Author Topic: Which Cherry MX-Switches share same springs/stems?  (Read 9369 times)
Offline Aufwind
« on: Mon, 14 January 2013, 14:40:08 »
Is there any kind of list about which MX-Switches do share stems/springs?
lysol pointed out some details here http://geekhack.org/index.php?topic=39214.msg764347#msg764347 but I am to stupid to follow it up in plain text. :D
A format like this
ResultStemsSprings
MX-RedsMX-BlacksMX-Blues
would be awesome!!
Or does such a table already exist?
By the way: Does someone know how to add borders to the table?
Offline asura
  • not a duck
Re: Which Cherry MX-Switches share same springs/stems?
« Reply #1 on: Mon, 14 January 2013, 14:53:33 »
There's a table over here which doesn't implicitly state it, but all the "light" share a common spring, the "mediums" also and etcetera.  And there's another of a similar ilk over here.
Offline noxwood
« Reply #2 on: Mon, 14 January 2013, 14:56:55 »
I'm fairly certain those are overlooking some small, 5g differences in spring weight. Last time I checked, it claimed that red and brown were the same, but I believe they have a slight difference.
Offline asura
  • not a duck
« Reply #3 on: Mon, 14 January 2013, 15:00:59 »
I could be entirely wrong (as I don't have a set of springs or a strain gauge) but my understanding was that blue/red/brown had the same spring and the differences in measurements was due to the different stem designs.
Equally, Cherry quotes the actuation force, not the terminal force, which is a very easy thing to alter - for the manufacturer that is - without using a different spring.
Offline Aufwind
« Reply #4 on: Mon, 14 January 2013, 15:23:19 »
That is was I was looking for. Thanks a ton you two! :-)
« Last Edit: Mon, 14 January 2013, 15:29:04 by Aufwind »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #5 on: Mon, 14 January 2013, 15:23:57 »
This is also how I understand it.
« Reply #6 on: Mon, 14 January 2013, 16:41:25 »
Are MX "White" still produced??
I really want to get some so I can get that zinc 2.0 set, because those keys are so heavy..
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Mon, 14 January 2013, 17:33:50 »
Yes, the current white only became available last year. Buy some from 7bit groupbuy.
Offline jabar
« Reply #8 on: Mon, 14 January 2013, 18:11:43 »
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #9 on: Mon, 14 January 2013, 18:14:45 »
Is the MX white spring the same as mx black spring?
Offline BossBorot
« Reply #10 on: Mon, 14 January 2013, 21:52:41 »
yes
also here is a map of some spring and stem combos. Ignore the top part  :p.
« Last Edit: Mon, 14 January 2013, 21:55:01 by BossBorot »
