Author Topic: Best mug design  (Read 18769 times)
Best mug design
« on: Sat, 28 March 2026, 11:21:34 »
Thoughts?
-Handle, No handle?
-Glass, Ceramic?
-Metal, Enamel?
316454-0
Re: Best mug design
« Reply #1 on: Sat, 28 March 2026, 12:33:49 »
Glass actually has lower thermal conductivity than ceramic, but because they are transparent they tend to look nastier.
I tend to be afraid of pouring hot liquids in glass because of regular glass is temperature-sensitive.
Perhaps the ideal mug would be made of cloudy heat-resistant glass.
Re: Best mug design
« Reply #2 on: Sat, 28 March 2026, 12:47:37 »
Like this one? They're all Borosilicate if it's used in a mug.
316466-0
Offline TheSoulhunter
  • ~ BOOO ~
Re: Best mug design
« Reply #3 on: Sun, 26 April 2026, 09:46:52 »
I use these Bodum Glas cups for tea since the 90s...
316857-0
And this 400ml Yeti Stainless for coffee...
316855-1
A Ghost From The Past
Re: Best mug design
« Reply #4 on: Tue, 28 April 2026, 21:45:55 »
It makes one wonder. Does the ideal tea exist at a constant temperature, or is the flavor an ever moving // evolving construct as the tea cools.
  • ~ BOOO ~
Re: Best mug design
« Reply #5 on: Wed, 29 April 2026, 13:43:08 »
Interesting thought...
I usually prefer my coffee hot, but my tea lukewarm. I slurp my coffee, but sip my tea.
Offline phinix
Re: Best mug design
« Reply #7 on: Tue, 05 May 2026, 04:16:39 »
Definitely, tea flaover changes with temperature. Obviously, you can change the flavor by pouring boiling water right away after boiling point (which is not ideal), or pour it over 30secs later and you will already feel the difference.
Then, when in a cup, I can feel the difference, with hot tea, or lukwarm - flavor changes a bit.
Offline phinix
Re: Best mug design
« Reply #8 on: Tue, 05 May 2026, 04:19:47 »
I have these and like them very much
https://www.amazon.com/Double-Walled-Glass-Coffee-Handle/dp/B07YXQGZBZ/ref=dp_prsubs_d_sccl_2/143-9001916-6165936?pd_rd_w=R2pFb&content-id=amzn1.sym.42aa4ac9-41cf-40f2-844a-256751b93dbf&pf_rd_p=42aa4ac9-41cf-40f2-844a-256751b93dbf&pf_rd_r=VA7JEP6BQ8GJ03FAV2Y8&pd_rd_wg=ONsnL&pd_rd_r=d50f8c46-09de-44c5-8edc-2b12e8aa9581&pd_rd_i=B07YXQGZBZ&tag=lkcs00-20&th=1
Yep, I use them too. Different shape, but double wall glass is great for keeping your beverage hot for longer. WHole life I've been using regular ceramic mugs, but about 5 years ago I bought one of those and difference is huge. They also look nice aesthetically.
I like to drink my coffee with a bit of milk, so once stirred with a teaspoon, I like to watch how it swirl inside :) Like a sandstorm! :D
Re: Best mug design
« Reply #9 on: Tue, 05 May 2026, 08:41:12 »
My ideal mug would be an amalgam of these 2.
I prefer the blue handle because it is flat-ish in cross-section with a longer, flatter top section which makes it easier to grab and to hold - besides being more comfortable on the fingers.
But aside from the handle shape and configuration I like the clear one better because the top lip is slightly curled outward. Also the markings are pretty cool!
I am indifferent to one being slightly taller and slimmer in circumference and the other being squatter.
- Plato
Offline SwearWolf
Re: Best mug design
« Reply #10 on: Sun, 21 June 2026, 17:24:14 »
The ideal mug for me is a ceramic mug with a large handle and a silly joke I can te-he at!
