Author Topic: Are all HHKBs Topre?  (Read 5748 times)
Offline blondie
« on: Fri, 27 June 2025, 14:08:37 »
I just discovered that HHKBs are Topre. I have had, if I remember correctly, an HHKB lite 2 USB for probably over 20 years. Now it seems that people have strong emotions towards Topre keyboards. But,I don't remember any particular feeling when first starting to type on this keyboard, nor none now. So, I am wondering if this one is a Topre keyboard or not. Or, maybe I just don't have sufficient sensitivity in my fingers (more likely).
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Offline YALE70
    • Hackjob
Re: Are all HHKBs Topre?
« Reply #1 on: Fri, 27 June 2025, 14:50:03 »
IIRC, the early PS/2 HHKBs and the Lite/Lite 2 models all used standard rubber domes. Everything else (with the sole exception of the Studio) is Topre.
Raiding your local thrift store.
Alienware Area 51 R2 | ASUS Prime X670-P WiFi | EVGA RTX 3090 KINGPIN Hybrid (2100 MHz @ 1000 mV) | AMD Ryzen 9 7950X (5.7 GHz) | Thermaltake Toughliquid 360 | G.Skill Ripjaws S5 32GB DDR5 (6000 MHz) | Dell D1500EF (1500W)
Model F Labs Classic F104 | Northgate OmniKey Ultra-T | HHKB Professional Hybrid Type-S | IBM Model F AT | Unicomp Classic Model M | Datacomp DFK515
Mad Catz R.A.T. 8+ ADV | Sanwa Gravi Wireless | Microsoft Trackball Explorer | Logitech Trackman Marble FX | Logitech Cordless Optical Trackman | Elecom Huge Wireless
Offline blondie
« Reply #2 on: Mon, 30 June 2025, 13:43:29 »
Thanks! Now maybe I should look for a more recent HHKB to try out.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Mon, 30 June 2025, 14:09:03 »
You are correct the HHKB Lite models are regular rubber dome KBs. A far cry from their Topre brethren IMHO.
« Reply #4 on: Mon, 07 July 2025, 16:47:52 »
Except, Topre = Rubber dome.
There is no difference. Don't let advertising fool ya. That's exactly what you're buying.
Been saying it for years.
It's an obsolete technology.
No rapid trigger, low polling rate, inconsistent over time as dome wear hardens unevenly and shifts the weight of keys.
Induction rod keyswitches are the future.
Offline bansheetango
« Reply #5 on: Tue, 15 July 2025, 08:41:59 »
HHKB Studio is MX.
Offline Rob27shred
« Reply #6 on: Tue, 15 July 2025, 14:55:43 »
I mean you're not wrong Topre sure does use a rubber dome for the actuation & return of the key. Although it is disingenuous to lump it in with cheap membrane rubber dome KBs. Topre OEM domes are made from better rubber & have a more consistent weighting from dome to dome, they do harden a bit over time causing them to feel heavier than their stated weighting. Also a lot of Topre enjoyers seek out vintage aged domes since they are supposedly more consistent feeling dome to dome & before the explosion of aftermarket domes would give you weightings otherwise unavailable. I've never been huge on Topre myself, but would never go as far as saying they're no different than cheap membrane rubber dome KBs.
« Reply #7 on: Fri, 18 July 2025, 07:18:42 »
Also a lot of Topre enjoyers seek out vintage aged domes..
They're the same people who buy lifestyle brand speakers.
It would be too offensive to say they're morons, but their intelligence is at approximately the same lvl.
:p
Offline TheSoulhunter
  • ~ GHOST ~
« Reply #8 on: Sat, 16 August 2025, 10:24:16 »
*Glorified Rubberdome
Interesting to see you are still onto this. Just like 10y ago when I was last active here :D
