Author Topic: Gigabyte Aivia Osmium  (Read 7257 times)
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« on: Fri, 12 October 2012, 23:08:07 »
Anyone seen/used one of these boards? I've been lurking for info about it for some time, but I can't even find where it's made just so I can guess which OEM makes it...
So, what's the info about it? A dealbreaker like those Cooler Master keyboards which are actually good, or just a manufacturer joining the mechanical gamer keyboards bandwagon with iOne, just like Logitech just did a few weeks ago?
And by the way, couldn't Gigabyte get an uglier and longer name for a keyboard than that?
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline Human
Re: Gigabyte Aivia Osmium
« Reply #1 on: Fri, 12 October 2012, 23:32:21 »
This Osmium are probably from iOne.
BTW, this board isn't Gigabyte first mechanical board. They did it few years back, but stopped due to poor demand/market.
Also, I am also pretty sure that Logitech isn't made by iOne. More of a same OEM of Corsair k60/90.
BTW, the name is already pretty short. Razer Blackwidow Ultimate [insert model here] is longer.
« Last Edit: Fri, 12 October 2012, 23:36:28 by Human »
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #2 on: Fri, 12 October 2012, 23:44:49 »
Never seen that before but that spacebar is ugly -_-
-Enzo Ferrari
Offline laffindude
« Reply #3 on: Sat, 13 October 2012, 02:06:51 »
Not many people know about this board. I believe it is an iRocks with those 3 1.5 left modifiers.
Offline Skull_Angel
« Reply #4 on: Sat, 13 October 2012, 02:09:05 »
3 1.5x mods!? What a monstrosity  :confused:
« Reply #5 on: Sat, 13 October 2012, 03:12:15 »
k60 and k90 is pretty surely iONE based on the bottom row. irocks doesn't make that bottom row. they make the weird bigger ones.
Offline wetto
« Reply #6 on: Sat, 13 October 2012, 18:18:37 »
Sure is short, but sure is an ugly one, almost as ugly as the previous board's appearance.
And are ya sure the k60 and k90 aren't made by iOne? I've seen like hundreds of RMA cases on both and they're not very well made from what I've heard, in comparison to the CM boards such as the Quickfire Rapid.
Besides, the keyboard itself looks like a piece of failure. For start, look where the hell they put those macro keys!
My collection:
Offline Human
« Reply #7 on: Sun, 14 October 2012, 01:46:29 »
Modifier wise, it is different(normal Cherry style vs Costar/iOne steel wire style)
Switch mounting wise, also different(5pins PCB mounted with aluminum plate vs typical steel mounted)
Keycaps wise, it also quite different(Corsair's one as below with significantly less curvy keytop while older BWU series using a tall DCS profile keycaps with quite curvy surface with a thin and fragile "X" stem, newer iOne make board having durandale tyle of "+" stem), you also notice that Corsair is putting a "-" on their numpad "5" instead of normal "."
Layout wide, it is still different(1.5,1.0,1.25,6.5,1.25,1.0,1.0,1.5 vs iOne's known 1.5,1.0,1.5,6.0,1.5,1.0,1.0,1.5)
« Last Edit: Sun, 14 October 2012, 02:00:04 by Human »
Offline TheQsanity
  • SmallFry Lovin'
« Reply #8 on: Sun, 14 October 2012, 02:10:52 »
a very sexy wrist rest on there... and fancy lights too! Must cost a lot.
SmallFry! <3
Offline wetto
« Reply #9 on: Mon, 15 October 2012, 11:22:11 »
Nope it doesn't, US$ 120 is kinda like normal for these illuminated keyboards, but, what really makes me not like it is the fact that the macro-keys are all the way up there and that the USB HUB and Audio extension is on the right side of the keyboard, instead of behind it.
My collection:
