Author Topic: Quickfire brown - problem ?  (Read 2065 times)
Offline xyril
    • Youtube Channel (full of typing and gaming vods)
« on: Mon, 24 December 2012, 16:51:59 »
Hey i just own this keyboard "Quickfire Rapid" Brown (TKL)   for almost a month or two.
Came out of the box, it was perfect . Keys feels smooth and lil bumpy. But now I can start to feel that  the keys is abit harder to press ......  my blues are not so   stiffs compare to this.
whats the problem :( ... how can i fix it? Also the spacebar is like jigger.
sry for mah english . 3rd language .
Offline Hyde
  • White Tofu Extraordinaire
Re: Quickfire brown - problem ?
« Reply #1 on: Mon, 24 December 2012, 16:59:32 »
Ehhhhhhh have you spill anything over your keyboard by any chance?  Because I can't think of any reason why the key will become more stiff.  Is it just 1 key or a lot of keys?
Also what do you mean that spacebar is like "jigger"?
Offline xyril
« Reply #2 on: Mon, 24 December 2012, 17:17:50 »
space bar rattle . sry
No i dont spill anything like water. I think my rice (hmmm) . i should able to clean it up dont i ?
« Reply #3 on: Mon, 24 December 2012, 17:35:32 »
LOL.. Jigger......
 If your space bar is Bent very badly, "mega-Jiggers",  then try the Hair dryer method to straighten it a bit...
Lube usually doesn't help if the jigger is caused by flatness.
HAHAHA.. jigger...
Offline xyril
« Reply #4 on: Mon, 24 December 2012, 20:00:14 »
so to clean the keyboard. i need to take the keycaps and clean the keyboard lol?
« Reply #5 on: Mon, 24 December 2012, 20:33:31 »
um... take the cap off,  press the stem down, and spray the inside at multiple angles with compressed air..
If that doesn't do it, You really have to de-solder and replace the switch.. you cannot open the key switch because on this keyboard it's plate mounted.
Plate mounting provides for greater stability, but is difficult to work with.
« Reply #6 on: Tue, 25 December 2012, 19:07:51 »
Is it all keys or just some keys feel stiffer?
Shouldn't really happen.  And if it does happen gradually, you would be unlikely to notice (unless you switch between other keyboards with similar switches).
Perhaps it is just finger fatigue?  Maybe just use it as normal for a few more days and see if it gets back to normal.
« Reply #7 on: Tue, 25 December 2012, 19:17:31 »
;D you're just making stuff up now..
« Reply #8 on: Tue, 25 December 2012, 21:06:47 »
Ssshhh...
