Author Topic: How can you like Topre?  (Read 25954 times)
fossala
  •  Guest
« Reply #100 on: Thu, 12 April 2012, 13:13:05 »
This has been looked into here.
http://geekhack.org/showthread.php?27474-Topre-rubber-dome-stiffening
Cherry blacks shouldn't get stiffer over time. As springs wear they reduce in resistance. You may need to re-lube them though.
« Reply #101 on: Thu, 12 April 2012, 13:40:00 »
Quote from: fossala;573880
this whole stiffening + softening issue is what held me back from an hhkb, No replacement parts.. I get that the failure rate is low, but wtf, how hard is it to send out some springs and rubber caps.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #102 on: Thu, 12 April 2012, 14:05:31 »
Quote from: tp4tissue;573904
Is it just my imagination, or do Realforce keyboards (not sure on HHKB) not have discrete domes? Pretty sure you have to slice up a single sheet of domes to replace most of them. Can't find a photo off-hand.
I was sure I'd used dome keyboards with an actual PCB under the domes – when popping out a dome to clean it, there was a proper PCB there with traces. These were the ones with a carbon coating on the dome ceiling, and over time they would go less and less time between cleans before the carbon coating stopped conducting current.
Bore Awards
