Author Topic: Cherry Stabilizer Questions  (Read 2378 times)
Offline NikoGasm
  • Platinum mad.
« on: Tue, 15 January 2013, 02:51:42 »
So I got a DK9087 recently and it uses Cherry stabs. They feel really mushy to me (as reported by most people as well) and I've heard some things about a mod you can do eliminate the mush.
I have two questions about that:
1. Does it really work?
2. If so, what exactly do you do?
Offline alaricljs
  • I be WOT'ing all day...
Re: Cherry Stabilizer Questions
« Reply #1 on: Tue, 15 January 2013, 09:04:57 »
Yes it works... video/thread
Filco w/ Imsto thick PBT
Offline NikoGasm
  • Platinum mad.
« Reply #3 on: Tue, 15 January 2013, 09:34:09 »
Thank you very much. I'll be doing this to my stabilizers when I get home.
Offline bardomudo
« Reply #4 on: Tue, 15 January 2013, 09:47:44 »
My KBT Oni had mushy stabilized keys. All I had to do was lube it and after a day or two it became normal. Really hard to differentiate from my Filco with Costar stabilizers.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Tue, 15 January 2013, 09:52:28 »
I've seen those video before but I've always wonder that how hard is it to get those stabilizer "stems" out of the housing to do the mod?
Offline alaricljs
« Reply #6 on: Tue, 15 January 2013, 10:00:23 »
You have to pull the switch and the entire stabilizer set out if you're talking about plate mount.  If you have a Korean board then you have to dismantle the whole keyboard since they use PCB mount.
Offline Hyde
« Reply #7 on: Wed, 16 January 2013, 01:06:50 »
Mmmmm sounds like a lot of work.
Oh and I also try cherry stabilizer for the first time today.  I went to NCIX and they have a demo CM Storm Trigger for me to play around.  I though people were exaggerating but, for the lack of better word it indeed feel mushy when bottom out.  Have to say I definitely prefer costar stabilizer better.
Offline Polymer
« Reply #8 on: Wed, 16 January 2013, 05:17:59 »
If you plan on adding o-rings, I think it is actually better to have cherry stabilizers..
If you don't plan on adding o-rings then I can definitely see where people don't like the difference in the larger keys.    Maybe not so much the space bar but definitely the large keys like backspace/Shift/Enter...
Offline NikoGasm
  • Platinum mad.
« Reply #9 on: Wed, 16 January 2013, 09:36:33 »
I bought like ~500 o-rings for just under eight dollars a few months ago. I set up one of my keyboards, didn't like it, and now they all just sit in their bag. So I definitely don't plan on adding o-rings.
