Author Topic: Does any one have pictures of....  (Read 1459 times)
« on: Tue, 11 September 2012, 09:56:18 »
White pbt keycaps by feng,   I think they're kbc, not sure
and
White WASD abs keycaps
TOGETHER......
I need a picture with the two TOGETHER, for color comparison.  ;D
I only own the pbt set by feng, and they're a little bit too BLUE, almost ultraviolet. LOL  :))
So I am thinking about buying a WASD set, but I want to make sure they're not super blue/violet as well.
Offline karljs
Re: Does any one have pictures of....
« Reply #1 on: Thu, 13 September 2012, 19:26:42 »
Unfortunately I can't produce a picture, but I do own a WASD with a bunch of white keys. To my eyes they are pretty much pure white. I placed them on a 96 bright sheet of printer paper and they are nearly a match.
That said, you might be more perceptive than I am ...
« Reply #2 on: Thu, 13 September 2012, 21:42:37 »
Hey man, thanks, I think I might just go ahead and order a single key to make sure. You guys should have a free samples program, just send small bits of clipped plastic, not the full key.
