Author Topic: DAS got new keyboard?  (Read 2454 times)
Offline Neo.X
« on: Wed, 29 August 2012, 10:13:59 »
Just saw on NCIX that DAS keyboards are now called " Click Pressure Point Mechanical Keyboard " and "Soft Pressure Point Mechanical Keyboard ".
I amd just wondering that is this just a new name or it's a new model?
Anyone have an idea?
Thanks
All those keyboards will be lost in time....
Offline Dajm
Re: DAS got new keyboard?
« Reply #1 on: Wed, 29 August 2012, 10:30:25 »
It's just a way of describing it. They're still using Cherry blues and browns.
Offline Neo.X
« Reply #2 on: Wed, 29 August 2012, 10:44:48 »
Thanks.
But, in NCIX, "Professional Model S Click Pressure Point Mechanical Keyboard" is not in stock while this one "Professional Model S Mechanical Keyboard" is on sale. Makes me wonder what's the difference between them.
BTW, the sale price for "Professional Model S Mechanical Keyboard " is 79.99CAD, pretty nice price. Too bad it's a blue switch, I can't use it in office.  :'(
Offline Dajm
« Reply #3 on: Wed, 29 August 2012, 12:30:29 »
Yeah, I don't know where they get their product designations from.
As far as I can see, on the official DAS website the descriptions haven't changed (daskeyboard.com)
Offline therecorder
« Reply #4 on: Wed, 29 August 2012, 12:32:16 »
http://www.daskeyboard.com/products/
Perhaps it's the first one in the second row ("Professional - Media - Soft").
Offline Dajm
« Reply #5 on: Wed, 29 August 2012, 12:35:38 »
Should be pretty easy to figure out which is which: DAS offers, aside from the Mac-keyboard, only 4 models.
They offer keyboards with blue switches or brown switches, each come in a labeled and in an unlabeled version.
If you're not sure what they mean by "Click Pressure Point", just check the switch type, that way there's no confusion.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Wed, 29 August 2012, 13:52:37 »
Do the 'new' ones on ncix have media keys? Perhaps they are just deciding to only carry one version of Das and are phasing out the older version and using some different wording in some attempt to distinguish them apart?
« Reply #7 on: Thu, 30 August 2012, 06:16:08 »
There's a difference between Product distinction and making **** up.
