There shouldn't be any gpu below 16gb.
« Reply #919 on: Tue, 14 October 2025, 12:01:14 »
Pantherlake,  pffffffff.  LAME..
This thing isn't remotely competitive,  AMD will kick them in the potato.
Amd has so many levers at this point, Intel needs to really make 1 thing work, stop with all this nonsense, Nvidia partnership, Arc, E-cores.
Offline Leslieann
« Reply #920 on: Sun, 19 October 2025, 10:34:15 »
Nvidia is having problems selling 8gb GPUs and has completely scaled back production of those cards.
GOOD!
Intel needs to really make 1 thing work, stop with all this nonsense, Nvidia partnership, Arc, E-cores.[/size][/color]
They need partnerships to get out of the hole they dug.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #921 on: Sun, 19 October 2025, 15:04:20 »
They need Chinese people. They don't have enuff Chinese people to catch TSMC.
What they aught to do is, offer all the mid-lvl TSMC guys 5-10Mil a piece to come to Intel.
Then go to Chinese mainland, and do the same, sneak out all their top SMIC guys.  According to reports, the SMIC guys are even stronger engineers than the TSMC guys.
This is a joke, because it's impossible to get them out, they'd get asssinatzed.
Offline Sniping
« Reply #922 on: Tue, 21 October 2025, 23:05:32 »
my deathadder v3 pro developed a scroll wheel issue that seems somewhat common. found a reddit thread that advised scrolling fast in one direction for a minute, which ended up fixing my mouse. found another deathadder locally for $20 with a similar issue and applied the same fix and it worked. lol
« Reply #923 on: Wed, 22 October 2025, 00:56:46 »
Just resolder a new wheel. they're cheap.
But overall, razer mice are not well designed.
For logitech, at least they have a pretty decent software to detect games and profiles, which is a stand out feature.
For razer, their software is so crap, that it's barely usable, and their tuning isn't any better than the Million other off brand boards that use the same sensor and mcu.
« Reply #924 on: Wed, 22 October 2025, 08:16:37 »
Polly want to archive a few win10 isos before they do something silly.
« Reply #925 on: Wed, 22 October 2025, 10:43:41 »
Easily bes controlr on market. Performance / $$ wise.
314977-0
« Reply #926 on: Thu, 23 October 2025, 21:42:12 »
240hz 32" oled monitor or 165hz 77" oled tv.
mm.....
Offline phinix
« Reply #927 on: Fri, 24 October 2025, 08:39:57 »
mm.....
77" :D
« Reply #928 on: Fri, 24 October 2025, 12:42:03 »
It's tough cuz they all perform so differently.
Considering the Samsung 500hz small one too. but, it's just tooooo small. But hades 2 runs at 360fps sooo. hrrrm.
« Reply #929 on: Fri, 24 October 2025, 19:36:09 »
OMG, whaaa. Spectre and Meltdown mitigations drop 4790k by 10% /GASP... that's alottt. Old CPUs already have trouble hanging on.
« Reply #930 on: Fri, 24 October 2025, 23:52:18 »
Wow, 10% is 10%, you can reallllly feel it in high fps games like hades 2.
« Reply #931 on: Sat, 25 October 2025, 19:06:12 »
Ok, so Tp4 has setup this old pc to do 1-thing, play Hades 2,  New win10 install, HAGS turned off.
4790k 4.8ghz, 16gb 2400mhz, 1060 2100mhz 6gb,
Best settings, with spectre and meltdown win10 mitigations turned off.
This thing can sustain 210fps - 360fps(game-cap) @ 2560x1440,  It's cpu-bottlenecked. The 1060 actually has a bit more juice, which is good because then we avoid the gpu 99% utility lag spikes.
1350rpm gpu fan, barely audible, 64C sustained temp, open chassis, 750rpm case fan, 360rpm cpu fan.
ULLM enabled, vsync off, you don't need vsync as long as you're above 200fps, even on 60hz screens, you can barely see the tearing. You can use fast-sync, because it's consistently high enough fps, but it actually feels less smooth than off because of the frame-pacing will be in odd numbers.
1000hz controller wired.
Realllly good experience.
« Reply #932 on: Tue, 28 October 2025, 00:08:43 »
This just looks disgusting. How could a multi billion dollar company make such ugly products.
315027-0
315029-1
Offline Leslieann
« Reply #933 on: Tue, 28 October 2025, 23:07:42 »
Looks are subjective but it's  quite bold to go against all trends of front glass and mesh. It looks like a 10 year old case.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #934 on: Tue, 28 October 2025, 23:17:11 »
It's so obviously ugly. Nothing about it is coherent.
It gives the impression, let's paint 2/5th of a car then stop, BECAUSE.
Offline phinix
« Reply #935 on: Wed, 29 October 2025, 15:04:04 »
What case would you say is beautiful?
« Reply #936 on: Wed, 29 October 2025, 16:07:47 »
Mass market, Phantek evolv x2,  Deepcool - CH270
Less massmarket, Ncore100air
315043-0
Offline Leslieann
« Reply #937 on: Wed, 29 October 2025, 19:02:26 »
Just off the top of my head...
For a budget cases: Lian Li A3 in wood version and the Jonsbo D32 PRO
Other nice cases, Lian Li o11 series, Hyte Y60 and Y80, Ncase M1, Fractal North.
Just browse Newegg's best sellers you'll likely see something you like and that doesn't even touch on the ultra high end, custom stuff the mini-Itx people are building.
« Last Edit: Wed, 29 October 2025, 19:04:38 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #938 on: Wed, 29 October 2025, 23:14:50 »
LCD pc monitors are so profitable. They put basically bunk in there and charge a $300 upmark from offbrand. None of them do LED light strobing correctly either, and most of them don't have dimming.
Offline phinix
« Reply #939 on: Thu, 30 October 2025, 04:21:39 »
Yep, those are pretty.
I would like to have some nice itx or mATX retro case, waiting for FLP03 - mATX version.
Or something with more wood, that dark wood version of Fractal North is nice.
« Reply #940 on: Thu, 30 October 2025, 09:27:09 »
Tp4 is of the opinion most wood use in cases don't look good.
Wood is always some shade of Brown.  The only color that goes with is snow-white. And the proportion has to be high, so it needs to be alot of wood, which cases can't have because of venting. So they all look half-butt.
« Reply #941 on: Thu, 30 October 2025, 09:32:20 »
Wood is brown.
True, but each family of brown colors mates well with other groups of colors. For instance, the siennas, being more reddish, go better with reds, while umbers look better with blues and greens.
Also, raw wood is almost always improved by being oiled.
Offline Leslieann
« Reply #942 on: Thu, 30 October 2025, 21:09:06 »
In cases but only because of cost.
You can get wood in a natural black, red, blue, purple, even green.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #943 on: Thu, 30 October 2025, 22:08:06 »
Those are all wood, that has a Color-ish + brown. Tp4 maintains that it's mostly different shades of brown, be it red-ish or blue-ish.
« Reply #944 on: Fri, 31 October 2025, 07:39:23 »
I consider the great attributes of wood, regardless of whatever finish or stain it wears, to be strength and resilience. Neither of those are very important when wood is used cosmetically rather than structurally, but I can imagine that wood's vibration-dampening ability might help soften the environment around the case.
Offline Leslieann
« Reply #945 on: Fri, 31 October 2025, 08:05:48 »
I used to think that before I went down the rabbit hole that is exotic woods.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #946 on: Fri, 07 November 2025, 07:27:01 »
It "LOOKS" ok...  but honestly, this takes up MORE footprint, AND requires matx concessions.
315226-0
Offline Leslieann
« Reply #947 on: Fri, 07 November 2025, 08:15:31 »
So much wrong with this design.
I can totally hear the higher ups telling the engineer to design it and I get why they did but clearly no one bothered considering what the end result would be or how they would market it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #948 on: Fri, 07 November 2025, 08:35:16 »
Like post-modern architecture at its worst.
« Reply #949 on: Sat, 08 November 2025, 08:03:55 »
On lower end gpus, Non-native resolution scaling can take up to 1-3% total performance.
Hades2, 1060, 6gb 2100mhz.
300 fps 2560x1440 into 3840x2160 screen.
315 fps 2560x1440 into 2560x1440 (Display does the scaling).
ThassssALOT.. 5% realm
/Gassssp
