Author Topic: Anyone ever tried this? Poor solution I know.  (Read 2653 times)
Offline shogrran
« on: Tue, 20 March 2012, 01:35:32 »
So I just noticed the first early signs of wear on the rubber coated surface of my CMStorm QFR. I have expected it and it is inevitable as I have sweaty and very acidic hands. It's actually unexpected that the coating has lasted me this long before it even showed any signs.
I was just bumming around the house one day and I spotted a roll of Scotch brand tape and I thought hmm... maybe I can use this.
The Scotch brand tape... what the company calls "invisible" or "magic" tape I think is ideal... as it does not leave any residue when you peel it off. It also isn't glossy and that helps a lot in hiding that you have tape on the surface.
Here is a couple of pics TAKEN WITH A LOUSY CAMERA PHONE (for god sakes photo quality nazi's! a lot of you aren't photographers... you're just probably rich teenagers with a Nikon.) You probably can't even notice that there's tape on the lower left corner of the keyboard covering the entire area where my palms rest as I type.
Pro's its easy to take off and it is also easy to replace. It acts like those screen protectors you put on your smartphone screens.
Without flash
With flash
Cons... its fugly and may drive obsessive compulsive people crazy.
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
Offline laffindude
« Reply #1 on: Tue, 20 March 2012, 01:37:09 »
This is exactly why I hate the finish on the Quickfire Rapid.
Offline shogrran
« Reply #2 on: Tue, 20 March 2012, 01:39:17 »
Quote from: laffindude;551230
I kinda like it actually. I know it fades but then the non-coated plastic has it's own share of problems with shine anyway.
[SIGPIC][/SIGPIC]
Offline whiskerBox
« Reply #3 on: Tue, 20 March 2012, 01:47:18 »
Check out this thread some people are using plasti-dip on there QF's
« Last Edit: Tue, 20 March 2012, 01:49:20 by whiskerBox »
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline shogrran
« Reply #4 on: Tue, 20 March 2012, 02:23:47 »
Quote from: whiskerBox;551235
Yup I read about that plasti-dip. Would like to try it out one day but... plasti-dip isn't commonly available in hardware stores from where I come from. And I also want to hear about the later-on effects of doing plasti-dip. I am imagining it will flake off at some point. I think doing plasti-dip would require a bit of preparation on the surface as well - pretty much like painting plastic. I'll try plasti-dip or some other alternative when the time comes that I can really sacrifice the QFRs current finish. As I would want tot sand it down and prep the surface before coating it with anything.
[SIGPIC][/SIGPIC]
« Reply #5 on: Tue, 20 March 2012, 04:11:11 »
Quote from: shogrran;551251
Um.... That's kinda the point of plasti-dip, you just put it on, and it works, and peel it off if you "no like"
« Reply #6 on: Tue, 20 March 2012, 09:05:16 »
Remember that the longer tape stays on, the harder it is to get off.
And most solvents that remove tape residue will damage plastic.
Of course, I would imagine that you have to/want to replace this tape at least once a year, if not a lot more often than that.
- Oliver Willis 2026-08-01
Offline shogrran
« Reply #7 on: Tue, 20 March 2012, 11:21:23 »
Quote from: tp4tissue;551287
Hmm... well in that case that is a good solution. But has anyone tried to peel it off if you "no like"? I slightly am doubtful it will go off that easily when it comes in contact with an almost same rubberized surface. Is it washable by some mild solvent or something?
[SIGPIC][/SIGPIC]
Offline shogrran
« Reply #8 on: Tue, 20 March 2012, 11:23:37 »
Quote from: fohat.digs;551368
That is kinda why I though Scotch brand "invisible" tape is best. Its different from the regular tape... I have never encountered it leaving residue on any surface. The "stickyness" is almost the same as the "stickyness" you find in good quality post it notes.
But yea... Its best to replace it frequently anyway. It doesn't have to be yearly though. :D tape is cheap.
[SIGPIC][/SIGPIC]
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #9 on: Tue, 20 March 2012, 13:58:13 »
Same problem here with Rosewill:
http://geekhack.org/showthread.php?28274-Rosewill-9000-Case-shining
This is why I am lusting after one of those Aluminum / Steel cases
Offline shogrran
« Reply #10 on: Tue, 20 March 2012, 15:46:08 »
Quote from: i3oilermaker;551595
doesn't aluminum mark with sweat as well?
[SIGPIC][/SIGPIC]
Offline Cereal
« Reply #11 on: Tue, 20 March 2012, 17:14:14 »
http://geekhack.org/showthread.php?28453-Modding-My-Keyboard!
and
http://geekhack.org/showthread.php?28250-CM-Storm-Wrapped-in-CF-Vinyl
I really like these mods, probably harder to apply/remove then then that  plasti-dip stuff though.
CM Storm Quickfire Rapid
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #12 on: Tue, 20 March 2012, 18:24:45 »
You can get cheaper vinyl that is easier to remove than DI-NOC, but it'll be harder to apply initially and won't last as long from wear and tear. Big sheets of it are really cheap to "practice" with. Avery and some other companies make it for both signs and for scrapbooking hobbyists and whatnot.
As for removing the rubbery coating from the Quickfire... you may just be able to get a nice looking finish from some VERY fine grit sandpaper and using even pressure and consistent strokes. I'd take that off anyways if I was applying any other method.
