Author Topic: What is best latest TKL keyboard kit I could buy?  (Read 126295 times)
Offline phinix
« on: Sun, 27 July 2025, 08:52:52 »
Anything stands out recently?
Looking for some good kit, like Frog TKL for example.
EDIT
So far I tried:
• NK Classic TKL
• Gem80
• Tiger Lite
• Linky87
• Tiger 80
• Epomaker TH87
• Nuphy Node 100
• Keychron C1 Pro 8K
• Keychron C2 Pro 8K
« Last Edit: Fri, 10 July 2026, 03:56:46 by phinix »
Re: What is best latest TKL keyboard kit I could buy?
« Reply #1 on: Sun, 27 July 2025, 13:09:34 »
https://mechkeys.com/products/aesco-a67-a83?variant=46341756420319
Aesco 67/ 83
Has rapid trigger,  Induction rod key switches.
This is state of the art.  comes in 67 and 83 variant.
Look at that PCB, all them chips.
313787-0
313789-1
313791-2
Offline phinix
« Reply #2 on: Sun, 27 July 2025, 13:28:12 »
Aesco 67/ 83
Looks cool, tp, but I need TKL - my brain cannot live without nav and cursor clusters in standard layout.
« Reply #3 on: Sun, 27 July 2025, 13:36:57 »
ERgodox. Best keeb.
Tp4 rejects the existence of TKL. Tp4 no longer lives in that universe.
Offline omf
« Reply #4 on: Mon, 28 July 2025, 18:41:40 »
Offline phinix
« Reply #5 on: Tue, 29 July 2025, 04:23:15 »
I've been looking at the same thing. The current actually-obtainable list seems to be:
* Solar80
https://clickclack.io/collections/new-arrival/products/gb-solar-80-mechanical-keyboard-kit
* Neo80
https://www.qwertykeys.com/products/neo80
* KBD8X MKIII
https://kbdfans.com/collections/kbd8x-mkiii/products/kbd8x-mkiii
* Enter80
https://clickclack.io/collections/in-stock-keyboards-smart-collection/products/in-stock-kezewa-enter80-mechanical-keyboard-kit
* Gem80
https://nuphy.com/products/gem80
oh, thanks for listing those.
Gem80 looks nice, I'm very tempted.
« Reply #6 on: Wed, 30 July 2025, 13:27:36 »
What makes those boards expensive is the low production scale. The stufffs inside isn't much more advanced/premium vs mass market boards available nowadays.
Offline SugaryBrownie
« Reply #7 on: Thu, 21 August 2025, 03:07:43 »
* Solar80
* Neo80
* KBD8X MKIII
* Enter80
* Gem80
How's Gem80? It looks pretty nice from the website. The pink onelooks lovely.
Offline wataru
« Reply #8 on: Thu, 28 August 2025, 02:50:07 »
best quiet tkl ive ever tried was realforce 87u by far but it's hard to find in europe and might be slightly out of budget. you might need to get one second hand on discord or something like that.
abko and niz also have electrocapacitive tkl keyboards but idk the quality
Offline phinix
« Reply #9 on: Thu, 28 August 2025, 18:14:45 »
I have 3 87u topre.
I wasn't asking about quiet - I hate quiet keyboards.
Offline HungerMechanic
« Reply #10 on: Sat, 30 August 2025, 11:53:12 »
Have you tried the Neo80 keyboard yet? That is an interesting budget board. [It's not 'budget' quality.]
That is the only one in your list that I have experience with. I also have a KBD8X MKII. What I can say is that I don't see how the MKIII stands out in today's market, but it is probably a 'solid' board.
Offline phinix
« Reply #11 on: Sun, 31 August 2025, 11:40:52 »
I just got NK Classic TKL keybaord kit - looks really solid, good quality. I need to build it, hopefully in next few days.
« Reply #12 on: Sun, 07 September 2025, 19:23:56 »
I have a Classic TKL - typing on it right now.
It's a solid board, but I find the typing experience a little harsh. Like maybe the plate doesn't flex like it should. But I'd be curious to see how it goes with you. It could be that the Hyperglide Browns I am using with this build are snappier than pre-tooled.
Offline phinix
« Reply #13 on: Mon, 08 September 2025, 03:14:50 »
Yeah, I was hoping for a nice and soft typing, but feels like its like typing on concrete :(
i used very pronounced tactile switches - CK x Haimu Pastel Thistle - those are even more tactile than Boba U4T. Maybe I should try linears to see how those feel. i like how heavy this plastic case is and overall estetics, but disappointed a wee bit by that hard typing. Maybe I should take out that rubber bottom sheet to see if it going to sound deeper?
I love how kbdfans Tiger lite gaming version sounds and feels like, but its a bit too light, it needs some kind of weights inside.
Is there any other plastic case keyboard that sounds so deep, feels soft when typing and is a bit heavier than Tiger Lite?
« Last Edit: Mon, 08 September 2025, 03:17:02 by phinix »
« Reply #14 on: Mon, 08 September 2025, 07:46:05 »
Yes, I'm in the same position. I admire the lightness of the new Tiger Lite. But the plate is so flexy that the F-row mostly doesn't work, they're not engaging the PCB.
It's also like a lot of these cheaper plastic-cased keyboards aren't really designed for tactiles. Which probably benefit from a soft bottom-out. Linears may work better with the Classic TKL. And many people say that the bottom rubber is integral to good sound, but I have no idea. Certainly, it is possible to modify the sound of that board using dampening materials.
Soon, I will try to switch over to a Transition Lite TKL. It seemed like it would offer a flexy / soft typing experience, but I didn't really get a chance to try it out. If I don't like the switches I have in there right now, maybe I will migrate my HG Browns to it.
Honestly, if you are primarily using tactiles, it is probably best to get a top-mount keyboard with a high-quality polycarbonate or PP plate. That is where my best typing experiences with tactiles are. No matter how much more it costs, top-mount and a really good flexy plate are the best.
In your case, instead of purchasing a Tiger Lite and a Classic TKL, it may have been better to pool your money into something like the Diversity TKL:
https://geekhack.org/index.php?topic=125085.0
That seems promising for tactile mounting, and was very reasonably-priced in GB.
« Reply #15 on: Mon, 08 September 2025, 07:52:54 »
Another thing: You can take one of those super-budget Ajazz or Attack Shark TKLs and strategically fill it with sorbothane. You end up with a soft and flexy keyboard with a creamy sound.
See this post here:
https://www.keebtalk.com/t/whats-on-your-workbench-today/12656/2517
I think that the value proposition for tactile switches is: buy the cheap ultra-budget AliExpress TKLs during sales. I'm talking $60 CAD max for one of the fully-outfitted wireless ones, or about $45 CAD max for a barebones.
All they need is sorbothane dampening, and maybe some work on the stabilizers. Then, you have a TKL that can compete with "budget customs," the entry-level TKLs.
If you need to move up from there, move right up to a $2-450 USD top-mount TKL. Get a custom-made PC plate for it, if you have to. That level of quality is the only functional reason to buy something more expensive than a super-budget TKL. The latest generation of entry-level sub-$100 customs don't offer much special for tactile builds beyond aesthetics.
Offline FOURRINGS
« Reply #16 on: Tue, 09 September 2025, 00:42:29 »
Anything from MODE is nice.
Offline FOURRINGS
« Reply #17 on: Tue, 09 September 2025, 00:43:00 »
... ALSO MACHINA! they use some very nice materials and finishes.
Offline phinix
« Reply #18 on: Tue, 09 September 2025, 03:13:32 »
No, its ok, I don't use tactiles as much as I did in the past. I prefer linear Oil Kings. I only put those tactiles in that keyboard as I used all linears in other keebs :) I only have one set of tactiles and then 4-5 sets of linears, so will need to try and swap those on Classic TKL and see how linears feel like.
Offline brainrotgames
    • brainrot games
« Reply #19 on: Wed, 01 October 2025, 01:51:17 »
Here are some of the best TKL keyboard kits available right now:
Frog TKL: Excellent build quality, customizable, and a unique design.
KBD67 Lite: Affordable, easy to assemble, and has customizable RGB lighting.
Offline phinix
« Reply #20 on: Thu, 02 October 2025, 05:12:44 »
I'm slowly leaning towards throwing all my keyboards through the window...
I've been trying to build that Classic TKL last night - having problems with stabilisers. They are very sluggish, I did not over lube them. I played with differnet caps, had pbt caps swim in boiling water (pbt PBS set) to try and bend them a bit, cause noticed that cap stems were kinda not aligning with stab stems. Got that right, then had to bend stab wires a bit, cause it looked like those were pushing stabs sliders to the edge of it and scratching on those walls too heavily.
Then after 2 hours of trying things I got it right - they worked fine - but then I realised that there is something wrong with actual build - stabs felt ok when straight on pcb, but as soon as I put on plate, they started to get stuck! WTF!!!!!!
That Classic TKL has screws for pcb+plate, so I took those out, moved plate around to see when it stop "blocking" stabs, there are moments were it works for one stab, but not for all... How the hell plate can have impact on stabs? I think only moment would be when moved to one side, it moves actual switch away from the center of stab and somehow make it all sluggish/stuck.
That's two different sets of stabs (TX AP Screw-in and clip-in), different caps (pbt PBS set, SA, HSA, GMK), switches... I'm on the edge to give up  :'(
Or sell it all and buy pre-built keeb, maybe I'm too old and this **** is not for me anymore...
« Last Edit: Thu, 02 October 2025, 05:18:55 by phinix »
« Reply #21 on: Sun, 05 October 2025, 08:55:56 »
I'm really sorry to hear about your difficulties with the Classic-TKL.
I had read of some similar problems that others encountered. It was specifically said that earlier releases of the Classic-TKL had very tight plates, which made it difficult to install stabilizers. So maybe you received one of those.
My Classic-TKL functions fine, but I find it to have a harsh mounting setup. I think that the design needs to have several revisions in order to stand out in today's competitive budget keyboard market. I wouldn't get discouraged just because of your Classic-TKL issues. It's not representative of custom keyboards in general. If anything, they are mostly becoming easier to work with [Neo80 being one example].
BTW if you are looking for a plastic-cased keyboard with a bit more weight to it [via dampening] that is softer, try the Transition-Lite. Go for 1.2mm PCB if you want maximum softness. It comes in a variety of colours, and it does not seem to have stabilizer issues.
Offline phinix
« Reply #22 on: Mon, 06 October 2025, 02:21:04 »
Thanks, I didn't know there was known issue with this keyboard. I emailed Novelkeys to see what they could help.
I'll have a look at this Transition-Lite board, looks similar to Tiger Lite.
« Reply #23 on: Mon, 06 October 2025, 14:11:20 »
Yes, I bought the Transition Lite around the same time as the new Tiger Lite.
They are comparable, but not the same.
For one, the Transition Lite comes with more customization material. At least mine did. It was possible to dampen the board, using the materials in the kit. This is in contrast with the Tiger Lite, which was very barebones. Just the minimum number of parts.
The big difference is in the PCB. The Transition Lite had an option of 1.2mm PCB. This PCB is not known for having better sound or consistency than a 1.6mm. However, it is softer than a 1.6mm. So the Transition Lite can be built both softer and quieter than the Tiger Lite, using stock parts.
For maximum softness if going that route, for tactiles or whatever, omit installing any optional 'switch-ordering plates.' Those extra plate films that keep switches more stable tend to increase the hardness of the plate.
Offline phinix
« Reply #24 on: Mon, 06 October 2025, 17:06:04 »
Cool. I love my Tiger lite, but only one thing I would change is the weight - I would add some heavy filler, or even some kind of weight.
Is Trasitions Lite heavier than Tiger Lite?
« Reply #25 on: Tue, 07 October 2025, 22:05:14 »
At least the ones I have, the Transition Lite is much heavier. I think it's mainly from the dampening material, or whatever layers come with the kit.
The Transition Lite case is made from polycarbonate, which might make it a little heavier and more sturdy than the Tiger Lite.
There was only one real issue in building the Transition Lite: the manufacturer did not submit the PCB information to VIA. So, to configure VIA, you need to download a special .JSON from a specific location. This is annoying. I can probably find / send it for you.
If I can find the time, I will post a sound test. Mine is configured to be muted-sounding. Soft, flexy, and muted. I think it's stronger at being a soft and muted keyboard than a flexy one. Might as well leave that to the Tiger Lite.
Offline phinix
« Reply #26 on: Wed, 08 October 2025, 03:44:39 »
I still have one brand new Tiger Lite Gaming I need to build, but issue with stabs stopped me getting to another board.
I narrowed it down to probably plate issue - it sits very clsoe to stabs on their sides - left side of left stab and right side of right stabs, so looks like plate is very narrow on those sides, could be it. I contacted Novelkeys and guys confirmed issue with ver1 of the plate - I got ver2 so should be fixed, but there is possibility that manufacturer still gave me ver1, so guys were kind and are sending me new v2 plate, I hope this is going to solve the problem.
« Reply #27 on: Wed, 08 October 2025, 09:54:13 »
Yes, sorry to hear about these stabilizer issues. They can be a pain.
Good to see that you are receiving a new plate. That might help. My next keyboard might be a Transition Lite with MX2A Browns. Should be lively, and non-harsh.
Offline phinix
« Reply #28 on: Sat, 11 October 2025, 20:50:56 »
I think I will also buy Keychron V3 Max TKL, fully assembled with banana switches. I will mount my oil kings, but will order full kit, so I don't have to deal with stabs...
« Reply #29 on: Sun, 12 October 2025, 12:25:47 »
Yes. The Keychrons are there for people who don't feel the need for custom stabilizers.
Let us know how it goes, especially comparing with the Tiger Lite and Classic TKL!
Offline phinix
« Reply #30 on: Tue, 14 October 2025, 13:37:58 »
Got that plate, unfortunately its the same as the one I have. Classic TKL is not for me then, going on ebay :(
First problem with plate, then harshness of typing - its like typing on steel plate, I dont know why it feels like that...
Need to find pre-built board with thocky, deep sound.
« Last Edit: Tue, 14 October 2025, 16:45:14 by phinix »
« Reply #31 on: Tue, 14 October 2025, 17:38:49 »
I tested a pre-built budget board that had excellent sound. Take a look at this:
https://www.keebtalk.com/t/what-did-you-get-in-the-mail-today-part-2/20502/1283?u=hungermechanic
Offline phinix
« Reply #32 on: Wed, 15 October 2025, 11:36:01 »
Holy mother of creamy keyboards!
Done, ordered one.
Thanks for a hint, as soon as I listened to your typing, I ordered one :D
« Reply #33 on: Wed, 15 October 2025, 17:01:00 »
Yes, I can't bring myself to modify it in the slightest. Because it has perfect sound and consistent feel already. I want to use it as a 'reference' keyboard.
I have read, and searched to find that similar keyboards are being sold on AliExpress for $20 CAD less. However, there is no guarantee that they are tuned to the same specifications as the Linky87. The AliExpress versions also offer black and beige cases, I think, so they do have that in their favour.
There's an 'array' of thocky budget keyboards sharing almost the same design, but the details on any individual tuning are not given. So the Linky87 provides a known build.
It's possible to get something similar by modifying a $60 CAD 'fully-built' Attack Shark M87 Pro. However, you will manually have to fill it with sorbothane!
https://www.keebtalk.com/t/whats-on-your-workbench-today/12656/2517?u=hungermechanic
This is a decent keyboard in stock form, not having the sound of the Linky87. With sorbothane, it gets close. So you'd have to do that, and lube your switches. The Linky87 is deeper and more marbly, but you wouldn't notice unless you compare them side-by-side.
« Reply #34 on: Wed, 15 October 2025, 17:07:14 »
BTW, in terms of the more expensive kits, I have been hearing good things about the 'Spyder TKL.'
I only heard about it recently:
It seems to offer a more traditional sound. I think there's a number of builds with aluminium plates, which is a 'traditional' build of the 2010s.
Since a number of people are doing tactile builds with it, it's probably not all that harsh. What a crispy and poppy sound from those Browns in the first video. It wasn't my preference when I started with Browns, but I got used to the aluminium plate.
Offline phinix
« Reply #35 on: Wed, 15 October 2025, 19:50:56 »
If I was going for a higher quality kit, i would go for Frog TKL. I had 2 in the past and let it go.
If I could get Frog and perfectly tuned stabs on it, I would keep it.
I read that Geon was going to make lighter version of Frog, but I dont think its has been done yet.
Offline phinix
« Reply #36 on: Mon, 20 October 2025, 16:13:33 »
Is it me, or does this blue theme keycaps board is white and that green theme is kinda creamy/beige?
Green caps version was out of stock, so I ordered blue one, like yours, but I wish it was beige. I wonder why they did not make black one.
« Reply #37 on: Mon, 20 October 2025, 19:58:21 »
My monitor is not tuned right at the moment, but yes, I think the green theme was creamy-beige.
Basically, they seemed to be offering two major variants. A white keyboard with bluish-colours [Blue Honeywell and Blue / Orange] and a beige keyboard [Beige and Cream, Green].
So the 'beige' keyboard was supposed to be more retro. And this was the case on AliExpress as well. I was glad for the Blue Honeywell on the white one, as I've always wanted to try that. I think it corresponds to a GMK set.
I would prefer a black or blue keyboard, though, and none of the retailers offered a variant like that.
Probably avoided black in order to be 'different.' Most budget Chinese keyboards are black. So, offering white and beige options helps differentiate them. Gray would have been nice, however.
Right now, I am deciding between a Classic-TKL and a Neo80 cu for an MX Brown build. I can see the strengths of either, but the Neo80 cu costs 3x more.
Offline phinix
« Reply #38 on: Tue, 28 October 2025, 09:13:31 »
Holy shiiiit, it just came in!
Stock switches are crap, gonna swap them with mine, but this board sounds unbelievable!
« Last Edit: Tue, 28 October 2025, 09:17:33 by phinix »
« Reply #39 on: Tue, 28 October 2025, 14:51:05 »
Yes. I don't use linears a lot, so I can't really evaluate the stock switches. Maybe I'll try it later.
But my concern is that it may not sound as good without hand-picked switches. It will be interesting to know if your preferred switches sound as good / better.
Offline phinix
« Reply #40 on: Tue, 28 October 2025, 17:04:15 »
I'll mount oil kings and see how those sound.
Offline phinix
« Reply #41 on: Wed, 29 October 2025, 18:05:04 »
Daaamn, I think this keyboard is made for SA keycaps and some heavy linears.
Oil kings with 22mm long 80g springs and SA keycaps I picked Filco SA. I'm waiting to catch cream case version and will move those on, but even on white case it looks good.
AND sounds fantastic!
I will add photos tomorrow.
« Reply #42 on: Thu, 30 October 2025, 12:46:37 »
Now I'm wanting to try this. I even have the perfect SA keycaps for a white base.
Offline phinix
« Reply #43 on: Thu, 30 October 2025, 16:58:08 »
I need heavy springs and cannot find one.
TX 22mm 85g. Or even 90g.
Aliexpress kinda has those, but I dont want to order from there.
« Reply #44 on: Sun, 02 November 2025, 13:06:46 »
Yeah, there's less selection for 22mm springs.
Offline phinix
« Reply #45 on: Tue, 16 December 2025, 07:34:23 »
After few days of use, Linky87 developed some weird scratchy/squeeky noise in few mods.
So I bought Gem80 - when it came, it felt premium, heavy, well made. Sounded amazing, deep thicky sound, perfect.
But, for some reason after few days of use, again, few mods started to be scratchy.
Seriously, mods/stabs issue is driving me nuts.
I guess its time to go back to the roots - I have one brand new Tiger lite gaming keyboard I have not built yet, plsu two sets of stabs, TX I think.
Need to nail down those stabs perfectly.
« Reply #46 on: Tue, 16 December 2025, 10:07:33 »
Be careful with that Tiger Lite. Mine has an F-row that won't secure switches. So the F-row is basically inoperative.
I think these budget kits, especially what's coming out in the last few months, might be compromising too much in order to keep the price down.
It may be why boards like the Neo80 are so popular. I don't hear about too many issues with them. I almost bought a second one during a recent sale.
As you say, it's important to stick with the fundamentals. If the stabilizers aren't tuned right, then it doesn't matter the cost of the board.
Offline zegonix
« Reply #47 on: Wed, 17 December 2025, 02:10:12 »
i sure have a huge problem with the neo and qwertykeys boards. they use proprietary firmware and an obfuscated chip (they removed the markings and replace them with their branding) so you can't just program your own firmware.
i for one, like to maintain my keymaps as plaintext, so i can version it using git. also i want to be able to flash my keyboard without using a mouse, so i want to be forced to use via(l)!
Offline phinix
« Reply #48 on: Fri, 02 January 2026, 15:13:07 »
Hey, now they have Sunset Black version too.
Offline phinix
« Reply #49 on: Wed, 07 January 2026, 17:52:02 »
OK, test number.... 113.
Tomorrow new keyboard will be delivered - Nuphy Node 100 (low profile, beige version).
I hope mods on that will be ok. However, it is kinda messed up full size cause cursor cluster is moved :(
I hope that those red switches going to be heavy enoughf or me. I wonder if low profile needs lighter spring for same result as standard profile.
