Author Topic: Laptop Backlight issue  (Read 1896 times)
Offline gamesquirt
« on: Sun, 29 April 2012, 01:39:16 »
I have a HP envy 3005-xt
For some reason, occasionally, when the backlight is turned on, a few of the keys such as b and n dont register as being pressed 98% of the time.
Also when the backspace is held down it only deletes once.
All these issues only happen when the backlight is turned on, if i turned it off it acts normally.
I thought id post here before i take it back to the store and ask them about it.
« Reply #1 on: Sun, 29 April 2012, 01:44:29 »
Quote from: gamesquirt;585379
take it apart, and check the keyboard cable is seated correctly. If that isn't the problem, you can order a replacement keyboard part from HP.
Offline gamesquirt
« Reply #2 on: Mon, 30 April 2012, 01:50:07 »
I dont want to take it apart as that will void the warranty. But thanks for the suggestion, i can mention that to the retailer.
Is there any other possiable reasons this could be happening.
Also has anyone sent anything to HP for repair? how long does it take?
Thanks
« Reply #3 on: Mon, 30 April 2012, 02:45:05 »
Quote from: gamesquirt;586112
Thanks
Are you sure removing the keyboard will void your warranty? I've serviced hundreds of HP (though mainly their higher-end lines of probook and eitebooks) and on most of them, the keyboard is designed to be user-removable. Oftentimes there is a ram chip under there. Usually for HP, the bottom cover and keyboard can be easily removed with a phillips head screwdriver and a steady hand, and the rest of the computer is normally secured with torx T6 screws.
Now, I haven't sent anything to HP for repair, but I have had lots of people send things to me for warranty repair. HP overnights us the parts, so we can maintain a turnaround time of ~3-5 business days, though it varies. When we send computers off to HP for repair (usually in the case that it's been too damaged, and HP might want to replace it for the customer) it takes a bit longer, though I can look up the exact numbers if you like.
That said, tp4tissue makes a good point: This could be an issue with the keyboard cable just needing to be re-seated, although in my experience, the issue could potentially also lie with the keyboard itself, or even the motherboard.
