Author Topic: Just some help with CM Quickfire Rapid  (Read 4046 times)
Offline tehsprayer
« on: Fri, 09 March 2012, 17:14:04 »
[ Attachment Invalid Or Does Not Exist ] 43343[/ATTACH]
So I have this keyboard.
I'm pretty new to mech. keyboards so...Are these keycaps laser or painted?
Are they ABS or PBT?
Also, is there anyway to sand off the print on the keys or no? (Something that wont take long.)
Is there a way to take off the logos too?
REΛLFORCE 87U - uniform 55g
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #1 on: Fri, 09 March 2012, 17:28:51 »
They are ABS pad printed keycaps. You're probably better just replacing the stock keys with a set of doubleshots, KBC PBT, or WASD keycaps.
Here's a thread on covering the board with vinyl if you want to mod your board that way.
Oh, and welcome to Geekhack! :welcome:
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline kwang2009
« Reply #2 on: Fri, 09 March 2012, 17:32:36 »
They are lasered and then filled. They are ABS and I would not try any sanding. I also love the stock keys, but PBT might be the answer. EDIT: I am sure they are lasered.
« Last Edit: Fri, 09 March 2012, 17:41:46 by kwang2009 »
Offline biochem
« Reply #3 on: Fri, 09 March 2012, 20:51:18 »
Quote from: ripster;540560
Somebody take a pic of the S, D, F keys like the others in the Key Reference Wiki and I'll add it.
How is this?
[ Attachment Invalid Or Does Not Exist ] 43354[/ATTACH]
Filco MJ2 tenkeyless (blues)
Heatware
Offline kwang2009
« Reply #4 on: Fri, 09 March 2012, 21:00:20 »
http://i44.tinypic.com/oh4njl.jpg
They turned out weird.
Offline kwang2009
« Reply #5 on: Fri, 09 March 2012, 21:01:48 »
Quote from: biochem;540648
How is this?
(Attachment Link) 43354[/ATTACH]
His are good.
Offline biochem
« Reply #6 on: Sat, 10 March 2012, 08:16:37 »
Quote from: ripster;540821
Look like the same molds as for the Filcos.
I had the same conclusion after a close-up comparison.
Heatware
Offline tehsprayer
« Reply #7 on: Sat, 10 March 2012, 08:44:02 »
bump                     .
Offline biochem
« Reply #8 on: Sat, 10 March 2012, 18:23:46 »
Added to the Wiki:
http://geekhack.org/showwiki.php?title=Key+Reference+-+Pics+and+specifications+for+various+manufacturers+keys&redirect=no#CoolerMaster+Quickfire+Storm
ripster: RE the wiki, the key caps are completely interchangeable between the Filco and Quickfire. I have the Filco keycaps on my Quickfire.
OP: Your objective for sanding the key caps is unclear. Do you want blank key caps with no lettering or smooth key caps with lettering? If the former, you can buy blank key caps from WASDkeyboards that will fit your keyboard. If the latter, Filco key caps are smoother than the Quickfire key caps. You can easily purchase Filco key caps in the classifieds subforum by putting up a WTB thread.
Heatware
« Reply #9 on: Sat, 10 March 2012, 18:31:21 »
[ Attachment Invalid Or Does Not Exist ] 43501[/ATTACH]
« Reply #10 on: Sat, 10 March 2012, 20:21:46 »
Quote from: thegunner100;541652
(Attachment Link) 43501[/ATTACH]
what keycap set is that.
« Reply #11 on: Sat, 10 March 2012, 20:24:04 »
The stock filco set.
