Author Topic: Caps Lock Num Lock and Scroll Lock all lit up? (noppoo choc mini)  (Read 12416 times)
Offline NickVsYou
Anyone know what could be causing this? my keyboard is no longer working, completely out of the blue.
Offline TotalChaos
  • Indy Game Coder
Re: Caps Lock Num Lock and Scroll Lock all lit up? (noppoo choc mini)
« Reply #1 on: Mon, 07 January 2013, 19:17:47 »
My brand new Rosewill keeps doing that but its temporary.  It is caused by the cable connector being loose.  The electrical connection keeps getting made and broken over and over and sometimes the lights come on and get stuck.  Usually they just flash at me.
I donno if ur problem is the same.. But try wiggling the cable and pressing it in firmly and see if that helps.
Offline codymaust
« Reply #2 on: Mon, 07 January 2013, 19:19:00 »
Have you tried simply unplugging and replugging?
Sometimes my QFR will will light up and not work after my laptop comes on from hibernate/sleep.
« Reply #3 on: Mon, 07 January 2013, 22:00:34 »
Can you try the keyboard on a different computer?  Or even simpler, have you tried rebooting?  Has this keyboard got a detachable cable?  If so, can you try a different cable?
Offline jabar
« Reply #4 on: Mon, 07 January 2013, 22:01:54 »
I've had my Choc Mini "hang" (num lock frozen) on boot exactly once... a reboot solved it. Maybe also disable num lock enabled by default in the BIOS, if it's an option?
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #5 on: Mon, 07 January 2013, 22:14:20 »
try direct solder to board if it doesn't go your way... that whole detachable cord thing is such a fad.. impractical...
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #6 on: Mon, 07 January 2013, 23:04:57 »
Any luck with it out of the 3 threads on the issue you've created?
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline stingrae
« Reply #7 on: Tue, 08 January 2013, 12:45:22 »
If it works on other computers, it might be worth trying a pci usb card another possibility is that a usb setting is on or off that isn't meant to be this seems a bit of an oddity though.
No one would recommend soldering on your motherboard but they would suggest solder on your noppoo but anyway since it works on other pcs this isn't an issue.
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline NickVsYou
« Reply #8 on: Tue, 08 January 2013, 21:47:51 »
Not working once again
How i feel
« Reply #9 on: Tue, 08 January 2013, 22:56:30 »
Still under warranty?  RMA??
« Reply #10 on: Wed, 09 January 2013, 19:53:38 »
Did you try a different keyboard on the computer and it worked?
Maybe try a different USB port with the 'broken" keyboard.
